#101 (permalink) | |
Yes. Yes. We put the bar on and set the rods to the same distance they were before. We had over 2" of total toe out in the rear. You will just need the rear toe aligned.
#102 (permalink) | ||
As for the polished parts, etc.; I agree, I don't need that on my "hidden" parts. The way that the new brace attaches to the toe links/heim joints should be plenty strong - it would be nice if they had left the chassis bracket in the middle there though... Quote:
To install the brace, you remove the original toe links from the track rods, and replace them with the new ones. Since these are what you use to adjust the "steering angle" of the rear suspension - the rear toe, you need to re-align the rear (at least)...
#103 (permalink) |
Mark,
Thanks for the info, however, my 2006 Elise Sport does not have the track pack set up. It has Ohlins with remote reservoirs in both the front and back to adjust compression damping. The rebound damping is adjusted with a collar similar to the track pack you described. So, I have two adjusters on each corner. There are no markings on any of them....just knobs to turn. The car was set up with all 8 adjustments fully counterclockwise (softest setting). I recently adjusted each knob one full turn clockwise and the result was much better handling (no wobble in hard turns on entrance ramps) with very little deterioration in ride quality. I could use some advice on the best way to set up my type of shocks....other wise it's going to be a lot of trial and error. Thanks in advance. Lou |
#104 (permalink) |
Thread unraveler
FWIW all, there was a update issued by Lotus about a month ago where the torque on the toe link lock nuts was increased from 50 to 60 Nm. (37 to 44 lb-ft.)
2007 Cross Country Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#105 (permalink) | |
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
#106 (permalink) | |
http://www.penskeshocks.com/technica.htm download the adjustable damper .pdf and read page 16,17 Then read the Ohlins .pdf of the ST44 shocks http://www.ohlins.com/Automotive/Man...7/Default.aspx page 6
2007 Calclub SCCA Regional Solo Champion SS 2006 Elise BRG Trackpack LSD for 2007 2006 Calclub SCCA Regional Solo Champion SK1 |
#107 (permalink) |
Keep it simple and real
No, normal ride height is 130mm and recommended track height is 120mm...as stated in the manual. My '06 Exige came delivered with Track Pack and a 130mm ride height (barely cleays my driveway) out of the box.
#108 (permalink) | |
Shock adjustment
#109 (permalink) | |
Thread unraveler
#110 (permalink) | |
Thread unraveler
#111 (permalink) | |
#112 (permalink) | |
Jack '07 Exige Cup 255 '08 2-Eleven Track videos ... http://www.youtube.com/jackcup |
#113 (permalink) | |
#114 (permalink) | |
Thread unraveler
One thing he did caution me about.... the Lotus lock nuts aren't intended to be removed. The hole in the nut isn't a circle, but a slight oval. If you remove it too many times, you run the risk of it not locking very well as it may become more circular with the added wear. But I suppose that's where the sector111 nord locks would come in handy.
#115 (permalink) | |
#116 (permalink) | |
Rear Link Torque spec
rod link ends, only to counter mis-info he had given. Hope that helps. Cheers, Don.
'' I always tell my students to follow their bliss- where the deep sense of being is from, and where your body and soul want to go''. Joseph Campell |
#117 (permalink) | |
I don't know how I missed that. You actually posted it 4 times in a row not 3.
#118 (permalink) | |
Sorry I missed Lime Rock today... something came up. Cheers, Don.
#120 (permalink) | |
