Old 02-23-2008, 07:06 AM   #1 (permalink)
zoltiz's Avatar
Front wheels don't rotate freely when car is raised
I had the car on stands several times recently and noticed that front wheels don't spin for more than half a revolution when up in the air. Pads are relatively new, but I'm still a bit worried that caliper cylinder is not letting go enough.
Think I should get it checked out, maybe clean the caliper? Both front wheels do it. Car has 18K miles on it, pads have around 1500 miles on them, half of it just highway cruising, though.
'05 Storm Titanium Elise | sport | touring | hardtop | larini se | cup car airbox
'08 Deep Sea Metallic BMW 550i | //M-Sport | premium | nav
zoltiz is offline   Reply With Quote
Old 02-23-2008, 07:34 AM   #2 (permalink)
-30-
ace10's Avatar
Images: 33
frequently reported, possibly normal.
investigate further by searching:
brake* drag*
[SIZE="2"]2007 Exige S, Storm Ti. Sport, Track and TC.[/SIZE][SIZE="1"]Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.[/SIZE]
[SIZE="4"][/SIZE]
[SIZE="1"]08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C[/SIZE]
[URL="http://www.lotustalk.com/forums/search.php"]The Red Pill[/URL] :wave: [URL="http://www.lotustalk.com/forums/profile.php?do=addlist&userlist=ignore&u=5868"]Ignore Me[/URL] :up: [SIZE="1"]*Be sure too save your IL before browsing away[/SIZE]
ace10 is offline   Reply With Quote
Old 02-23-2008, 09:02 AM   #3 (permalink)
KMG365
I was told by Allan from LBH, that the pistons get clogged with brake dust. This prevents the piston from fully retracting. I have this problem and am going to clean the boots out today and see if it helps.
Never Lift....
jordantii is offline   Reply With Quote
Old 02-23-2008, 03:05 PM   #4 (permalink)
R T
Registered Loser
R T's Avatar
on mine, the pads were hung up in the caliper
R T is offline   Reply With Quote
Old 02-23-2008, 06:29 PM   #5 (permalink)
KMG365
What do you mean "hung up"? Like they were stuck to the pistons? I cleaned mine today and it is a little better but not totally free.
Never Lift....
Old 02-23-2008, 09:18 PM   #6 (permalink)
Graphite Bruce
Graphite Bruce's Avatar
Brake drag is normal, says Rob at Dietdchwerks.
05 Elise, sport pack, touring, graphite
Graphite Bruce is offline   Reply With Quote
Old 02-23-2008, 10:47 PM   #7 (permalink)
R T
Registered Loser
R T's Avatar
No, like they don't slide smoothly away from the rotor because the edges of the pad backing plate that touch the caliper (not the piston) get "hung up" on the calipers where the pad backing plates are supposed to slide against the caliper (not the piston).
Old 02-24-2008, 01:03 AM   #8 (permalink)
Mountain Road Nut
ChrisH's Avatar
A bit of brake drag is normal for the Elise. I even checked with the dealer on this. There is no spring to push the pads away from the disk - just a release of pressure. Hence, they drag slightly. If the pads did fully retract, then you would have to push the brake pedal even further than you do know to engage the brakes.
I have even seen it on other car types (Hondas, BMWs, ...) at autocrosses when one is cornering hard enough for a wheel to lift. The wheel quickly stops spinning.
Old 02-24-2008, 02:42 AM   #9 (permalink)
KMG365
Gotcha. Thanks. I cleaned all of the surfaces and it is a bit better.
Never Lift....
Old 02-24-2008, 05:56 AM   #10 (permalink)
Elise Fondler
cerven's Avatar
I use WD-40 on the pads - no brake squeel and wheels turn faster
Eschew Obfuscation
Got mine 03-25-05 Ardent /biscuit /touring /3M / hard top
cerven is offline   Reply With Quote
Old 02-24-2008, 07:50 AM   #11 (permalink)
jallingt's Avatar
+1 for the brake drag when the wheels are off the ground.
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles)
2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars)
2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator)
Couple nice bicycles, way too many snow skis.
jallingt is offline   Reply With Quote
Old 02-24-2008, 08:06 AM   #12 (permalink)
R T
Registered Loser
R T's Avatar
Jordan, I actually grease those contact point lightly.
Old 02-24-2008, 08:10 AM   #13 (permalink)
できそこないの傲慢嫌い
carlover's Avatar
Check the VIN of the Lotus you're considering buying
http://www.lotustalk.com/forums/f3/h...hl30039-66280/
carlover is offline   Reply With Quote
Old 02-24-2008, 12:21 PM   #14 (permalink)
KMG365
I was going to but I wanted to see if it was just a build up of dust. I will grease them next time. Thanks for the info.
Never Lift....
Old 02-24-2008, 05:39 PM   #15 (permalink)
R T
Registered Loser
R T's Avatar
In fact, for the stock pads, I had to file the edge down a little to get rid of the nasty edge of the backing plate "burnout" where it contacts the caliper.
For the price on those pads you'd hope for at least a Plasma cut backing plate as a min ...... but hey, do what you gotta do
