Old 08-20-2009, 09:37 AM   #1 (permalink)
Lotus-Position's Avatar
Light weight wheel 'uprights' available?
I was replacing my rotors last weekend (DBA5000s ) and looking at all the iron hanging off the end of the control arms. Isn't there a ton of unsprung weight savings there by replacing with lighter uprights and calipers? I seem to remember a thread where someone prepping a race car shared a bespoke replacement for the uprights... but can't seem to find it.
Does anyone know a source for lightweight uprights and calipers? Is it worth it for overall weight reduction and handling? Thoughts?
Just another astroturf, evil-mongering, radical member of the right wing M.O.B. (Mainstream Opposition to Barack).
Lotus-Position is offline   Reply With Quote
Old 08-20-2009, 09:54 AM   #2 (permalink)
Enemy of the State
tandemracer's Avatar
Like these?
Elise Parts - *>**>*GT Hubs S1 (Front Pair)
06 Elise, AW, Touring, Sport, Premium, Hardtop, Starshield -- S111 Harness bar, Schroth ASM 6 point Harnesses, Seat Grommets, Front Tow Hook, Rear Tow Hook, Halon fire extinguisher, Polk speakers, MicroMirror, Odyssey PC680, ekological HID kit, Pagid RS14 pads, SS brake lines,CF Center Console, CF AC Surround, urethane motor mounts, Titanium Dave's Sub Belt Bars, Heater Core Bypass , Craftsquare Mirrors, Carbon Splitter, LETSLA, DBW Pedals, Xtender
tandemracer is offline   Reply With Quote
Old 08-20-2009, 10:02 AM   #3 (permalink)
User, Registered
fpitas's Avatar
Originally Posted by tandemracer View Post
Do those fit our model of Elise?
Francis
fpitas is online now   Reply With Quote
Old 08-20-2009, 10:58 AM   #4 (permalink)
Enemy of the State
Hmmm, those are for S1.
Here are the links for the S2 hubs:
Elise Parts - *>**>*GT Hubs S2 (Front Pair)
Elise Parts - *>**>*GT Hubs S2 ( Rear Pair )
Old 08-20-2009, 11:02 AM   #5 (permalink)
Meow!!
darkSol's Avatar
I contacted EliseParts almost 3 years ago and asked them about these...
They replied back with:
"Hi David
There are no major weight saving advantages but there are several other advantages, namely, Strength, Toe link bolt in double sheer, better wishbone angulations, they are designed to accept better and wider range of front and rear calipers, they won't rust and higher camber angles are achievable.
They are the best on the market by far, many race teams use them and to date I have had only positive feedback.
Cheers
Geary"
Hope this helps!
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 08-20-2009, 11:18 AM   #6 (permalink)
Left Lane Assasin
JungleJim's Avatar
Images: 12
Wayne, if you are concerned about unsprung weight why did you install the DBA5000(or 4000) rotors in the rear when the rear caliper does not use all the swept surface?
According to the Sector111 site, the Ultradisc rears with a larger rotor hat than the front save 3lbs per corner!!
2007 Exige-All Black and Mean, Factory TouringPak/TrackPak/StarShield/LSD/TractionControl/iPodDock. All stock but not for long.
v = square root ((2 * e) / m)
JungleJim is offline   Reply With Quote
Old 08-20-2009, 03:59 PM   #7 (permalink)
Good point, I had not put that together in my research. Was thinking I should get the same rotor "set" front and rear rather than "mix and match", but technically no real reasong to. Good to know for next time though... thanks!
Old 08-20-2009, 04:03 PM   #8 (permalink)
dmh
Republic to Thugocracy
dmh's Avatar
LP -- "Just another astroturf, evil-mongering, radical member of the right wing M.O.B. (Mainstream Opposition to Barack)."
You've got my support!
"This is the moment when we must come together to save this planet. Let us resolve that we will not leave our children a world where the oceans rise and famine spreads and terrible storms devastate our lands."
Community Organizer and Chief Obama...now intervening with natural occurrences!
dmh is online now   Reply With Quote
Old 08-20-2009, 04:06 PM   #9 (permalink)
"Hi David
Cheers
Geary"
Hope this helps!
Excellent, thanks for this info and the pointer to EliseParts. Not the hubs I had remembered from a previous thread, but I like all the other benefits even if they aren't lighter.
Old 08-20-2009, 04:25 PM   #10 (permalink)
Awesome! I was wondering when someone was going to comment on my new avitar and sig!
Old 08-20-2009, 07:07 PM   #11 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
Other than those Eliseparts uprights Pilbeam Racing Designs .. Innovation + Excellence = The Winning Formula do them for the S1 and I suspect also for the S2 - you'd need to contact them to confirm.
Aedo is offline   Reply With Quote
Old 08-25-2009, 04:24 AM   #12 (permalink)
Pilbeam Racing do uprights for both S1 and S2 and also include a drop of arround 40 mm front and 45 rear. This allows for optimium suspension geometry at very low ride heights.
Trip D is offline   Reply With Quote
Old 08-29-2009, 08:29 PM   #13 (permalink)
Project Nirvana Elise
shinoo's Avatar
Expect a new upright solution from Nitron as well. In fact we will have several new items to show at WCLM in Vegas....Guy from Nitron will be our guest and we will hold a Tech Seminar to discuss some new hardcore race focused bits...
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
