P1071 Code: System mixture to lean (Bank 1) - LotusTalk - The Lotus Cars Community
post #1 of 29 (permalink) Old 03-23-2009, 02:14 PM Thread Starter
Stale_Hotdog's Avatar
Hi i've been getting this code every couple tanks of gas recently. I have an 08 s240 engine mods on the car are (Cup car airbox, larini clubsport 8 inch exhaust, zeitronix a/f ratio sensor and display, sikou michi catchcans, and gotham tune.) I attributed it to bad gas but I've tried different stations and it's been popping up like clock work. Anything I should check for?
Stale_Hotdog is offline
post #2 of 29 (permalink) Old 03-23-2009, 02:42 PM
Is this the first time you have driven it after storing for winter? (Condensation).
Also check your plugs... water collection inside the plug tubes will cause a misfire.
The new owner of RLS is Austin, you can contact him at: Austin0Barrett <<<< @ >>>> gmail <<<< dot >>>> com
Thomasio is offline
post #3 of 29 (permalink) Old 03-23-2009, 03:06 PM Thread Starter
It is my daily driver. I am located in California so I have never stored it or not driven it for more than 2-3 days. It is garaged nightly as well.
post #4 of 29 (permalink) Old 03-23-2009, 03:13 PM
apk919's Avatar
You mean P0171, right?
Do you have an OBD-II scanner with real time data display? Check your fuel trims (STFT, LTFT) to see if they're near the limit of +17%...
apk919 is offline
post #5 of 29 (permalink) Old 03-23-2009, 03:24 PM Thread Starter
I have an OBD-II scanner not sure if it has real time display though
post #6 of 29 (permalink) Old 03-23-2009, 03:27 PM
apk919's Avatar
If it doesn't see if you can borrow one that can. Two important parameters are the Long Term Fuel Trim, and the Short Term Fuel Trim... basically it's telling you how much above or below the baseline tune the ECU is setting the fuel mixture. If the fuel trim goes above 17% (it's adding fuel, since it senses a lean condition), it usually indicates that the ECU is having trouble getting the mixture right...
What does you AFR gauge say, BTW?
CharlieX would probably have a lot more to say on this issue...
apk919 is offline
post #7 of 29 (permalink) Old 03-23-2009, 04:07 PM
OSX Black hat
charliex's Avatar
"larini clubsport 8 inch exhaust"
that'd be my first guess.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #8 of 29 (permalink) Old 03-23-2009, 06:45 PM Thread Starter
I was worried you'd say that . My af gauge flucatates a little at idle it bounces around 14.5-14.7
post #9 of 29 (permalink) Old 03-23-2009, 07:00 PM
OSX Black hat
charliex's Avatar
for idle thats fairly normal, its trying its best to maintain 14.6
charliex is offline
post #10 of 29 (permalink) Old 03-23-2009, 07:20 PM
Chili Red's Avatar
Id say cup car air box is the issue. I put it on a few months ago and I'm getting the same code...
2007 Exige S - Chili Red
2009 Mini Cooper S - Chili Red
Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera.
Chili Red is offline
post #11 of 29 (permalink) Old 03-23-2009, 07:46 PM
OSX Black hat
charliex's Avatar
its possible, but just do a search on larini p0171 (or lean), and i'm talking about results we've seen on the dyno too.
charliex is offline
post #12 of 29 (permalink) Old 03-23-2009, 10:25 PM
shay2nak
shay2nak's Avatar
I'd say cup box also.
There are ODB readers that will tell you fuel trims?? I bought one but it was cheap, $70. Don't think it does it. Maybe I can exchange...
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #13 of 29 (permalink) Old 03-23-2009, 10:30 PM
OSX Black hat
charliex's Avatar
i'd be shocked if it didn't, not at $70. look for short term and long term fuel trims,or STFT LTFT
charliex is offline
post #14 of 29 (permalink) Old 03-24-2009, 05:54 AM
apk919's Avatar
To see fuel trims you have to get a reader that displays real time OBD-II parameters... they're a little more expensive than the ones that just read and reset DTCs (CELs). There are quite a few standard fuel/emissions related parameters (since emissions was really the point of the OBD-II standard... you can thank CARB for that)
apk919 is offline
post #15 of 29 (permalink) Old 10-19-2009, 04:31 AM
mrcarcrazy's Avatar
Thread revival. I've gotten this CEL twice so far. just over a month and 1000 miles between the two incidents. I do not have an aftermarket intake. and no recent mods to the car.
My Reader shows a snapshot of what was going off when the CEL was set.
so here's that
Load PCT 33.7%
ETC (F) 172
Shrt FT 5.5
Long FT 8.6
Rpm 1650
VSS 2mph
MAF 1.041
TP 14.9%
Any ideas?
2005 Magnetic Blue Elise - "the Lotus" (original I know)
1999 Jeep Wrangler
2013 335 M sport.
If you dont GET it after you drive it, then you dont GET it - serpent
mrcarcrazy is offline
post #16 of 29 (permalink) Old 10-19-2009, 05:32 AM
Check for exhaust leak
alexscotti is offline
post #17 of 29 (permalink) Old 10-19-2009, 05:34 AM
spectre's Avatar
I had that same code and cup airbox. Went back to stock Airbox and have not had it come back. I do have the clubsport exhaust.
spectre is offline
post #18 of 29 (permalink) Old 10-19-2009, 05:59 AM
mrcarcrazy's Avatar
ok, I'll check for exhaust leaks, anything else I can look for/ test while I'm under the Car?
Again stock intake. and no mods in the past year except STS. This code has popped up twice in the year I've owned it. almost 1000 miles separate the two incidents.
1999 Jeep Wrangler
2013 335 M sport.
post #19 of 29 (permalink) Old 10-19-2009, 10:59 AM
Simba's Avatar
Probably an exhaust leak. If you're running the stock engine mounts, check your manifold studs/bolts and make sure they're tight. In my experience it's quite common for the manifold to work loose due to the stock mounts allowing the engine to move around A LOT.
Simba is offline
post #20 of 29 (permalink) Old 10-19-2009, 11:07 AM
mrcarcrazy's Avatar
Interesting. will do.
Thanks guys.
1999 Jeep Wrangler
2013 335 M sport.
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Check Engine Codes
Human Verification
