#61 (permalink) | |
If I do this mod, could I use the old oil coolers (or other heat exchangers in the inlets) for the ProAlloy and lose the one in the stack?
Randy Modified |
| Sponsored Links | |||
Advertisement | |||
#63 (permalink) | |
unamused northeasterner
#64 (permalink) | |
New ends on the lines would sort that out, or new oil lines. But you are also talking about changes and upgrades... Sometimes rushing in is not as prudent as a more reasoned approach. |
#65 (permalink) | |
1. what is the correct oil temperature operating range? Any difference for Street vs Track? 2. How do you change the oil in the same set up? Is there an oil drain plug on the setrab somewhere? 3. How do you go about refilling? Seems to me that there would also need to be some way to refill without having to run the motor? So whats the process here? 4. regarding radiated heat. What about the radiator lines? Yes the oil lines do add some, but the radiator and heater core lines add heat as well. Hopefully Phil can chime in on number 2 and 3. |
#66 (permalink) |
i-VTEC power
Thought I'd bring this thread back to see if anyone else has any pics of oil cooler mounting.
The ones posted are great, just looking for any other mounting bracket options. I'm not the best at fabricating...
Finishing up an 06 Elise engine bay partout, see my thread in the garage sale post for parts you may need. |
#67 (permalink) |
DIY 2007 Exige S K20A2 C38 Rotrex OneHotLap build thread http://www.onehotlap.com/2012/07/lot...rned-into.html http://www.onehotlap.com/2012/07/lot...d-into_11.html |
#68 (permalink) |
i-VTEC power
Still plugging along.
Been waiting for interior pieces from British Racing Group since July ![]() After hearing of all of the nightmares with refilling coolant, decided to order up the tool to fill under vacuum. Other than that the oil cooler is the last on the list, which is why I was here trying to come up with a solution for mounting it. I tried BOE Fab and they weren't any help. This has been the worst experience EVER for a car project!
#71 (permalink) |
Is there a way to bypass the front loop without pulling the rear clam off? Can you get to the oil pipes from the underside of the car near the engine?
Just asking because i have the front clam off now and I don't really want to take on the full project right now, but If i could just bypass the loop and pull all the hardware out of the front this month that would be nice. Our temps don't get real hot so I might not even need a cooler if I stay off the track. Have others just deleted the entire oil cooler with ok results? |
#72 (permalink) | |
90% go, 10% show...
VFII, Eliseparts Sequential, Geartronics Paddle shift. You name it, I've probably got that installed too... 1864lbs, full tank Otherwise, it's bone stock....
#73 (permalink) | |
i-VTEC power
I asked around with some people that were familiar with the honda K series engines, they flow a lot more oil than the toyota so there was an issue with pressure and flow for my set up. That is why I am running a single Setrab in the rear, to keep the lines short. It was either that or a laminar cooling device that uses coolant to cool the oil and I wasn't looking for that much extra work with plumbing
#74 (permalink) |
Thanks guys. Do you think at modest air temps (under 80) it would be safe to run the car without a front oil cooler?
I read a lot of the posts in this tread and it seems like they might run cold with the stock engine and cooler setup. I am changing out the radiator housing and it would be a perfect time to ditch the front cooler.. |
#75 (permalink) |
i-VTEC power
I've read that it should be fine without the front coolers as long as you never intend on tracking the car.
If you only have 1 cooler I personally think I'd just leave it. If you have 2, Sector111 sells a kit to convert it to 1 if you are worried about the oil staying too cold. These cars are so fun to drive fast I wouldn't get rid of it in case the time comes to put your foot into it for more than just a few seconds. Overheating the oil isn't good for any engine.
#76 (permalink) |
Does anyone have a source for the TRD oil/water sandwhich plate? I pulled out the oil cooler and placed an order for a ProRad today. I think for my once a year track event that would cover me just fine with the ProRad and TRD in Oregon temps.
#77 (permalink) | |
The Mad Scientist
I removed the entire oil cooler / line system, including brackets, hoses, coolers and sandwich... Without taking off the front clam! Down to 1762 lbs. with no top and no gas! I had to share
d.a..v...i....d David Thomas Stewart - davidtstewart@gmail.com 2005 Graphite Grey Lotus Elise + BOE Rev400 DragTimes: 402hp 1762lbs. 11.477 @ 123.59 mph |
#78 (permalink) | |
2006 111R Elise,Rev 400 supercharged ,BOE CAB intake, BOE surge tank, Mahle 10.5 pistons, Crower Maxilight conrods, Ferrea Valves & springs, Circuitworx oil pump gear,PPE headers and decat ,HIDs,SSC Harness bar,Nitron SA,Shaved V2 steering arms AP 4 pot calipers CL RC5+ pads,FF engine damper. Saikou Michi catch cans, NGK wideband.Toyota MWR E153 gearbox conversion and Exedy clutch LSD , SSC P&P Adaptronic, CompositeWorx SP1 seats ,Aussie-clamhinge. |
#79 (permalink) | |
Amazing, I'm going to pull out the lines / coolers later this month!
#80 (permalink) |
The Mad Scientist
No additional cooling system yet - but I'm not going on the track until later this Spring.
I'll be doing BOE's rear mounted Setrab system. Add a 1/2 dozen lbs. back for insurance. Certainly was nice driving around this morning knowing all the oil in my engine was contained within the head, block and pan. It was like driving a timebomb around before.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
