The rear shocks on my '06 Exige with track pack were replaced under warranty. The dealer also had the car realigned and corner balanced as part of the service. My question is around the corner balance. This shop stated it was more important to have the front tires evenly weighted than cross weights even. This is different than I've heard previously. Should I be concerned?
Mixed use but most important for track use, most fun with driver only but regularly have passengers/students. Measured Corner Weights w/ driver LF 423 RF 422 LR 715 RR 616 Measured Weight Distribution Total Weight 2176 Front-to-Rear Front 845 38.83 % Rear 1331 61.17 % Side-to-Side Left 1138 52.30 % Right 1038 47.70 % Diagonal Weight Left Front / Right Rear 1039 Right Front / Left Rear 1137
Peter Fanning 2008 Persian Blue Exige S240 - track, touring ![]() 2006 CO Exige - RIP
#2 (permalink) | |
ΒÄŅNED
Of course, it matters a bit whether the car is ballasted for one or two occupants... (was it ballasted properly?) EDIT: Did they measure ride height, by the way? I usually measure/set ride height first, then corner balance...
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 12-12-2008 at 09:50 AM. |
#3 (permalink) | |
The diagonal is the issue I'm concerned about.
registered nipple
you want your cross weights to be %50 or really close+-1% to that, with you sitting in the car, and gas level at about the average of when you are tracking it.
also set your tire psi where you set them at the track. if you know the hot temps on track thats best also. make them redo it correctly.
2008-2009 SCCA AZ Regional "Driver of the Year" 1986 Swift DB-1 Sold 2008 HSR-West FF 3rd generation Champion 2008 "The Series" FF 3rd generation Champion 1987 Porsche Spec 944 2008-2009 season SCCA AZ regional Champion |
#5 (permalink) | |
ΒÄŅNED
My '07 S is a bit heavier than your '06, but here are my corner weights: LF: 467# RF: 442# LR: 715# RR: 682# Cross: 1157/2306 = 50.17%
My cross weights are off about that much, it is a problem. It oversteers in tight right handers and understeers in tight left handers.
Click links to see my 2008 Lotus Exige-S 240 , '99 M3, 505rwhp '89 Mustang (
sold) , '05 WRX STI ( sold) homepages or here for my M3 vid (11MB) |
#7 (permalink) | |
registered nipple
I wonder what other great things they have done to your car to "improve it".
#8 (permalink) | |
I talked to the owner, he's certain this will work well so I'll give it a try. I asked specifically about the cross weight effect on left vs. right turns. He claimed that's more a function of the alignment than corner balance. Not sure I believe him. At least worth the experiment. Worst case I take to my preferred shop and pay for an alignment/corner balance.
