Go Back   LotusTalk - The Lotus Cars Community > Community > Other
Old 10-19-2009, 04:03 PM   #1 (permalink)
kaz
JabStrongFierce
kaz's Avatar
Benign Paroxysmal Positional Vertigo
Benign Paroxysmal Positional Vertigo (Benign Positional Vertigo): Dizziness and Vertigo: Merck Manual Home Edition
Second time I got this from being in the Lotus...first time was after track day at Streets. And yesterday after romping around in the Lotus I came home and promptly almost fell over from the spinning !
Going to try this maneuver to resettle the little rocks in the inner ear - track day won't be fun if the world is spinning around and round...
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning
kaz is offline   Reply With Quote
Old 10-19-2009, 05:05 PM   #2 (permalink)
Vulcan Grey's Avatar
Been to South or Central America lately?
My parents suffered dizzy spells and vertigo for about a year after visiting Guatemala. Turned out to be a virus.
Travis
Vulcan Grey Esprit SE
http://vulcangrey.lotuscolorado.com/gallery
Vulcan Grey is offline   Reply With Quote
Old 10-19-2009, 05:26 PM   #3 (permalink)
perfututum futūtor
RoadDad's Avatar
Not all short duration vertigo is BPPV. It is one of the most commonly misdiagnosed "causes" of vertigo. There are specific symptoms/signs that need to be present (rotatory or torsional nystagmus, fatiguability, for example) for correct/accurate diagnosis. It is also typically unilateral and the treatment is side specific. If you actually do have BPPV and correctly perform the particle repositioning maneuvers for the wrong side you may actually make things worse . If you actually do have BPPV and correctly perform the particle repositioning maneuvers for the correct side, they still don't always work.
Me... I don't need to.
Bite me." -Randy
Old 10-20-2009, 05:57 AM   #4 (permalink)
#334
Chococar's Avatar
I got it while a passenger with the instructor driving at the Lotus driving school at the factory... Didn't know it had a fancy name though
Old 10-20-2009, 06:14 AM   #5 (permalink)
Mods are good for you
Dave's Avatar
Peter,
You sure this isn't just bed spins from spirited Wild Turkey sipping?
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 10-20-2009, 07:57 AM   #6 (permalink)
timmp's Avatar
some thoughts on this
Kaz:
I have the same issue and went through a long series of tests and evaluations a couple years ago to address it. I did the repositioning exercises, and it seemed to get better, but didn't go away. I then went to the optometrist to get some reading glasses, as my vision was changing (welcome to my 40's), and told him of the vertigo issues, and he tested my distance vision and discovered that I was a little bit weak at long ranges (I hadn't noticed this). So, very light prescription driving glasses and bingo, I'm much better. Also, even now, if one of my ears gets partially plugged with wax, I get the same symptoms of dizziness and lack of focus after driving.
Just some more info to consider - my situation was a bit different, as I was having symptoms every time I drove, but if this helps you, then all the best.
tim
When in doubt, accelerate!!!
timmp is offline   Reply With Quote
Old 10-20-2009, 09:04 AM   #7 (permalink)
RENDERMAN's Avatar
Images: 6
Dramamine should take care of the problem
WILL.I.AM
2005 Saffron yellow Custom Elise….
Adobe Photoshop CS4 Certified Instructor
Check out my work, Site under construction...
http://www.wilsart.com/
RENDERMAN is online now   Reply With Quote
Old 10-21-2009, 11:48 AM   #8 (permalink)
kaz
JabStrongFierce
kaz's Avatar
ENT said I had a light case of it, probably brought on from the Etyomtics (in ear plugs) that I use once in a while since they are hard to pressurize the same in both ears. So...you spin around in the car, take out plugs...pressure changes between ears and voila' spin city. Told me to stick with the Shures I have instead as they are the expanding foam type and you don't "push" them in, they kind of expand into your ears.
Anyways did the procedure, went away after a couple minutes of reorienting.
I also found this funny product
Epley Maneuver for Vertigo & BPPV Treatment - DizzyFIX
