Computer Nerd
Hand Brake Stuck Upright. Help Needed (pics)
Last night when I got home and parked I went to pull the ebrake and I heard a small noise as it was going up. So I pressed the button and tried releasing the brake and it wouldn't go back down. Then I tried pulling it up another notch before letting it go back down and that didn't work either. It would only go up so now my brake handle is as far up as it goes.
![]() I found the piece that fell out which I assume was the noise I heard. I don't know what the hell to do. I tried using a hammer and hitting it and that didn't fix anything. The piece that fell out can't go back in unless (I'm assuming) the brake is all the way down. What else can I try?
'05 Elise Starlight Black + Sport Pack on Red Leather Exige Grills | Arqray Single Tip Titanium | Rear Panel Eliminator | LIR Racing CF Side Scoops | raceVIEW CF Mirrors | Zoom CF Mirror | HIDs | 4.5lb battery | Sector111 Bootie | No Carpets or Sound Deadening Foam | Sector111 4Tress Bar w/ EZMount | reENFORCER | SS Brake Lines | Green Filter & Desnorkeled |
Brembo Resize & Repair
Call the dealer and find which is the least expensive brake cable section to cut and release the parking brake.
Alternatively, unscrew a bolt holding the parking brake lever arm from the caliper and wiggle the arm off, which should release the pulling on the cable. The arm has a torx-shaped mounting hole. If you unscrew the bolt, take a look at the caliper to see which side of the car allows you to retighten the bolt and have the arm rest against the caliper body near where the cable sheath comes through the casting. One side will not - you would be tightening the bolt away from the caliper. There are smaller parts inside the caliper to enact the parking brake self-adjusting feature which cannot hold back the torque of tightening this bolt. I would be more helpful as to which side, except that I am familiar with Vipers (that have these calipers) and believe that on the Elise the calipers are "upside down" on the other side. |
Computer Nerd
Both of those sound too tough for me right now. If I cut the cable are my brakes gonna be affected at all? And when it snaps is it gonna fling around and slice stuff because it's under tension?
Did you try using a large screw driver and pry the ratcheting lock out since that seems to be what the brake is stuck on since you lifted it beyond the last locking tooth?
225 TTQC & 05 Elise |
take undertray off and loosen the cable then see if you can pull the ratchet part outwards so that its on the teeth. You will prob. need a new partt hat fell out
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror |
Director of Engineering
Location: I live in Glen Ellyn IL, a suburb of Chicago.
Looks like the rivet pivot. I doubt you will be able to get the ratchet to release and the handle to stay in position without getting the cable tension released first. As for replacing the rivet, that may be difficult without removing the handle assembly. I have not seen this happen in one of these before so I do not have any experience fixing this. Your best bet may be to get the parking brake cable released and taking it to a dealer. Good luck.
#7 (permalink) |
it appears from the parts manual you will need the parking brake assembly which includes the broken piece.
Lotus Garage - Parking Brake Mechanism
#8 (permalink) | |
When cutting, it will snap. You can stuff rags around the cable where you cut it so that it will only pull back rather than whip around. The distance the cut end will travel is only an inch or two; you can estimate this by looking at the brake lever arm on the caliper- it can only rotate a small amount. The cable will also unstretch. I like the screwdriver unhooking the ratchet idea. You might have to pull up on the handle once again to be able to get the teeth disengaged. |
#9 (permalink) | |
If you cannot dislodge the ratcheting mechanism lock via screwdriver, then take off bottom panels, and find where two sections of brake cable meet...there should be adjustment there (which will allow you to take them apart.) release tension. then you should be able to remove the E brake assembly, and take a look @ it in a more open environment. Based on that lotus garage diagram, you may be able to remove the bolt from either end of the first cable (either @ the brake lever, or at the u shaped distribution part. I would avoid cutting anything. If a hacksaw is the answer then you're asking the wrong question.
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent |
#10 (permalink) |
remover undertray, loosen e-brake tension adjuster, that should allow you to pull the e-brake mechanism from the car. Looks like the rivet is probably for an internal pivot point and you may be able to replace the rivet with a through bolt pur it back in and have it tack welded. Don't cut anythign or you will be buying still more parts.
it will take some time, but should be fixable inexpensively if the rivet will tack weld in place |
#11 (permalink) | |
User Restricted By ΑDMIΝ
Here's what you need to loosen:
#12 (permalink) |
Whatever method you choose, make sure you block the wheels with wheel chokes so the car won't go rolling backward
'08 Honda S2000 CR (Rio Yellow Pearl) '07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '04 BMW 330 ci (White) |
#13 (permalink) |
Computer Nerd
Ok I'm gonna try this out when I get home tonight. I'll get under there and loosen that "parking brake cable adjuster" nut that I see in that most recent picture. Now what about the rivet that came off? Can I just throw a nut & bolt in there in the mean time? I don't weld.
#14 (permalink) |
fm78.tv - check it.
If it's been longer than 4 hours, I say call a doctor.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#15 (permalink) |
G-200 Driver
I don't think I've ever USED my parking brake
#16 (permalink) |
McLareghini Bugatterrari
I use mine when I'm changing wheels and forget to slightly loosen the lug nuts before I lift the car.
xtn
#17 (permalink) |
really? I use mine everytime I park. (Except after an autox run. I just leave it in gear there.)
that's time to goto the ER. and prepare for big ol needles going places you don't want them to. You'll want diprivan.
#18 (permalink) |
Computer Nerd
Well I fixed it with the help of my neighbor. We pulled those two silver bolts on the side so we could lift the handle as well as the thing with the teeth on it. Apparently there was a part that was pinched so were loosened it up with a screwdriver and sprayed some WD40 in there to get them apart from each other. After that we lined up the holes, popped the rivet back in and then put those last 2 bolts on. I had to take the drivers seat out to get to one of the bolts though.
Anyway, I'm gonna end up going to a hardware store and replacing that rivet with a nut & bolt because it feels a bit loose the way it is. I don't want to have to do it all over again.
