Old 07-09-2006, 09:47 PM   #1 (permalink)
bluejae's Avatar
my tires at about 2900 miles *updated* tires at 3100 miles
fronts
KG Exige Delivered 5-9-2006
POLL:check for scratches "in" your headlights
Excessive tire wear? It may be your alignment
My Example
Hiro's Example
codymac's Example
to be installed: stebel horn, fumoto valve
current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges
future mods:wheels, forced induction
bluejae is offline   Reply With Quote
Old 07-09-2006, 09:48 PM   #2 (permalink)
bluejae's Avatar
and the rears.... whats left of them anyway
My Example
Hiro's Example
codymac's Example
Old 07-09-2006, 09:48 PM   #3 (permalink)
bluejae's Avatar
1 more
My Example
Hiro's Example
codymac's Example
Old 07-09-2006, 09:50 PM   #4 (permalink)
bluejae's Avatar
would i be able to make a trip to san antonio and back on these tires?
that's about 500+ miles
My Example
Hiro's Example
codymac's Example
Old 07-09-2006, 09:56 PM   #5 (permalink)
If it doesnt rain, you should be ok IMHO
Sports cars sold:
1991 Miata
2000 S2000
1998 Viper GTS
2002 Z06
2005 Lotus Elise
taking a breather for a while so I am carless
chip is offline   Reply With Quote
Old 07-09-2006, 10:14 PM   #6 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
Good work!
Aedo is offline   Reply With Quote
Old 07-09-2006, 10:25 PM   #7 (permalink)
the obedience of fools
marcw's Avatar
Originally Posted by Aedo
Good work!
what he said!
marcw is offline   Reply With Quote
Old 07-09-2006, 10:42 PM   #8 (permalink)
bluejae's Avatar
oh yeah... this is just normal driving... no track days and no standing starts
My Example
Hiro's Example
codymac's Example
Old 07-09-2006, 10:44 PM   #9 (permalink)
Nerd on wheels
Arno's Avatar
You're running too high tire pressures. Worn only on the middle.
Bye, Arno.
Arno is offline   Reply With Quote
Old 07-09-2006, 10:44 PM   #10 (permalink)
fishguy's Avatar
Images: 1
bluejae,
the fronts look fine, the rears look like they are being(been) run overinflated. there should ideally be even tread wear on the tire accross it. i might not be seeing the picture accurately, but it does look like the center is much lower in depth than the outside. check your pressures before you drive, and also after. be safe with those banana skins in the back if it starts to rain. set them at recommended pressures but then check the wear frequently, and adjust the pressure up or down accordingly.too high makes the center as the contact patch, too low, makes the outer edges as the contact patch. if too high(which is what i see in the picture) your only using about 1/3 of your potential grip of the tires.
Josh
Old 07-09-2006, 10:51 PM   #11 (permalink)
bluejae's Avatar
thanks... that's weird... as soon as i read some threads regarding the tire pressure... i noticed mine were a little high all around... so i let them out... just barely below... i guess i need to take some more out on the rears... and yeah... the center is worn a bit...
i need to find some new tires for daily driving though...
but does it look like normal wear even if it may have been overinflated?
My Example
Hiro's Example
codymac's Example
Old 07-09-2006, 10:54 PM   #12 (permalink)
short angry bloke
codymac's Avatar
Images: 19
If you mean mileage, yes. Be sure to check your pressures hot - they gain pressure when the tires heat up.
Old 07-09-2006, 11:00 PM   #13 (permalink)
nugg_dawg's Avatar
Images: 1
I generally set mine at 24 psi front and 26psi in the rear cold.
BTW, what were you running when you said they were over inflated?
John
nugg_dawg is offline   Reply With Quote
Old 07-09-2006, 11:09 PM   #14 (permalink)
bluejae's Avatar
John
whatever was on the door sill... i think that's where i saw it... but a little less than that... but i'll set it to 26 tomorrow before i go out...
My Example
Hiro's Example
codymac's Example
Old 07-10-2006, 03:11 AM   #15 (permalink)
More track time please.
Bleu Omdurman's Avatar
Don't forget to change out your winter air for summer air.
pressures tend to shift as much as 1 psi a month in GA transition from feb to Jun.
Take my track day survey: here You should enjoy it. 10 questions.
Now take survey #2 here
Mods: TurboXS Intake, Ultra Disc Rotors, Adare Motorsports Racing Pads.
Bleu Omdurman is offline   Reply With Quote
Old 07-10-2006, 03:31 AM   #16 (permalink)
Val
Nothing
Val's Avatar
Definately over inflated.
Val is offline   Reply With Quote
Old 07-10-2006, 07:02 AM   #17 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Make all the comments you'd like - I typically gain 25% of cold pressure once the A048s are hot.
Old 07-10-2006, 07:26 AM   #18 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
Where are you driving from? What's bringing you to San Antonio? PM me if you need any info.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 07-10-2006, 08:07 AM   #19 (permalink)
bluejae's Avatar
winter air? summer air???
My Example
Hiro's Example
codymac's Example
Old 07-10-2006, 08:08 AM   #20 (permalink)
bluejae's Avatar
i had enough time this morning to check my rears real quick... i couldn't believe it... they did gain pressure... so it let it out to about 25 1/2... i haven't check the front yet... i'll do that when i get back... thanks everyone
My Example
Hiro's Example
codymac's Example
