Old 05-09-2008, 05:20 PM   #1 (permalink)
jkolb's Avatar
Brake Warning Light Issue
The brake warning light on my Exige flickers on when I take a sweeping right turn. I have checked the fluid and it is 1 cm above the line on the reservoir and, yes, the emergency brake is all the way off. Any ideas?
Thanx
Jerry
2007 Laser Blue Exige S
1965 Elan (26r clone) vintage race car
2005 Audi S4
jkolb is offline   Reply With Quote
Old 05-09-2008, 05:24 PM   #2 (permalink)
BANNED
Thanx
Jerry
Same thing happens to me on left turns. I keep meaning to check the fluid level. Will do it tomorrow before work and report back.
mpsalm is offline   Reply With Quote
Old 05-09-2008, 06:04 PM   #3 (permalink)
Zzzzzzz
Green Hornet's Avatar
I wonder it this is catching
My light comes on when I turn hard or sweeping left.
How full is the reservoir to be?
Life, Liberty and the Happiness of Pursuit
Green Hornet is offline   Reply With Quote
Old 05-09-2008, 09:46 PM   #4 (permalink)
thegoat's Avatar
I have never had it happen, but my reservoir is full to nearly the top, or the max line, if there is one. I was doing an inspection the other day and everything looked good. I just remember it looking pretty full when I inspected.
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 05-09-2008, 09:47 PM   #5 (permalink)
the fluid sensor is at the top and it goes off on turns even when its near full . top off the fluid i'll bet your pads are getting worn when that happens the fluid leval drops. remember to take some out when you replace the pads so it doesnt come out the top. carl
User formerly known as 4carl
carl is offline   Reply With Quote
Old 05-09-2008, 09:59 PM   #6 (permalink)
Chris Mackey's Avatar
This happened on my 94 Plymouth Villager (minivan) while cornering. The fluid was slightly low, and after topping it off, it went away.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
Chris Mackey is offline   Reply With Quote
Old 05-09-2008, 10:25 PM   #7 (permalink)
R T
Registered Loser
R T's Avatar
It's definitely the fluid, top it off and like carl said, don't forget to watch it closely when you push the slave cylinders back in.
R T is offline   Reply With Quote
Old 05-10-2008, 03:56 PM   #8 (permalink)
jkolb's Avatar
So, I took off the access panel again today and found that m fluid level was about 4 mm below the MAX line, but well above the molded in line. Filled it up to the MAX line and that cured the problem. It appears that the sensor is very sensitive to the fluid height and will give you a lot of warning about low fluid levels.
Jerry
2005 Audi S4
Old 05-12-2008, 09:32 PM   #9 (permalink)
BANNED
How does everyones brake fluid reservoir sit?
Mine doesn't sit flat so filling to the max line on the front doesn't get to the same spot in the back. So I overfilled it slightly.
Old 05-12-2008, 09:53 PM   #10 (permalink)
German Reimport
Mr.C's Avatar
Same here.
I had the last brake fluid change done at the dealer during the 7500 mile service, and they also filled the reservoir all the way to the top past the max line.
Mr.C is offline   Reply With Quote
Old 05-13-2008, 04:47 AM   #11 (permalink)
#334
Chococar's Avatar
Have you tried cleaning the contacts, as described in this old post of mine (#15 in this thread)?
brake warning light on (dim)
Thanks,
Joe
Old 05-13-2008, 05:00 AM   #12 (permalink)
Trust in God
Needspeed's Avatar
07 Exige S (Chili Red)
05 Legacy GT Ltd
98 Esprit V8 (sold)
02 WRX (sold)
Needspeed is offline   Reply With Quote
Old 08-25-2009, 11:04 AM   #13 (permalink)
midship's Avatar
I just had this happened after a brake/clutch bleed... more fluid problem solved!
Ambrose
"If you are not where you want to be, the index is not broken, you are just slow. - 47CP"
midship is offline   Reply With Quote
