Old 08-31-2009, 09:35 AM   #1 (permalink)
Formulabob's Avatar
15/16 Wheel-Brake Caliper Clearance
Do 15" front wheels clear the AP 4-pot calipers? If yes, then what brands/widths/offsets work? It seems that I really need a set of wheels/tires for street usage and a second set of wheels/tires for track usage. The potential weight and cost savings of the 15/16 setup is enticing, so some good info would be appreciated.
Bob
2008 Solar Yellow Exige S with Touring and Track Packs, Manly engine mount inserts, intercooler scoop and shifter mods, RLS tubes, Cup air filter, Cup wheels, and some unique body paint accents -- many more mods to be added over time.
1991 Elan M100 stock except for a roll bar and Wilwood brakes.
2008 Lincoln MKZ for rain, or rush hour traffic, or trips with luggage, or big/non-limber passengers .
Formulabob is offline   Reply With Quote
Old 09-01-2009, 08:36 PM   #2 (permalink)
Formulabob's Avatar
Does anyone have an answer? I certainly would appreciate some info.
Bob
Old 09-19-2009, 01:26 PM   #3 (permalink)
A7594217's Avatar
Bump for an answer
05 GG Elise-BWR S/C-Nitrons-Intake-Exhaust-Test Pipe-Cf Scoops-Cf Lip-Cf Diffuser-Piaa Wheels-And all the little stuff
A7594217 is offline   Reply With Quote
Old 09-19-2009, 01:30 PM   #4 (permalink)
Exige enthusiast...
sandsmuseum's Avatar
Images: 33
No, 15 inch wheels do not fit the AP brakes
I have tried the 15 inch Rotas and they did not clear the caliper on the AP brakes. This was tried on my 2008 Exige S 240. They were not close so I expect no wheels will fit although I have not tried any others.
This is truly sad. I was very impressed with the handling on my Elise with 15 / 16 inch rims. I am very unhappy with the brakes (see other posts of mine) and the handling of my Exige with 16 / 17 inch rims.
Ohlins go on this week. Maybe I will change my mind then...
www.sandsmuseum.com
antique coin op repair
mod for the Library on EliseTalk
sandsmuseum is offline   Reply With Quote
Old 09-19-2009, 05:54 PM   #5 (permalink)
choi0706's Avatar
you've got more problems with the rear parking brake cables rubbing.. be sure to zip tie those back
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 09-21-2009, 08:03 AM   #6 (permalink)
Exige Cup 255
Noel's Avatar
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
The minimum wheel clearance is a 16' inch front wheel for the Lotus Sport AP BBK.
And 16/17 is a better combination than 15/16. Proper forged wheels will give you the weight savings required.
Noel is offline   Reply With Quote
Old 09-24-2009, 09:48 AM   #7 (permalink)
Assuming the proper tires and rim sizes were available, 15's would be the ideal combination all around, and a properly forged 15/16 will still weigh all the more less than a properly forged 16/17 comparable rims. I'm not saying there is an appropriate all 15" or 15/16 set of tires and wheels, but i am saying that fundamentally (it's physics) it should be better. Look at any true over the top race car from F1, nascar, to dragsters and they all the smallest rim that'll fit on the brakes. LOTS of sidewall.
I think some of the creative brake cooling options that some people have done here are a more elegant solution (although i'm not a brand guy, it's a very "lotus" idea. Instead of adding bigger brakes, add more cooling... which will likely weigh less and enable other performance features like smaller rims. The problem isn't the brakes ability to stop the car, it's their ability to disipate heat. Treat the problem not the symptom.
2006 Aspen White Elise. Hard top (never left it's shipping box), LSS, LSD, Traction control, Red leather.
ewalberg is offline   Reply With Quote
