#41 (permalink) |
Lotus Sales
Hey Meat,
I'm right there or pehaps a bit lower when applying my butt in the car........... I have uprated uprights, toe links, bushings and my new Nitron Race suspension and what ever else I could do. I have the new Aluminum rear uprights from Geary...........The quality is superb!!!!!
Good judgement is based upon experience. Experience is based upon BAD JUDGEMENT!!! Mark Starr 914 217-4817 |
#42 (permalink) | |
BTW...if you get a chance do a crack test on some of the take-off bits...magnaflux or whatnot. |
#43 (permalink) | |
[b]* V E R I T A S * A E Q U I T A S *[/b] We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. Over 500hp. Track weapon. 2009 Rossion Q1. [color=orange]Monaco Orange. [/color]Wing. Black leather/Alcantara with orange stitching. The street car. In build: 2009 Toniq R (300whp? 1100 pounds?). [color=orange]Chrome Orange. [/color] Lexus GX-470 tow vehicle. [color=blue]“Busy at times off the forum and *scary* actually off the Internets. So I may not see your pm or emails for a while"[/color] |
#44 (permalink) | |
Team Fiscal Irresponsible
'05 Arctic Silver/Ruby Red - Touring/SS/HT |
#45 (permalink) | |
Dremel with cutoff disks? Air die grinder with some cylindrical carbide bits? They look to be welded in there pretty well, they don't look like small spot welds that will just chisel off easily. That's not going to be easy... ![]()
#46 (permalink) |
No way to get a cut off disk in there. I think the max size tool would be about 1/8" diameter.
#47 (permalink) | |
It would be even hard to fit a die grinder bit in there...Maybe it is only welded on the side and a chisel would work to cut the welds. It looks like it's filled/radiused all around the nuts, but maybe that's just the galvanized coating filling in around the nut. In any case, I wish you luck. Is it welded in your car because it's an early car? Later cars weren't welded? In which case, it another "feature" of the early cars...
#49 (permalink) | |
V Not my picture V
How good do the welds look? I made this out of cardboard so it might make sense when I describe it. If you remove the two existing bolts. Then make a metal bracket with 3 holes in it (the cardboard in my pic) then, from the bottom, run the two outside into the welded nuts. Finally, using the center bolt, tighten it, maybe the two nuts will 'pop'. If the welds are high quality, the bracket would probably bend before the nuts break off. OK, everyone can laugh at me now.....I can take it. ![]() |
#50 (permalink) |
Is this the redesign of the redesign of the original? If not, I think it's around $600. Good to know the one pictured is of the original design.
#51 (permalink) |
The new "production" track brace coming in on track pack cars is lighter, simpler and cheaper than the first version. I think that the first version may have come out of a different part of the company, Lotus Sport, but I'd have to check on that.
From the horse's mouth the new brace is a simple steel tube with a hole drilled through each flattened-out end. So the bolts that goes through the accompanying new rod ends would also pass through one end of the track brace. The feeling is that the stock bits are fine for A048 tires it seems. But if you go gummier, then you should add the brace. Adams seemed to indicate that, for autocross, the brace was not really necessary, even on Hoosiers, not sure about Goodyear "real slicks". Must be a time duration thing as autocross is so brief compared to a series of 20-30 minute runs at a track day? |
#52 (permalink) |
Does anyone know the part number for the rear brace kit? I've searched but can't find it anywhere
2007 Exige S Krypton Green: 2ubular/FF RaceHeader/Penskes/Hypercoils/H20 injection 2006 Corvette Z06: Road Course 2007 Porsche 997 TT: Daily 2004 STi: project car #2 1994 Supra Turbo: project car #1 |
#53 (permalink) | |
Anyone?
#55 (permalink) | |
And then be covered by corporate liability insurance. ![]()
#56 (permalink) |
Lotus Sales
The Lotus part number is LOTAC05377..............List price is $671.15.........We have them in stock.........
#57 (permalink) | |
#58 (permalink) |
So I assume this part number is for the updated lighter version?
#59 (permalink) |
Lotus Sales
That is for the old part but I have to see if there will be a new part number. I will advise. I have a call in already.......
#60 (permalink) | |
The new brace may just be a tube flattened at each end, but I bet it attaches to the chassis in the middle somewhere...
