#21 (permalink) |
Unfortunately, Trek has quit making their frames in the USA. Almost everyone has
Cannondale may be the last big manufacture that is not out sourced. The 2009s I don't know? High end Bianchi's are still Italy I believe. Being a Klein owner I would think you are looking for something a bit more upscale. I picked up this 2007 bike used on ebay last year. My local dealer (#1 bike shop in Portland) could not get me a 2008. This is quite the frame for a semi-mass produced bike. The seat rear stays are so soft they flex like a passive shock absorber system. Cannondale has been refining their aluminum tubing profiles for the last 20 years. The welds are near the quality of Klein. Of course Ti and carbon frames are said to be an even better ride. It's all how much you want to spend. |
#22 (permalink) |
As far as I know, trek did not completely stop making frames in the US. The lower end carbon frames are made overseas, I think China, but the higher end OLCV carbon frames are still made in the US.
225 TTQC & 05 Elise |
#23 (permalink) |
Regurgitated User
i don't think you want a 180 crank... especialy if you need a tripple. crank length will not make you and faster (or slower) on pace, but longer arms will make your ability to acelerate slower. longer arms can make a given rpm on climbing a little more faster - but again, that is not a factor if you need a tripple to climb with anyways...
Driving it around!
#24 (permalink) |
#334
You're right. I want a 200mm crank
And I've found it! Lennard Zinn makes cranks up to 220 mm It's always seemed silly to me that I am stuck with short stubby cranks (in comparison to my long legs). Lennard is a tall guy who makes and sells everything for the tall rider, including frames, clothes, etc. His web site is zinncycles (dot) com.Yeah, I know I'll be taking some risk, but if I really don't like them, I'll put some "normal" size ones on instead. Thanks again for all the advice, everyone! Joe |
#25 (permalink) |
Enemy of the State
Proper fit is everything when buying a bike. You are tall enough that there aren't many choices for production bikes that will fit you well. Make sure that your shop has plenty of experience with professional fitting tools such as a Serotta Size-Cycle so that they can get you set up properly before you sink your money into a mistake. You don't want to have to rig a stock size frame with such a long stem that it shifts too mcuh of your weight to the front wheel. You also need to be careful of putting really long cranks even if they fit you) on a bike that isn't designed for them because you will reduce the pedal clearance and may end up clipping pedals against the ground when turning.
Zinn has more expertise than anybody in the country in dealing with tall cyclists. It is worth talking with him for some advice or even springing for one of his custom frames. Serotta also does a good job with tall frames. Check with Craig Calfee if you are dead set on carbon. PM me if you want more advice. I worked in the bike industry for 18 years selling and fitting high-end custom bikes, so I have a little experience with this subject.
06 Elise, AW, Touring, Sport, Premium, Hardtop, Starshield -- S111 Harness bar, Schroth ASM 6 point Harnesses, Seat Grommets, Front Tow Hook, Rear Tow Hook, Halon fire extinguisher, Polk speakers, MicroMirror, Odyssey PC680, ekological HID kit, Pagid RS14 pads, SS brake lines,CF Center Console, CF AC Surround, urethane motor mounts, Titanium Dave's Sub Belt Bars, Heater Core Bypass , Craftsquare Mirrors, Carbon Splitter, LETSLA, DBW Pedals, Xtender |
#26 (permalink) |
#334
Here's what I ordered
Thanks again everyone for your advice!
I ordered a 2010 (available beginning July 1) Trek Madone 5.2 OCLV carbon fiber frame (made in Waterloo, Wisconsin) with the new Ultegra 6700 group (cables under the handlebar tape) except: 180 mm DuraAce triple crank AND 200 mm Zinn triple crank (I'll experiment and decide which I prefer) Velocity Deep V 32-spoke wheels, front & rear with 25 mm wide tires Speedplay pedals (to clear the ground better with the long cranks) I'll post my impressions after I get the bike and do some riding. Thanks, Joe |
#29 (permalink) |
Hope the bike works for you.
You may want to look at Xtracycle for touring. Their longtail adapters work for most frames. Welcome | Xtracycle, Inc. Xtracycle Products & Accessories | Xtracycle, Inc. Worth looking at are the choices in hubgears, up to 14 usable speeds, with a wider range than most derailleurs. And there is at least one combo hubgear/ derailleur with 27 speeds on the rear alone. No chain twisting between front and rear. And boron-aluminum is far superior to titanium. I think there are boron frames too, only a third lighter than titanium. |
