Old 06-22-2009, 08:09 AM   #1 (permalink)
saudio's Avatar
Brake fluid question
I just called Criswell parts (Gaithersburg Lotus Dealer) asking about the proper brake fluid to use when I do a flush on my 2005 Elise. I was told that any DOT 4 fluid was fine.
To get a more specific recommendation, I called Euroclassic parts (Richmond Lotus Dealer) and asked the same question. I was told that any DOT 3 fluid was fine.
Could somebody tell me the correct answer, and perhaps recommend a brand that is commonly available?
Thanks
Driving lights and a Lidbone.
Oh, and a supercharger.
saudio is offline   Reply With Quote
Old 06-22-2009, 08:19 AM   #2 (permalink)
User, Registered
fpitas's Avatar
DOT 4 is a "better" fluid, in that it has higher boiling points than DOT 3. Nothing wrong with the Castrol LMA DOT 4 available in almost any auto parts store.
Francis
Old 06-22-2009, 08:24 AM   #3 (permalink)
GR8 SCAPE
waydui's Avatar
DOT 4
According to the 2005 Elise Owners Manual you should use DOT 4 brake fluid.
I used Valvoline SynPower brake fluid until they discontinued it.
Now I use Valvoline DOT 3 & 4 Brake Fluid.
Regards,
Wayne
_______________________
Old 06-22-2009, 08:26 AM   #4 (permalink)
saudio's Avatar
Thanks. Very helpful.
So the same fluid can be both DOT3 and DOT4. That's interesting.
Old 06-22-2009, 08:28 AM   #5 (permalink)
User, Registered
fpitas's Avatar
Regards,
Wayne
I had been using the Valvoline, but recently they lowered the specs on boiling points, which was rather disappointing. Still nothing wrong with it.
Edit: that is, the new stuff is not as good as the Synpower.
Francis
Old 06-22-2009, 08:28 AM   #6 (permalink)
User, Registered
fpitas's Avatar
It's a "meet or exceed" sort of thing.
Francis
Old 06-22-2009, 08:30 AM   #7 (permalink)
Alarmed & Dangerous
TheViper's Avatar
I only use Castrol GTLMA (exceeds DOT 3 & 4 specs.), because of what LMA stands for "Low Moisture Activity"
Cheers,
Old 06-22-2009, 08:39 AM   #8 (permalink)
GR8 SCAPE
waydui's Avatar
The only real difference between DOT 3 and DOT 4 brake fluid is the boiling point. All brake fluids must meet FMVSS116 minimum boiling points specification. DOT 4 is also less hygroscopic (less affinity for moisture).
FWIW, DOT 3 boiling point is 401 degrees F. DOT 4 is 446 degrees F.
Regards,
Wayne
Old 06-22-2009, 08:55 AM   #9 (permalink)
TimMullen's Avatar
Images: 19
+1
I've been using the stuff forever, and have never had a fluid related problem with and brake or clutch system. It lasts a lot longer than "regular" brake fluid in those cases where I don't get to flushing the system as often as I'd like to...
94 Miata R Package - Black
Old 06-22-2009, 02:50 PM   #10 (permalink)
It is more complex than that, and the DOT 3 or 4 or 5 do not refer to the boiling point.
You can have different DOT3 with completely different boiling point, from 300 F to 660 F.
Do not touch DOT5, the pedal will be spongy, but it is better for the paint if you drop the oil to the paint.
Now, which one, DOT 3 or 4. No big deal, take any of both. It is more a question of chemistery about sealing.
If you are heating the oil by braking hard, go with some cheap DOT3 Ford at 550F. If you race or you are doing track day, DOT3 or 4 with a boiling of 600 is more than enough. And if you are very gentle with the car, just respect the car spec witj usual DOT4 oil spec, without taking care of the boiling point.
Elise 2006, white, Katana
Europa 1969, green, H22A, 194 whp, 1550#
CONFIGTECH.ca / Solidworks
elise/europa is offline   Reply With Quote
Old 06-22-2009, 03:11 PM   #11 (permalink)
Bane's Avatar
Images: 4
I only use Motul RBF600 in the Elise.
Works great
Don't use DOT 5... it's silicon based and isn't compatible with DOT 3/4.
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Old 06-22-2009, 06:39 PM   #12 (permalink)
Many use ATE type 200 (amber colored) alternating with ATE Super Blue (Blue colored). It's basically the same stuff, just with different dyes. The change in color makes it easy to tell when you've flushed all the old fluid out. Both are DOT 4.
Having said that, Castrol LMA is a solid performer, and available just about anywhere.
Pengineer91 is offline   Reply With Quote
Old 06-22-2009, 06:47 PM   #13 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Unfortunately LMA was only available in my area at Pep Boys, no others carried it.
Old 06-22-2009, 06:50 PM   #14 (permalink)
Exige Cup 255
Noel's Avatar
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
I'm on Honda DOT4. No problems whatsoever, in fact, it was better than the OEM stuff from a performance perspective.
Noel is offline   Reply With Quote
Old 06-22-2009, 07:07 PM   #15 (permalink)
G-200 Driver
kestrel74's Avatar
Super Blue all the way !
Old 06-23-2009, 06:29 AM   #16 (permalink)
User, Registered
fpitas's Avatar
Since we're discussing brake fluid:
Wikipedia.org - DOT 4
Wikipedia.org - Brake fluid
BTW, from my reading the new DOT 5.1 fluid might be a good choice: Wikipedia.org - DOT 5.1
The Motul DOT 5.1 is reasonably priced at about $7 for a 0.5 liter bottle.
Francis
Old 06-23-2009, 07:46 PM   #17 (permalink)
Living for track days
Rennstore's Avatar
Motul 600 - leaves NO stains as ATE BLue does and is a better fluid hands down than almost anything out there.
www.RennStore.com -- The source for Pagid brake pads
Craig
Rennstore is offline   Reply With Quote
Old 06-24-2009, 11:12 AM   #18 (permalink)
MugsyTheGr8's Avatar
here is an article from the stoptech homepage regarding brake fluid for those who want to learn more about it from a performance oriented standpoint.
it goes into the differences between dot standard and racing fluid as well as the advantages and weaknesses of different types of fluid.
MugsyTheGr8 is offline   Reply With Quote
Old 06-25-2009, 09:07 AM   #19 (permalink)
OTB
OTB's Avatar
RBF600 here too...
It has always worked for me. If you track the car, I recommend it. If you don't, any dot4 would work for you for street/auto-x.
OTB is offline   Reply With Quote
Old 06-25-2009, 11:12 AM   #20 (permalink)
Taken from the article
As a trailing note on the DOT ratings, if your car was designed for a particular type of fluid (especially prior to the development of DOT 4 fluids), you should make every attempt to stick with that fluid! For example, if your car was delivered with DOT 3 fluid, the internal components of the system (seals, brake hoses, and fittings for example) were specifically designed and tested for compatibility with DOT 3. Because DOT 4 fluids contain a different chemical composition, the system may not necessarily react in a positive fashion to the borate esters floating around in the mix.
Ren Man is offline   Reply With Quote
