Old 04-08-2005, 09:36 AM   #1 (permalink)
AIRacer's Avatar
Azenis 245-17's don't fit
FYI. I picked up a set of Azenis RT-215's to trash during my upcoming 3 days of Evolution schools. I went with 215s front / 245s rear. The 215s look like they clear fine, but the 245s are wider than the Kumho V710s. I pulled the rear spring & ran the suspension up to bump stop compression <1". The Azenis hit hard on the forward section of the inner wheel well (same place as the V710s, but much worse) & at the rear outer fender where the side marker light protrudes. Wheel spacers would be disastrous.
I have a set of the new RT-615 compound in a 225 width on the way for the rear. Hopefully the new compound won't overheat as much, but they are nearly as expensive as other options.
Finally here: Ardent Red, LSS, Hardtop, Touring Pkg
AIRacer is offline   Reply With Quote
Old 04-08-2005, 10:30 AM   #2 (permalink)
That's surprising. Azenis run wide for street tires, but I was under the impression that V710's would be considerably wider.
It sounds like you have another option on the way already. Did you consider the Hankook R-S2's? They come in good sizes, and are relatively cheap. Should be on a comparable level to the Azenis. I just got a set for my WRX, didn't get them mounted yet.
Reto
2005 Lotus Elise (yellow, sport pack), #94 SS
2005 Nissan Xterra (LSV)
ConeFusion is offline   Reply With Quote
Old 04-08-2005, 10:43 AM   #3 (permalink)
It's not the width that is the problem, it's the combination of width and height. The frame gets more narrow towards the passenger compartment. 245/45 Azenis are almost an inch taller than the AO48s and over an inch taller than the 245/40 Hoosiers. The shorter the tire, the wider you can go.
Starlight Black, Sport Pack, Since Oct. 04
TripleBlack_NJ is offline   Reply With Quote
Old 04-08-2005, 11:22 AM   #4 (permalink)
I was referring to the same size (245/45-17) V710's, which both Randy/Robert and Darrin have fit successfully. They did get some rubbing with the V710. I'm surprised that the Azenis would cause bigger issues than the same size V710.
Reto
Old 04-08-2005, 12:51 PM   #5 (permalink)
AIRacer's Avatar
Ha! If you walked into my shop's storage building (that has been commandeered as a race garage) you would now find at least 20 sets of new or slightly used of tires between the MR2, shifter karts, Elise, etc... I now have a set of V710s, AS304s, A048s & now the Azenis for the Elise & have ran it twice so far. What's another set? I'll have to start a tire store!
Thanks for the suggestion though. I'm curious how they will perform.
Old 04-08-2005, 02:15 PM   #6 (permalink)
Thanks for posting your findings. I wouldn't have guessed they would be worse than 710's in the same size, glad you told us.
z06fun is offline   Reply With Quote
Old 04-08-2005, 04:04 PM   #7 (permalink)
MyElise's Avatar
Images: 28
That's why these things need 15/16's to run bigger rubber.
MyElise is offline   Reply With Quote
Old 04-09-2005, 09:39 AM   #8 (permalink)
Time to DRIVE
adamant's Avatar
Images: 2
But 15"F and 15" rear wheels don't fit do they? I thought the brakes were changed and there is not enough room for the smaller wheels any more. I'd be interested to fit out if I am wrong
2006 Exige Chrome Orange
adamant is offline   Reply With Quote
Old 04-09-2005, 09:46 AM   #9 (permalink)
Evl
His Impatientness
Evl's Avatar
Yes, they will fit, as of serial number 1440ish. You might need a significant spacer to get the offset right, depending on which wheels you use. If you are interested in some 15" SSRs and V710s with some custom made spacers, let me know. I was planning on running in ASP, but will probably stick to SS this year.
www.agentsofentropy.com
Evl is offline   Reply With Quote
Old 04-09-2005, 10:07 AM   #10 (permalink)
What is the significance of 1440? Did they upgrade the brakes?
Old 04-09-2005, 12:11 PM   #11 (permalink)
Time to DRIVE
adamant's Avatar
Images: 2
Yeah, mine is much earlier than that (mid 300's ), I didn't know they changed any of the brake hardware.
Old 04-09-2005, 04:11 PM   #12 (permalink)
I'm in the 300s too. So what's different now?
Old 04-09-2005, 04:23 PM   #13 (permalink)
Evl
His Impatientness
Evl's Avatar
Not that anyone told me, but adamant seemed to think so. I'm just pointing out that if there was a change before 144X, it doesn't preclude a 15" SSR.
Old 04-09-2005, 04:25 PM   #14 (permalink)
Evl
His Impatientness
Evl's Avatar
Gee, don't get confused by your own rumor!
Old 04-10-2005, 09:07 AM   #15 (permalink)
Time to DRIVE
adamant's Avatar
Images: 2
My fingers can't keep pace with my brain. I can't figure out what I was trying to say there..
So to correct -- I do not know of any change in the brakes. I thought that we could not install 15" front and 16" rear wheels on the federalized Elise. If someone knows otherwise please post.
Old 04-11-2005, 04:59 AM   #16 (permalink)
>>> I went with 215s front / 245s rear. The 215s look like they clear fine, but the 245s are wider than the Kumho V710s. I pulled the rear spring & ran the suspension up to bump stop compression <1". The Azenis hit hard on the forward section of the inner wheel well (same place as the V710s, but much worse) & at the rear outer fender where the side marker light protrudes. Wheel spacers would be disastrous.<<<
It might not be that the 245/45 Azenis are wider than the 710s leading to more rubbing....DOT-R race rubber tends to run smaller in diameter than other tires. Both diameter and width affect rubbing...
