Former Lotus, current Z06
Maybe Someone Here Can Help
For an engineering class, I need to physically model what went wrong at Chernobyl. So far, I have split it up into three main parts.
1) The reduction of power caused a decrease in cooling. Temperatures rose. 2) An employee saw these increased temperatures and tried to shut down the reactor by inserting control rods, causing an energy spike. The control rods broke and were unable to be completely inserted. This increased the temps further as well as increasing the pressure. 3) Explosion. Graphite ignited. Spread of radioactive material. The way I see it, a physical model can be done by having some reaction going on in a container. Obviously safety is going to be a concern, so I'm trying to figure out what reaction I could use. The reaction (ideally) would have to be able to be controlled by some sort of cooling system in order to show how stage 1 occurred. Stage 2 would be relatively simple, since it would just be adding a substance to speed up the reaction. I'd like to avoid an actual explosion for stage 3, so I'm stuck at the moment since I don't know what reaction would be suitable in the first place. Any suggestions? Thanks, ~Jeremy K. |
G-200 Driver
magnesium.
Hydrocarbons Rule
Thermite would simulate the core burning down threw the layers of the building and in to the ground quite well...
Thread unraveler
"Explosion" idea: Diet soda and menthos. Fill you your "cooling rods" with menthos. Then crack them.
2007 Cross Country Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#6 (permalink) | |
WILL.I.AM 2005 Saffron yellow Custom Elise…. Adobe Photoshop CS4 Certified Instructor Check out my work, Site under construction... http://www.wilsart.com/ |
#7 (permalink) |
really light stuff
![]() Join Date: Jul 2003
Don't waste Russian Standard... that's good stuff. (At least it was in Mockba!)
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#8 (permalink) |
Well I ended up deciding to do the following:
Water being heated on a stove while adding cold water from time to time will simulate the reactor as it should be. When the amount of cold water is reduced, as the heat continues to be added, temperature will go up. This is stage 1. Stage 2 and 3 will be covered at the same time by adding dry ice or magnesium "control rods". EDIT: And would anyone like to explain why the vodka was posted? |
#10 (permalink) |
Not boiling. Besides, I'm probably going to have to go with dry ice. Not sure how to get my hands on magnesium
EDIT: I may be an idiot about the magnesium + water reaction lol. If it's the same thing that I think it is, then simply adding magnesium to water causes it to ignite. Last edited by jk13 : 10-11-2009 at 08:28 PM. |
#11 (permalink) |
Hoon
I believe you're thinking of sodium...
I suppose if you want an explosion you could set it up where you have a pump keeping water away from a piece of sodium . Cut power to the pump and the water rises and there is your big boom. Last edited by Amarao : 10-11-2009 at 08:44 PM. |
#13 (permalink) | |
Magnesium can be purchased in strips at some hardware stores, also a quick go at google might help. Thermite really would be spectacular, that's exactly what I was thinking. You could have various layers of materials for the thermite to burn through. Magnesium strip could be your heat source and a copper tubing between them would be your cooling system. By circulating water through the copper tubing you would be removing the heat preventing the ignition of the thermite. Once the flow of water stops, the magnesium burns through the copper and ignites the thermite. The thermite then burns out of control. Burns a hole in your layers of BS then through the bottom of you project board, then the table, then through the floor tile, Then begins to penetrate the floors foundation. JUST FREAKING LIKE CHERNOByL! Man I wish I could be there. Gig 'em ![]() Darrell Webb
Yes, that's very nice, Thank You.![]() ![]() ![]()
#20 (permalink) |
Hydrocarbons Rule
