Nitrogen in Tires?
Hi Everyone,
I saw a 5 second bleep on the local news saying to use nitrogen in your tires for better gas miliage. I did not see the segment so I am wondering what your take on this is. I called a local tire shop and they said that the machine alone runs about 6K. Best regards, mr t |
Kaidan Autosport
I haven't heard about increased mileage. The primary benefits are less variation in pressure due to expansion of gas, reduced moisture content means less corrosion on wheels and less oxidation of rubber = prolonged tire life.
Many tire service stores and gas stations are getting these machines. -Jim
2005 Laser Blue Elise, 1992 NSX Red/Black 2005 BMW F650cs, 1976 Honda Accord |
Keep in mind that air consists of 78% nitrogen. So using nitrogen instead of air isn't really all that different. As Jimbo already mentioned, the main benefit of using pure nitrogen is that it doesn't contain any moisture, unlike the air we normally use to fill our tires.
Reto 2005 Lotus Elise (yellow, sport pack), #94 SS 2005 Nissan Xterra (LSV) |
Elise Fanatic
The problem is that most tires are mounted using water or a water-based lub on the rims; you get more moisture from that than from the air itself.
Nitrogen for street use is mostly a waste of time and money. Do a search, it has been discussed before.
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
gimmicks based upon lore make money
Storm Titanium, LSS, touring, hard top. my other car is a ...oh yeah i remember the other car...a spyder club111 member. i tried to buy a lower spot and become member #13 but was spurned! "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety" -benjamin franklin |
#7 (permalink) |
Mountain Road Nut
Dry air is probably good enough. To get rid of the moisture in the tire from the mounting, just deflate and inflate, take a short drive to mix things up inside and heat up the tires, then deflate and inflate again, etc. Of course, you want a dry day, preferably very cold (cold air contains less moisture).
#8 (permalink) |
A smile a mile.
You can buy dessicant lines for your Compressor that dry the air. They're made for paint work. I just saw them in the Eastwood Catalog.
Paul Parkanzky Magnetic Blue with Biscuit Touring, LSS, Starshield |
#9 (permalink) | |
Mountain Road Nut
But I have one of those little 12V compressors that you stick in the trunk of your car, as I am sure many others do. There is no easily accessible or obvious air input. |
#10 (permalink) |
A smile a mile.
It goes on the output side of the compressor. I am not at home so I don't have the catalog in front of me. I'll do a quick internet search.
#11 (permalink) |
A smile a mile.
Here it is:
Dessicant Snake I have no idea how well it works. I just noticed it the other day and then this thread appeared.
#12 (permalink) |
Mountain Road Nut
Just go to eBay and search on desiccant. There are all sorts of different units at various levels of filtering. You will get all sorts of desiccants as well, but you can ignore those. Some include filtering out the oil that gets into the air from the compressor lubricant (which is why I don't use a compressor to blow water out of nooks and crannies on the car - you get oil on the paint). Here is a link to a high end unit:
#13 (permalink) |
His Impatientness
Has anyone looked into getting a regulator/tank so that you can put N2 from a welding supply place in the tires? While N2 generators aren't cheap, N2 is. It seems to me that not having to worry about pressure changes at the track would be nice.
www.agentsofentropy.com |
#14 (permalink) |
>>>Has anyone looked into getting a regulator/tank so that you can put N2 from a welding supply place in the tires? While N2 generators aren't cheap, N2 is. It seems to me that not having to worry about pressure changes at the track would be nice.<<<
For tire matters you can have your local welding supply place set you up. You can get a small MIG welder sized tank that holds about 60 cubic feet of Nitrogen for around 100 bucks...add a regulator and hose with a shraeder valve and you are set. Refills are around 15 bucks. You absolutely need a regulator, this stuff is pressurized to something like 1800 psi. They use the big tanks at race track events all the time to also run their air tools. At some autocrosses and track events I'd check to make sure that a pressurized tank of this kind is allowed on site. At autocrosses, many groups make someone who shows up at an event with a nitrous tank not only remove it from the car, but get the tank physically off the site, period. Even though "NOS" is not flammable or whatever. Neither is nitrogen. The nitrogen machines that some places use apparently separates it from the local air and so generates the nitrogen on the spot. |
#15 (permalink) |
It's the Journey
Another benefit
The other benefit I have heard about is that nitrogen is less sensitive to temperature changes so that tire pressure changes less between cool to hot conditions - this maybe helpful at the track.
#16 (permalink) | |
Elise Fanatic
#17 (permalink) |
formerly known as fastwrx
The easy and cheaper way would be to get a scuba tank and have it filled with air at the scuba shop. This is exactly what I use. The air is clean and dry as it is meant to be breathed by humans at depth. One 80 cu. ft. tank will last a LONG time.
Mike
The "car-tist" formerly known as Fastwrx! 2004 Subaru WRX STi 2005 Lotus Elise CO, LSS, Hardtop, Starshield - Got it!! |
#18 (permalink) |
About bringing nitrogen tanks to autocross events, the rule for SCCA Solo II events is: "Pressurized gas and air bottles with a pressure in excess of 200 psi must have a protective structure around their gauge and valves." This is a mandatory rule that applies to all SCCA sanctioned events.
It has been a long time since I had physics classes, but unless I forgot everything, the tire pressure will still increase with temperature when using pure nitrogen. The ideal gas law says that PV = nRT. Since the volume and amount of gas are constant, the pressure is proportional to the absolute temperature.
#19 (permalink) |
Interloper
Reto, you are correct about nitrogen and the other major components of air following the same pressure/temperature relationship. However, it's the moisture in the air that makes the difference. Water is a liquid in the temperature range that tires operate in, but it always gives off vapor. The pressure of that vapor when evaporation is in equilibrium with condensation depends on the temperature.
Water in your tire can go from almost all liquid at ambient temperature to almost all gas with really hot tires (over 200 degrees).
2005 S2000 #42as |
#20 (permalink) |
Absolutely. I probably should have quoted the posts I was responding to. A couple of people had suggested that the pressure would not change with temperature if you used nitrogen. The point I was trying to make was that it would still change, just less than with air containing moisture.
