There goes my oil. Help - LotusTalk - The Lotus Cars Community
Old 11-14-2012, 04:11 AM   #1 (permalink)
Just had the oil quickly deplete from my 2007 Elise. Got it shut down quickly. Imagine it is the lines like everyone else.
Q 1: Replace with OEM or Sector111 option? or any better options? (located in Texas)
Q 2: How long should it take a shop to change the lines? What is fair price?
Q 3: any other ideas?
It is currently at a good lotus repair shop awaiting my requests....
Thanks all!!
MJDElise is offline   Reply With Quote
Old 11-14-2012, 05:25 AM   #2 (permalink)
'06 Silver Elise
jefrac's Avatar
Hey ElisePtown,
Quite a few of us have been through this. I think all the aftermarket options are very robust and probably much better than "oem". I know RLS makes a great setup too. I replaced my own with the sector 111 system. Just make sure it gets done right and they check the oil cooler thoroughly too. Can't say how long it should take a shop....probably took me 12 hours working methodically. It was the first clam-off job I have done on the Elise.
Where in TX? I am north side of Dallas. PM if you have any questions.
06 Arctic Silver Elise, Touring, Traction Control, Supercharged, 2bular exhaust, Nitron singles, BWR anti-sway bar, RTD brace, no camber shims, SS brake lines, Harness bar and Schroth harness, shifter reinforced, Ultralite lines, green filter, Sport inserts, DBW Pedals, TALLrails, Team Dynamics 1.2's... but THE BEST MOD EVER is reprogramming your engine immobilizer!
jefrac is offline   Reply With Quote
Old 11-14-2012, 07:07 AM   #3 (permalink)
Land Rover
evilfij's Avatar
The remote oil cooler ends from lotus itself up being the least expensive if you are paying for labor to replace all the lines AND if you factor in that you get a radiator as well (which you will end up replacing anyway).
2006 Autumn Gold Elise Lily RIP-rebirth by newowner
2007 Exige S Phantom Black Type 72D Trim Goldilocks
evilfij is offline   Reply With Quote
Old 11-14-2012, 07:32 AM   #4 (permalink)
lotus_dp's Avatar
I see you're a new member...
This is a well-known recall through Lotus - expected official in January.
I'd take the car to a Lotus dealership to get reapired... they should cover the cost.
lotus_dp is offline   Reply With Quote
Old 11-14-2012, 07:51 AM   #5 (permalink)
Chrome orange is faster!
Drew09's Avatar
Yes, do this. Should be nothing out of pocket.
Drew09 is offline   Reply With Quote
Old 11-14-2012, 07:55 AM   #6 (permalink)
sturgeongeneral's Avatar
If there is any damage from oil loss the dealer will replace the engine at no cost.
05 Elise
56 VW Dune Buggy
Lightweight fiberglass toys that simulate street legal rocket ships!
sturgeongeneral is offline   Reply With Quote
Old 11-14-2012, 08:59 AM   #7 (permalink)
glb
Unattractive Nuisance
glb's Avatar
1. It's seldom the lines. More likely the fittings to oil cooler.
2. I used BAT fittings, as did many others. Very secure, attach to existing lines.
3. Many threads on how to fix on LT.
4. If clam does come off, replace radiator with all-aluminum unit. Also found on those threads.
5. I believe the Oetiker clamp w/BAT pieces are better than what recall may provide, but don't have the pprwk in front of me, i.e. I wanted more security than crimps. (If you go this way, you will need to borrow/buy the clamp tool.)
"Political language is designed to make lies sound truthful and murder respectable." G. Orwell.
"Incontinence Emergency Hotline- Can you please hold?"
glb is online now   Reply With Quote
Old 11-14-2012, 11:21 AM   #8 (permalink)
unamused northeasterner
Jack FFR1846's Avatar
If you want your car to be running NOW......consider the toyota adapter and simply eliminate the sandwich.....at least for now.
2ZZ oil cooler sandwich plate delete
This is an easy job. The hardest part is getting the correct socket to remove the sandwich bolt. The hex one....I used a smaller hex wrench and stuck a flat blade screw driver in to fill the void. Worked great.
Jack FFR1846 is online now   Reply With Quote
Old 11-14-2012, 12:33 PM   #9 (permalink)
Drew09's Avatar
I actually have one I'm not using if you want it. Brand new in the bag, $10 shipped if you want it.
Old 11-14-2012, 12:34 PM   #10 (permalink)
Guys,
Thanks for all the great advice!!
It is the crimp at the engine side.
Called the Lotus dealer and they said it should be covered on warranty.
Having towed their. (Park Place Lotus)
Any thoughts on whether the "improved" dealer repair will hold up?
I will definitely upgrade on my time to avoid this again.
Old 11-14-2012, 12:36 PM   #11 (permalink)
Jefrac,
I am in Prosper.
Been watching the board for over a year. Lotustalk just fixed my login where I can now post.
Thanks again!
Old 11-14-2012, 03:33 PM   #12 (permalink)
Drew09's Avatar
Originally Posted by MJDElise View Post
Guys,
Yes, the new recall has the good barb fittings (but the recall said the dealers wouldn't be getting them until January). I'd make sure that is what they use.
Old 11-14-2012, 03:35 PM   #13 (permalink)
Are they replacing all the ends or just the one that happened to fail first?
Old 11-27-2012, 08:01 AM   #14 (permalink)
vrooom vrooom
marius880's Avatar
hey guys... it looks like i am in the same boat!...
I walked down to my car, which was parked, and has been for 2 days. to find all the oil on the floor. but it was not until i had started the car and pulled it out of the parking spot that i saw that.
I quickly turned off the engine and now i am getting towed.
For me it happened in the front. i can see it through the grill and the oil line on the passenger side is pulled apart..
lets hope its a quick fix.
2006 Lotus Elise CO
2003 C32 amg
marius880 is offline   Reply With Quote
Old 11-27-2012, 11:41 AM   #15 (permalink)
Drew09's Avatar
Its not a quick fix. All the fittings need to be replaced under the recall.
Old 11-27-2012, 01:04 PM   #16 (permalink)
Sean K.'s Avatar
I still haven't gotten an answer on this: from the recall notice I read...it only appears to cover 05-07 cars.....I just bought an '08....does that mean I don't have to worry about the oil line/fitting problems?
Thanks,
Sean
Sean K. is offline   Reply With Quote
Old 05-14-2013, 06:17 PM   #17 (permalink)
Thanks,
Sean
I would like to know the answer to this question as well...
cch1 is offline   Reply With Quote
Old 05-14-2013, 06:28 PM   #18 (permalink)
Drew09's Avatar
Call the dealer and give them your vin.
"How many girls per gallon do you get in that car??"
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Lubricating System
