Old 11-02-2009, 05:34 PM   #1 (permalink)
Broken Wheel Bolt Adapter
Just snapped the tool that comes with the car to remove the wheel bolts. Think it's called a "wheel bolt adapter." It's the standard one, not a specific lock pattern. 10 splines. Is this some kind of standard thing that I can buy at Sears, or is a Lotus only piece? Please let me now as I have a track day at Infineon on Friday.
ddurham is offline   Reply With Quote
Old 11-02-2009, 05:42 PM   #2 (permalink)
tesprit's Avatar
It is a Lotus only piece. The good news is they are only about $10-15 from your local dealer.
Old 11-03-2009, 05:10 AM   #3 (permalink)
Project Nirvana Elise
shinoo's Avatar
This has happened quite a bit with the locking key as well. The only reason to stick with these is if security is an issue for you. Otherwise we have a great wheel stud option for you to consider...BULLETstud
Makes wheel changes much easier.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 11-04-2009, 05:19 PM   #4 (permalink)
New Problem
Got a new tool from Lotus but I still can't get one of the wheel bolts off. Tried an impact wrench. No go. If I use the breaker bar I'll just break the tool again. Any ideas (other then welding a nut onto the factory wheel bolt)?
Old 11-04-2009, 09:24 PM   #5 (permalink)
Frank Amoroso's Avatar
Ugh, that's rough. I'd try some penetrating lubricant (from the front and the rear... Oy! Such double entendre opportunities!), then I'd get on the brakes hard enough to put a fair amount of heat into the hub / lugs. I bet she breaks free. Shoot, the heat alone may get you there. Good luck.
Frank Amoroso
Whatever Press Vehicle(s) I'm driving this week
www.twitter.com/famoroso
Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it?
Frank Amoroso is offline   Reply With Quote
