Form and Function
Caster alignment
Just did a a laser alignment and my caster is about 1 degree different....how is this fixed?
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
Yes, check those shims/washers...
My Elise came from the factory with the shim/washer fore on one side and aft on the other side. My mechanic noticed the caster being off and figured it out. Now its balanced. I guess this kind of things happen w/ hand built cars. I also found a socket stuck to my speaker magnate... a little gift from Lotus.
#4 (permalink) | |
Can has Elise!
2005 Lotus Elise - storm titanium, touring old cars: 2004 Corvette Z06, 2005 Honda S2000, 2000 Toyota MR2 Spyder, 1997 Pontiac Trans Am, 1995 Camaro Z28 (cammed and modded for 340rwhp). Miss them slightly, but they've all guided me to the Elise. |
User, Registered
There are removable shims near the upper ball joint that set camber (at 7 in this picture). The ones for caster are at each of the upper arm mounting bolts, fore and aft (24 and 29). Shim(s) are removed from one end (say, the front) and placed at the other end to move the upper ball joint fore and aft.
#6 (permalink) | |
Can has Elise!
Ahhh, I wasn't aware of those shims. Thanks! The diagaram helps a bunch. How hard is it to get to these shims by hand? I've been contemplating increasing caster, I've been seeking a firmer/more weighted steering feel..
#7 (permalink) |
User, Registered
Moving the big shims is relatively easy, but there are some tiny washer spacers that are a complete pain in the *ss to get back in there and lined up with the bolts.
#8 (permalink) |
ΒÄŅNED
How tough is it to remove bolt #29 (red arrow below)? It looks like the rack boot/steering tie rod would interfere with backing it out enough to move the washers around...
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 07-10-2009 at 02:12 PM. |
#9 (permalink) |
User, Registered
I popped the outer tie rod and swung the steering link back and out of the way. Once I did that it was easy to get the bolt out. I forget, but I may have turned the steering a bit too.
#10 (permalink) |
ΒÄŅNED
Yup, I kind of figured you'd have to do that... thanks!
#11 (permalink) | |
ΒÄŅNED
Pic 1: Measuring the caster... Pic 2: Washers in position for maximum caster
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 08-23-2009 at 12:10 AM. |
#12 (permalink) |
User, Registered
Out of curiosity, how much caster did you get?
If I have to do it again I'll try the rubber cement trick. I forgot to mention I made a pointed bolt to center the washers once they were nearly in place.
#13 (permalink) |
ΒÄŅNED
Well, it's interesting that the two sides were not set symmetrically from the factory... the left side was 0/4 (0 washers ahead of bushing/4 washers behind) and the right side was 1/3. I measured the starting caster as 3.4º left and 3.2º right. After setting the caster both sides' washers are 3/1, and the caster I measured was 4.6º left and 4.0º right. The manual says 0.4º of caster change per washer... which seems to be accurate.
#14 (permalink) | |
User, Registered
#15 (permalink) |
ΒÄŅNED
Yes... I was wondering whether I'd notice the asymmetry; it feels fine so far. Haven't taken it on the freeway yet though. I'm going to do another measurement of caster after put a few more miles on the car. The factory spec is 0.35º difference side/side...
#16 (permalink) |
User, Registered
If it drives OK, if it were me I'd leave it alone. A little more caster won't hurt anything.
#17 (permalink) | |
ΒÄŅNED
#18 (permalink) |
Castor Effects
You probably already did this but don't forget to reset the toe. Changing the castor changes the toe.
Ardent Red, Biscut, Sport, Touring, Starshield, DA Ohlins, Adjustable front bar, 888's, stainless brake lines, Pagids, Sport ECU, Stage 1 exhaust, Cup Car Airbox, HIDs, Lotus driving lights, mini-mirror, LETSLA shifter, locking gas cap, painted engine covers, inprogress |
#19 (permalink) | |
ΒÄŅNED
You're right, and I will... I wanted to finalize the caster setting first.
