Old 08-30-2009, 02:33 PM   #1 (permalink)
txdude's Avatar
Help: Wheel Removal/Stuck
This is ridiculous. I've changed dozens of tires on previous vehicles but the Elise is giving me issues...
I've removed all 4 lugs, used wd-40, and gently tapped her with a rubber mallet but she won't budge even the slightest bit. I've never touched the wheels on my Elise before, so I ask... Is there a special locking pin or something that needs to be removed? Or do I just need to get rough with her and pull really hard? It's the front wheels.
Thanks y'all. I searched the forum with no luck, but feel free to direct me to the right thread if there is one.
txdude is offline   Reply With Quote
Old 08-30-2009, 02:42 PM   #2 (permalink)
perfututum futūtor
RoadDad's Avatar
No pin. Just the 4 nuts. Well, 5 nuts actually in your case - the 4 wheel nuts and you (I'm just kidding!).
WD-40 is a "water displacer". That is what the WD stands for. It is not a penetrating lubricant such as PB Blaster or Kroil.
If you have all of the lugs off you just need to pull/tap harder with the mallet/use a penetrating lubricant (but be careful where it gets) to get it loose, as there is no other retaining item.
If you are pulling or "tapping", please be careful that you don't pull or "tap" hard enough to dislodge your car from the jack stand that it is on.
Me... I don't need to.
Bite me." -Randy
Old 08-30-2009, 02:50 PM   #3 (permalink)
JLSELISE's Avatar
Don't be timid!
If it's really on there, some sharp blows with a rubber mallet (on the backside edge of the wheel) will be required--alternating "hits" on diagonals at 90 degrees would probably be a good idea, too.
Joel
'67 S3 Elan dhc (owned since 1970)
'06 Audi A3 3.2
'04 Noble M12 (380 rwhp)
JLSELISE is offline   Reply With Quote
Old 08-30-2009, 02:54 PM   #4 (permalink)
txdude's Avatar
Thanks y'all. I kind of figured so, but I didn't want to start another thread about how I caused some major damage doing something so easy lol.
Old 08-30-2009, 02:57 PM   #5 (permalink)
txdude's Avatar
The wheel has been conquered!
Old 08-30-2009, 03:01 PM   #6 (permalink)
perfututum futūtor
RoadDad's Avatar
You are now a man.
Bite me." -Randy
Old 08-30-2009, 03:02 PM   #7 (permalink)
DeanG's Avatar
The M100 has the same wheel removal issues. The problem is caused by the wheel being located via its center. A snug fit on between the center whole on the wheel and the hub can become very snug with a bit of corrosion.
DeanG is offline   Reply With Quote
Old 08-30-2009, 03:08 PM   #8 (permalink)
perfututum futūtor
RoadDad's Avatar
This is why some folks use anti-seize on the mating surface of the wheel to the hub (NOT on the lugs).
Bite me." -Randy
Old 08-31-2009, 10:26 AM   #9 (permalink)
TimMullen's Avatar
Images: 19
+! Always...
94 Miata R Package - Black
