#201 (permalink) |
I recently bought a 34/78 optima yellow top which would have mounted perfectly in place of the original battery but I wasn't liking the plastic hold down that the battery came with so I had a friend help me fabricate a metal one made from 1/4" angle iron. This is a slightly bigger battery than the d35 so the stock battery cover wont work unless I modify it.
| Sponsored Links | |||
Advertisement | |||
#202 (permalink) | |
Haxord but mine
-David 2006 Storm Ti Exige + VF TVS BOE Nikasil 10.5:1 + Vision Function TVS Vision Function MP62 Based Supercharger Install Thread Turn Signals Blink Fast? Stereo Harness Info |
#204 (permalink) |
Interstate MT 26R for Elise
Seems like my battery finally died.
But to be fair, it's partly my fault because I don't drive the Elise regularly. Dealer suggests Interstate MT 26R. Is that a POS? Key issues for me are (1) making sure it fits and OEM bracket is good enough and (2) not having to drive the car every two days for fear of the battery discharging. Unfortunately, I don't have access to an electrical outlet so can't use a tender. Any suggestions? Optima Red Top? |
#205 (permalink) | |
U.S. Cobra Distributer
My eBay Store (note; link seems only to work in Internet Explorer) www.SamplexUSA.com 1) Emergency Alarm/Immobilizer/CDL Override 2) Alarm/Immobilizer Programming 3) Guide to Alarm/Immobilizer/CDL Problems-Elise/Exige/Esprit 4) Alarm/Immobilizer PIN 5) Esprit Cobra 6422 Alarm System 6) Cobra 8186 Manuals 7) Improved AC & Heating 8) Battery Choices and Information 9) Light Bulb Types 2005 |
#206 (permalink) | |
Teacher + Lotus = How?
It will let you go for about 5 days without a real worry...7 at most. But I think you are looking for a larger source, and if so then Michael is correct from what I have seen/read.
2005 Lotus Elise Graphite Grey - Salvaged title being built with SSM class in mind - new replacement. ![]() 1997 Dodge Dakota Club Cab V8 -Nice to have a truck again. 2005 VW Passat Station Wagon TDI (harder to find than the lotus?) 2005 Lotus Elise Starlight Black - Sold |
#207 (permalink) | |
#208 (permalink) | |
#210 (permalink) |
Here is my PC680 in my Elise SC:
![]() You can also see the black switch at top of the mounting bracket to switch off the battery and the two wires are for a permanent charger (that I've never use). Installed since september, no problems. Everytimes I stop the car I switch off the battery. For some reasons if I don't want to do that, the most I left the car closed with the alarm and the battery switch to "on" was three days and there was no problem to unlock and start it again. I lose some weight on the back and achieve the main goal of that modification: I have really much room to put things. When not on track, I can go in hollyday for one week to ten days with my wife (and all women things that men don't need ...) and two bags, some tools and five pairs of shoes ... ![]() ![]() ![]() Much more: I'm still able to put the roof here without problems in this "seven days hollydays" configuration ! ![]() Nothing with us in the cabin, everything on the back: perfect (and it's good because we don't have room behind our seats because of the sector111 v-shape harness bar) !
Elise SC - Larini Track, decat 2bular, cup airbox, Nitron Trackday 46, LSD, ES engine mount inserts, RC5+, gPan2, full alu triple pass rad, PC680, Koldfire tune Last edited by dwarfy; 11-28-2012 at 04:23 AM. |
#211 (permalink) |
Just reporting back that the Optima 34/78 slotted in the Exige battery slot and bracket with zero issues.
It is significantly heavier then the OEM bettery, but it cranks the engine over like never before. Starts instantly. Very happy. Cheers, |
#212 (permalink) |
Trying to find a replacement that will fit unmodified into an Evora. My Varta pos can't hold a charge and I'm hoping to find adequate CCA in a good replacement. Optima red top is too tall, needs to be no higher than 6 inches at the base of the battery posts, 7.5 inches overall height. Length 11.25 and width 6.9 inches max.
Interstate may be my only choice but hoping to find a better, sealed battery. Searched everything I can find. |
#213 (permalink) |
Can anyone comment about Interstate brand batteries? My Elise came with the MT26R, and unless it was a really cold winter and it hasn't been started in over a month, it hasn't failed me...I recently picked up an Exige, which someone replaced that battery with a HUGE one and it's driving me crazy,I want to replace it with something smaller. Weight doesn't matter too much, I want a good reliable battery that will start when I need it to, sometimes after a few weeks of no driving. Dimensions are very close to oem, too...
Specs on the Interstate: Specifications: Product ID: MT-26R Amps: 675 Cranking Amps: 675 Cold Cranking Amps: 540 Voltage: 12 Termination: A Weight: 27.8 Width: 6.81 Length: 8.19 Height: 7.81 Plates: 24 VENTCAP: G WET/DRY: Wet What do you think?
'66 Rustang Fastback '07 Elise - Solar Yellow '07 Exige S - Graphite Gray '12 Mini Countryman S ALL4 '13 MB GLK350 '13 Smart ForTwo Brabus Edition |
#214 (permalink) |
When I bought a battery about a year ago, I was replacing an interstate. I wanted another, but the sales guy told me Interstate moved their production to Mexico and the quality dropped.
I FGI... "f'in googled it" and read that they ARE stamped with "made in Mexico". |
#215 (permalink) |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
