Bridgestone Potenza RE-11 on LSS Wheels?
Hello All,
I have the sport pack wheels and have been running Bridgestone Potenza RE-01Rs with great success as daily driver tires. However, as you probably know, this model tire is discontinued. For the heck of it, I just called the Tire Rack and they are completely sold out of the rear size I've been running (I missed the final clearance). I've been running these in the forum recommended sizes of Front 205/45-16 and Rear 245/40-17. So, now the question is, what next? The Potenza RE-11s are the replacement model which I'd love to try, but it looks like these tire sizes have changed a bit with regards to their tolerance for rim size? Here are the specs I found on the Bridgestone website: Sizes and Specifications You can see that for the Front 205/45-16 size, the Approved Rims spec is now 7.5-9.0 (The RE-01R spec was 6.5-7.5). I guess this is now out of the range for the LSS 6.5x16 rim, eh? And as for the Rear 245/40-17 size, the Approved Rims spec is now 8.0-9.5, which I guess is also out of the range for the LSS 7.5x17 rim? The other overall dimensions such as overall diameter and width seem to be in line with the previous RE-01Rs...but I guess these new rim specs rule out these sizes and possibly this entire tire model overall? I'm certainly no tire/wheel fitment expert, so I thought I'd post this out here to see if anybody has any thoughts and can clarify my understanding that I might be out of luck in trying the RE-11s with my sport pack wheels... Thanks in advance! |
I just bought the RE01Rs from TR on closeout. I asked them about 245s and they told me that they were out of spec for the LSS wheels so I went with the 235s....they seem fine so far.
2005 Elise - Storm Ti/Red LSS, Touring, Hardtop, StarShield, Stage II, MicroMirror, RE-01Rs 2002 Acura RSX - Maroon/Beige Stock - DD |
Mountain Road Nut
You could try the Dunlop Direzza Sport Z1 Star Spec tire. Tirerack seemed to really like them in their review, and other folks here who have used them seemed to like them. Your front tires will have to be upsized to 205, but that apparently is okay.
Dunlop Launches a New Star in Extreme Performance Summer Tires |
Cone Magnet
I'd guess the 205/245 should still work in the RE-11 check the section and tread width and compare it to the RE-01R.
Or just run the Star Specs, I really like them and they seem to be as fast or faster than the RE-01Rs in my experience.
06 Canyon Red Elise LSS, Touring, SS, Stg 2, HID, BWR swaybar 09 Mini Cooper S 6MT 2000 Grand Prix White S2000 |
I've checked the section/width and that seems fine, but that's not the issue behind my original post. The issue as described in my original post is with Rim size specifications. Based on new rim specs of the RE-11s, it seems that the LSS rims won't work with this new line of tire.
Based on this, I've definitely started looking at the Star Specs! |
Rotary Refugee
I already bought a set of RE-11's and they will go on either this week or next. I am doing a full suspension setup at the same time. I bought the 205/45-16 and 235/40-17 and have the LSS wheels. I will take pictures and let you know how they work out.
#9 (permalink) |
Head LOONY
Any update on using the RE11's in the size you are speaking about.
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#10 (permalink) |
Rotary Refugee
Short answer. Awesome. Grips well, little fade, sticky, minimal road noise, and good ride charecteristics. They are suited well to my new kw suspension (which did go on at the same time). I have three track days and a handful of canyon drives.
I will try to take some pictures. So far I have settled on 25/28 hot tire temps which seem to work well. |
#11 (permalink) | |
heh heh
Did you get any pics yet? What are your cold tire pressures? D |
#12 (permalink) |
06 S280
Would be interesting to see if the RE-11s are better on track than the RE-01Rs were. All I can say is the RE-01Rs were absolutely horrible on track. Now for the street they are awesome, especially in the rain. They just got real greasy on me on the track in the summertime. I suspect I just got way out of their heat range.
#13 (permalink) |
My car is really small
I have this exact size on my rear lss wheels with no issues. My front reo1s looked brand new so I have different tires front to back and I figured the re11s should be close. My inititall impression was that I liked the reo1s a bit better because I think they felt a bit stiffer and more responsive. It may be just due to the fact that they had almost no tread left to squirm. Grip and wet weather performance is excellent of course.
05 Safron Yellow "bumbleBee" A terrible car, but a great toy 02 mazda protge 5 "shagginwagin" 84 930 turbo "no nickname yet" |
#14 (permalink) | |
#15 (permalink) | |
I have 2 brand new sets of RE-01R rears and need a front pair to match, so I was thinking of mating them with a front set of RE-11 |
#16 (permalink) |
Its really hard to judge, as I haven had a chance to autocross on them. My initial impression is that the grip is similar between the two but the reo1s seem to have a little stiffer sidewall. The front end of the elise is so light that I dsont think it is an issue at all. There has been alot said about the ills of mismatching tires, and I think there is some truth in the conventional wisdom. However the front and back of an elise is so different in terms of loading that the tires may as well be on a different car. I dont think there is any issues with mixing them. The worst case scenario is they respond to heat a bit differently on a track, but I dont think this is a big deal....
#17 (permalink) | |
Zzzzzzz
Thanks |
#18 (permalink) | |
RE01R
They have never been tracked or autocrossed. They look almost brand new. Thy are mounted on OEM black wheels from 2007 Exige S which are also for sale. I went to 17's all around. Let me know if you are interested. Bryan |
