McLareghini Bugatterrari
Runout? I don't know of a spec, but I would imagine any more than 0.0010 or would be noticeable on these cars.
I've never heard of rotor runout being a required check for a state safety inspection before. Your state must be very strict!!! xtn
I believe the minimum spec for rotor thickness is 24mm.
xtn
#7 (permalink) |
The 24.9mm figure is a misprint, left over from the S1 cars. Or so I've read on this forum many times. I believe the correct figure for S2 cars is 24mm.
xtn
#8 (permalink) |
anglophile in exile
The 24.9mm figure is from the S2 service manual - I am checking if it is the same for the Fed version (the rotors are the same) and will update as soon as I have the correct figure. If you have the Fed service manual can you let me know what it says?
#9 (permalink) | |
OP. check the rotor. it is imprinted on the rotor. xtn is saying the 24.9 is a misprint in the service manual....( this has been stated on this site numerous times)...I haven't verified by looking @ my rotors, hence the suggestion to the OP
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent |
#10 (permalink) |
I believe the rotors are stamped 24.0, and right or wrong they ARE stamped. I'm surprised the safety inspector doesn't know to look at the rotor itself.
#13 (permalink) |
Woooo hooooo! I got something right for once!
xtn
