Old 02-28-2005, 01:12 PM   #1 (permalink)
No more cone damage!
Surferjer's Avatar
Hoosier A3S04 tire pressures??
The Tire Rack is shipping a set of Hoosiers to me as we speak, to be mounted on new SSRs. I did a thread search, but found nothing definitive on tire pressures for these tires. It appears that in hot conditions Randy and Robert started in the low 40s and ended up at 46 lbs at one meet. Others suggested pressures much lower. Does anyone have any experience (other than the one meet in SD in August) in setting pressure?
Also, if I remember correctly, that meet was before we started removing shims to improve negative camber in the front. Any results from AFTER that?
Lastly, it will still be cool here (50-55 degrees?) when I run for the 1st time on them, March 19th or 20th. What does the effect of cold weather/pavement mean to Hoosiers in terms of pressure? Thanks for all your help. I will certainly post my results after the fact.
1993 MR2 autox car
Surferjer is online now   Reply With Quote
Old 02-28-2005, 04:31 PM   #2 (permalink)
Tire care tips
Vehicle size: 1800-2200 lbs.
Recommended Hot Pressure: 39-42 psi
Cold Pressure: 30-36 psi
See the following information for the tires:
https://www.hoosiertire.com/rrtire.htm Go to tire information.
I found the information to be spot on. You need alot of pressure upfront to keep the outside edges from prematurely wearing. I have the R3S04 on my Z06 and run hot F- 46 psi and R- 39 psi. Very neutral and wear is fine. But I have -2 deg front camber and -1.5 rear. My information is with the R not the A though.
Give Jeff Spear at Hoosier a call. He knows his stuff.
2005 Lotus Elise, Magnetic Blue with blue leather, Touring, Hard Top, Starshield, SS brake lines, #635 (sold 9/8/05)
Cisitalia is offline   Reply With Quote
Old 02-28-2005, 04:54 PM   #3 (permalink)
eliseowner2b's Avatar
Surferjer,
You lucky bugger. Man that is gonna stick!
It appears Cisitalia closed out this thread in one lick!
Please let us know how things work out with these tires. It looks like I may be selling the car that was holding me back from buying a towing vehicle and featherlite so I may be going the hoosier way sooner than I thought.
Dan Parker
92 BMW 325 - JP Race Car
09 Jetta Tdi
06 Z4 M Coupe
09 Child on the way (anyone need a car?)
eliseowner2b is offline   Reply With Quote
Old 02-28-2005, 05:00 PM   #4 (permalink)
Surferjer's Avatar
I feel lucky. Got a terrific trailer, and I'm looking forward to running this season with the proper shoes on my Elise. And I decided to splurge and get another set of SSRs so I can run the AO48s on SSRs during class time in April, then pull out the Hoosiers and switch for meets. At this point my equipment is far, far ahead of my abilities. Guess I better go to class and get lots of practice.
1993 MR2 autox car
Old 03-01-2005, 04:08 AM   #5 (permalink)
Surferjer's Avatar
Hmmm, okay. no one else really commented on the weather aspect. At least with a trailer I can choose my weapon when I get there (AD07s ,AO48s, or Hoosiers). Yep, if it's raining I may go with the AD07s. I'm not sure they aren't a better tire for a rainy, slick track...
Edit: actually if there's enough time between runs, I could switch tires during the competition and see what works best. I could probably switch and retorque in 10 minutes. Might be fun to compare/contrast at cooler temps.
1993 MR2 autox car
Old 03-01-2005, 06:44 AM   #6 (permalink)
jer,
That is wise to have options and switch tires. A trailer opens many endless other opportunities. I have used the Hoosiers to great advantage on 50 degree days. I would still not hessitate to use them in 50 deg weather for a track day. They just take longer to warm up.
How do you autocross guys warm up your tires when you have a standing start? Electrical blanket warmers?
Old 03-01-2005, 07:02 AM   #7 (permalink)
Surferjer's Avatar
Some guys have tire warmers. I don't have any yet, and I've already spent a lot more than I probably should have. And a stiffer sway bar (why do they call it a track bar in NASCAR?) and Ohlins are higher on the priority list that tire warmers anyway.
Probably the most popular way to warm up tires is to have a co-driver. Maybe I'll snag my son from college for the weekend. Otherwise you just go cold and hope for the best.
1993 MR2 autox car
Old 03-01-2005, 08:15 AM   #8 (permalink)
Evl
His Impatientness
Evl's Avatar
Jer, I think a track bar and an anti-sway bar are two different things. I'm pretty sure a track bar is a lateral axle location device.
Re getting heat in the tires, you pretty much live with no grip on your first run. I think I might worry about switching tires mid race for that reason, but I'm not an expert.
www.agentsofentropy.com
Evl is offline   Reply With Quote
Old 03-01-2005, 10:17 AM   #9 (permalink)
Surferjer's Avatar
You might be right, Chris, on the bar.
On the tires that makes sense. I'm exchanging emails with Jeff Speer at Hoosier Tires right now on pressures.
1993 MR2 autox car
Old 03-01-2005, 11:53 AM   #10 (permalink)
BlkGT3's Avatar
I do not believe tire warmers, except co-drivers, are allowed under SCCA SOLO Rules. Disregard this info if another group is putting on the event and check their rules. Also all the tire warmers I am aware of are extremely Expensive. One thing on a Sunny Day Keep your tires in the sun and if possibile turn the car to heat both sides evenly.
Peter
2002 Porsche GT2 OSgiken/Moton/Rennsport Systems/Hoosier/Team Cannon Fodder
2006 SCCA T3 S2000
2007 OLOA E46M3 1st SSGT1 SB
2008 OLOA Porsche GT3 4th overall
2009 OLOA Porsche GT2 2nd overall D@@M Cones
BlkGT3 is offline   Reply With Quote
Old 03-01-2005, 11:56 AM   #11 (permalink)
Randy Chase's Avatar
Images: 761
Agreed that active tire warmers are illegal... but passive tire warmers (see blackwatchracing.com ) are legal... but will not help before that first run. Unless you get creative and store them in that motorhome with the heater set on 120 degrees.
If anyone is looking to buy Hoosiers... and can wait a little bit, I would suggest waiting until April for the new model AS305s.
Lexus GX-470 tow vehicle.
Old 03-01-2005, 12:51 PM   #12 (permalink)
A new Hoosier eh, interesting. Seems like the A3S04 just came out. I wonder if this means soon we could get A3S04's for real cheap like last summer with the A3S03's.
Also passive tire warmers dont help if your region does not run in heats. All of our local regions do a run-work-run-work type thing so the runs are like 45 minutes apart minumum.
z06fun is offline   Reply With Quote
Old 03-01-2005, 01:02 PM   #13 (permalink)
Images: 761
45 min spaced runs would really be something I hated.
I think Hoosier recognizes that the V710s are kicking their butt and they dropped the ball with a less than stellar tire this year. They have to get the next tires into the SCCA's hands in April for legality compliance for 2005.
Which reminds me, I hear the V710s for the rear of the Elise may be here soon also. Assuming they fit.
Old 03-01-2005, 01:12 PM   #14 (permalink)
Surferjer's Avatar
I'll have to suffer with the current Hoosier until I wear them out. Might last all season I suppose. Heck, maybe I should use them for the autoX school after all.
1993 MR2 autox car
Old 03-08-2005, 03:44 PM   #15 (permalink)
Interloper
John Stimson's Avatar
Originally Posted by MyElise
Hoosiers in 50 degrees?
Brrrrrrrraaaaaaaahaaaaaaa!
Don't waste the rubber...save them for 75+ degrees (track temp).
The A3S04s love the cold. They overheat and get greasy easily, sort of like a popular "street" tire we all know.
When the A3S04s came out, I loved the grip. Then I hated the premature edge wear. Now that the V710s have come out, I don't care anymore!
2005 S2000 #42as
John Stimson is offline   Reply With Quote
Old 03-09-2005, 04:58 AM   #16 (permalink)
Surferjer's Avatar
John-how many runs did you get before cording? I've heard from 30 to 60. That's a wide range. Just trying to plan when I'll have to toss these and get Kumhos.
1993 MR2 autox car
Old 03-09-2005, 08:58 AM   #17 (permalink)
One thing you can also do to help the front outter edge wear is set the front caster as high as it will go. The caster gives increased neg camber on the outside wheel when the front wheels are turned.
Old 03-09-2005, 10:23 AM   #18 (permalink)
Originally Posted by Randy Chase
...Which reminds me, I hear the V710s for the rear of the Elise may be here soon also. Assuming they fit.
Tirerack lists a 245/45-17 being available in about a month. Are you referring to that or some other size they have planned.
Starlight Black, Sport Pack, Since Oct. 04
TripleBlack_NJ is offline   Reply With Quote
Old 03-09-2005, 11:07 AM   #19 (permalink)
Images: 761
It is available as of this week. Stay tuned for a fitment test. Maybe within 24 hours. Or sooner.
Old 03-09-2005, 11:10 AM   #20 (permalink)
Images: 761
With non-maxed front camber... we had 20 runs before cording the front outside edges. With maxed out neg camber, we got over 30.
A lot depends on your driving style and the surface you run on. It can easily change that number by a large factor.
