Old 09-08-2008, 10:44 AM   #21 (permalink)
LarryB's Avatar
Count- thanks for the feedback. Is the .5 sec, when you were running the RA-1? When you factor in the lack of LSD on your car, that is very good driving, on street tires.
Craig- I've heard that about the T1R , they also go on to say after 500-1000 mile they get pretty good.
I'm running hard to find sizes on the MR2, would have been either the T1R or R1R, now that they finally release the other size I needed, it'll be the R1R.
LarryB is offline   Reply With Quote
Old 09-08-2008, 10:49 AM   #22 (permalink)
Michael_In_Hoboken's Avatar
R1R's fit LSS wheels?
Just to triple check before I pull the trigger
2005 Elise - Storm Ti/Red
LSS, Touring, Hardtop, StarShield, Stage II, MicroMirror, RE-01Rs
2002 Acura RSX - Maroon/Beige
Stock - DD
Michael_In_Hoboken is offline   Reply With Quote
Old 09-08-2008, 11:19 AM   #23 (permalink)
Yes - 0.5s comparison is Hoosiers vs RA-1s. Another thing to keep in mind is that I also ran these tires the previous day at Buttonwillow for 30 minute sessions in over 100F heat with minimal overheating issues. They were not as grippy as my nearly bald RA-1s (according to DL-1 logs) but I made up by driving better
CountTracula is offline   Reply With Quote
Old 09-08-2008, 11:20 AM   #24 (permalink)
Yes. 205/235 combo.
Old 09-23-2008, 08:15 AM   #25 (permalink)
coulthard fan's Avatar
Just a data point: I placed 3rd in a recent Redline Time Attack event with a set of R1R's on a otherwise stock Elise. They aren't as sticky as the Hankook C50s I usually use on the track, but I ran in the street tire class so I needed a treadwear rating of 140+ to compete. I think Manly out on the other coast has also won a couple of these Redline events with the same setup.
p.s. Thanks Joe at TireShoppe
Scott
Red 2005 Elise - www.tax-whistleblower.com
coulthard fan is offline   Reply With Quote
Old 11-25-2008, 03:09 PM   #26 (permalink)
Has a skinny fetish
uclacyc's Avatar
Images: 25
This is a reply to an older thread (found it using search), but does anyone know if the 205/45R16 front and 235/40R17 combo works for the R888's as well as the R1R's, for a non-sport package Elise?
Not so sure about the accuracy of the info from this other site:
PureSportsCar.com - US Lotus Tire FAQ :: Lotus Elise/Exige/Evora North America
uclacyc is offline   Reply With Quote
Old 11-25-2008, 03:19 PM   #27 (permalink)
LarryB's Avatar
By non-sport pack Elise, are you talking about the wheel sizes ? If so, even the 195/50/16 is too wide for it (LSS front sizes). Much less a 205/45/16. Stock, non-sport pack are 175/55/16 up front and 225/45/17 in back.
Old 11-25-2008, 03:42 PM   #28 (permalink)
Has a skinny fetish
uclacyc's Avatar
Images: 25
Yes, I'm talking about the wheel size. When you say even the standard 195/55R16 front 225/45R17 rear combo for a LSS package "is too wide," why does Lotus us that combo? Also isn't the tire slightly smaller since the sidewall is 45 vs. 55 (front) and 40 vs. 55 (rear)?
What people have chosen for the tire sizes for the R888's are all over the place and I can't figure out what combo works.
Old 11-25-2008, 03:53 PM   #29 (permalink)
LarryB's Avatar
The sport pack, uses a wider wheel then the stock wheels. Which is why a 195/50/16, tire is fine. However that tire size is too wide for the stock (non-sport pack) wheels.
Here is a little write up about the sizing of tires:
Tire Tech Information - Calculating Tire Dimensions
Width x Aspect Ratio = Section Height
Section Height x 2 = Combined Section Height
Combined Section Height + Wheel Diameter = Tire Diameter
Edit- both the sport and non-sport pack, use the same size rear wheels- tire sizes for both are 225/45/17.
Well, yeah physically you could fit a 195/50/16 tire to the non-sport pack front wheels. It's at the edge of what you could do, the tire would be somewhat pinched. Not ideal but suppose for street use, it ok.
Old 11-25-2008, 04:20 PM   #30 (permalink)
Has a skinny fetish
uclacyc's Avatar
Images: 25
Okay, I'm going to ask a stupid question:
Is there something mechanically that prevents putting the wider tires from a LSS package on a stock Elise? I remember it not being physically possible/desirable. I also recall that there was something with the suspension but I don't remember.
Thanks for pointing out the the rears are the same, though. I totally missed that.
Old 11-25-2008, 04:24 PM   #31 (permalink)
AR #0369
foosh's Avatar
Images: 4
No, you just need a new set of wheels to do so.
foosh is offline   Reply With Quote
Old 11-25-2008, 08:05 PM   #32 (permalink)
Images: 26
A 195/50 WILL fit the base front wheel no problem.
The 205/45….NO.
Do your self a favor and just get new wheels.
Green Ghost is offline   Reply With Quote
Old 11-26-2008, 09:36 AM   #33 (permalink)
Has a skinny fetish
uclacyc's Avatar
Images: 25
The 205/45….NO.
Ummm... yeah, that's what I'm trying to do, as I'm trying to figure out the correct size.
If the 205/45R16 doesn't fit the front, how are some people getting this to fit as stated on the first page of this thread? See posts from AdamT and jbr3rd.
Old 11-26-2008, 10:36 AM   #34 (permalink)
AR #0369
foosh's Avatar
Images: 4
Uh, Larry made this painfully clear. They will fit the LSS (sport package) wheel, which is wider than your base package wheel. The people you are referring to were not trying to put them on base wheels, but mounted them on wider LSS wheels.
So, find a set of LSS wheels or something with the same specs. Sector 111 has a wide selection.
Old 11-26-2008, 03:52 PM   #35 (permalink)
Images: 26
Just in case you don’t know this, the standard/base front wheel is 5.5 inches wide. The sport pack/track pack front wheel is 6 inches wide. (some one correct me if my # are wrong)
The 195/50 is the max you should go on a 5.5 wheel.
Look at sector 111 and Blackwatch racing for some good wheels and tire combos.
The standard 5.5 wheel sucks. The wheel looks nice, its just a phucked up size.
Old 11-29-2008, 04:15 AM   #36 (permalink)
Elise Driver
tireshoppe's Avatar
For normal driving the 195/50R16 on the front standard wheels will work fine and 225/45R17 on the rear is the same for both. If you drive very hard or use it on the track you can go to the 205/45R16 and new wheels.
Joe
tireshoppe is offline   Reply With Quote
Old 11-30-2008, 08:37 AM   #37 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Joe is there still a $100 Rebate on the purchase of four R1R's? If so how long is this going on for?
2005 Starlight Black Biscuit Interior // Hard Top // Von Hep Exhaust // Von Hep Rear Delete // Full Heat Shield Removed // Fujita CAI // Rota Torque Wheels W/ Toyo R1R's // ForceFed Carbon Fiber Splitter // Carbon Fiber Engine lid cover // LidBone // JL Audio VR525-CXi Front and Rear // Micro Mirror // Painted interior bits // Bling Buttons // Darth Holder
V-RAPTOR is offline   Reply With Quote
Old 11-30-2008, 09:20 AM   #38 (permalink)
Meow!!
darkSol's Avatar
LSS Sport Pack/Track Pack front wheels are 16x6.5. Rears in all cases are 17x7.5.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 12-03-2008, 04:44 PM   #39 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Bump
Old 12-03-2008, 04:51 PM   #40 (permalink)
LarryB's Avatar
Toyo Tires - Proxes R1R rebate
It ended 10/31. Sent mine in, late Oct... haven't seen it yet. It'll be another week or two before it's late.
