Old 06-04-2006, 12:17 PM   #1 (permalink)
Eyelise's Avatar
Is nitrogen worth it?
I'm about to change my track only set of tires. I'm going from OEM A048s to Robert's 225 Ms up front and 245 A032s in back. I noticed my local tire dealer offers nitrogen fills. I do mostly HPDEs and typically get a fair amount of pressure bleed. Is the nitrogen worth it?
Eyelise is offline   Reply With Quote
Old 06-05-2006, 08:07 AM   #2 (permalink)
tesprit's Avatar
Nitrogen may be worth it for a couple of reasons. The pressure stability is a good reason, but the best reason for a street car is the lack of moisture compared to compressed air. It is quite easy to get "wet" air from an air compressor if the filters aren't maintained well and this can lead to rim corrosion over a long period of time. The downside to nitrogen is that you will eventually have to have your own tank to do pressure adjustments at home or the track and they aren't cheap or fun to handle due to their size and weight.
Old 06-05-2006, 08:17 AM   #3 (permalink)
Buz
I have heard that nitrogen also has larger molecules so tires lose less pressure over time. It seems a welding supply shop could fill a tank or bottle for you.
Buz is offline   Reply With Quote
Old 06-05-2006, 08:42 AM   #4 (permalink)
short angry bloke
codymac's Avatar
Images: 19
For track use, I'd imagine a 3000psi paintball cylinder would work. With some quick and dirty math, I'm arriving at somewhere around just enough to fill four tires - should be enough to top off trackside and plenty transportable.
Old 06-05-2006, 08:57 AM   #5 (permalink)
Buz,
Not to pick nits, but air is 79% nitrogen, and the molecule is about the same "size" as oxygen. Any pressure loss for tires is due to mechanical issues
(valve stems, imperfect rims, etc.). The benefit of nitrogen from cyliners is
pretty much the lower moisture content, which allows more constant pressure as the tire heat cycles.
Jim
'62 Alfa Sprint
'65 Alfa Spider Veloce (2)
'88 Alfa Milano 3.0L
'91 Ducati 900 S/S
'05 Elise (#0294),Magnetic Blue, Blk Touring, hardtop
Jim Itin is offline   Reply With Quote
Old 06-05-2006, 09:07 AM   #6 (permalink)
Val
Nothing
Val's Avatar
Yep, you can also get 1+ litre 4500psi in very light kevlar
Val is offline   Reply With Quote
Old 06-05-2006, 10:11 AM   #7 (permalink)
Eyelise's Avatar
Are these cylinders threaded? I have CO2 cartidges for my bike that would work for the track. Anyone know any reason not to use CO2 to top off the nitrogen? They are dirt cheap at the bike shop. I'm sure there is no appreciable water vapor in the CO2 cartridges. One added benefit is nitrogen is lighter than air. This is a Lotus we are talking about after all.
Old 06-05-2006, 10:41 AM   #8 (permalink)
Buz
I thought paintball guns used co2. I have never heard of using c02 besides bicycle tires.
Old 06-05-2006, 11:36 AM   #9 (permalink)
Eyelise's Avatar
Can you think of any reason not to?
Old 06-05-2006, 11:43 AM   #10 (permalink)
formerly known as fastwrx
fastliz's Avatar
I know some (if not all) the local clubs who run track days have rules against compressed gas cylinders at the track.
Mike
The "car-tist" formerly known as Fastwrx!
2004 Subaru WRX STi
2005 Lotus Elise CO, LSS, Hardtop, Starshield - Got it!!
fastliz is offline   Reply With Quote
Old 06-05-2006, 11:52 AM   #11 (permalink)
Val
Nothing
Val's Avatar
lol maybe some sort of "aka military simulation" aka paintball for n00bs
competitive paintball uses either comressed air or nitrogen, usually 0.5-1.0 litre tanks at 4500-5000psi made from aluminium and kevlar.
Markers are electronic semi-automatic, often programmable. Firing rate upto 30 balls per second.
Old 06-05-2006, 12:21 PM   #12 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Mike
Really? Any reason why?
What about air compressors? What about welding equipment in the shops?
Old 06-05-2006, 12:32 PM   #13 (permalink)
TimMullen's Avatar
Images: 19
There is no reason (other than cost) not to use nitrogen, but no real reason to use it either (unless you are a professional race team looking for every last hundredths of a percent improvement).
The only advantage of nitrogen is that it is dry - the moisture in regular air used to inflate tires can expand when heated more than a dry gas expands. It's not that big of a deal - figure out what tire pressure works and use that pressure. Yes, it's trial and error, but so is figuring out the nitrogen pressure to use.
Nitrogen doesn't corrode rims an more or less than dry air - it's the moisture in the air that does any corrosion. But since the only steel wheel that I have that's corroded is on my old wheel barrow, I'm not worried.
If you use air (hopefully dry air) you can adjust the pressure simply and easily anytime. If you use nitrogen, it becomes much more difficult. I had nitrogen used in my tires on my Accord the last time I bought new tires (that what they used at Costco as a "selling point"). Did it make any difference to my tires or the cars handling? On difference is that they used a green tire valve cap to signify nitrogen.
By the way, the 13 year old Honda's steel wheels that has used air all it's life are just fine with not sign of rust prior to the installation of nitrogen in the last year or so.
I'm certainly not going to empty out the nitrogen, but I wouldn't go out of my way to use it either...
94 Miata R Package - Black
Old 06-05-2006, 02:23 PM   #14 (permalink)
Mountain Road Nut
ChrisH's Avatar
Options for dryer air:
a) Fill your tires when it is cold outside, and preferably low humidity. Why cold? Air holds less moisture when cold. Humidity is a percent of the water vapor capacity of the air at the current temperature. Hence, 50% humidity at 10 C is much less actual water content than 50% humidity at 40 C.
b) Hook up the intake of your air compressor to your freezer. Allow a small air opening to the freezer so you don't create a vacuum in the freezer. Same reason as "a" above.
c) Use a commercial inline moisture filter (e.g., dessicant) with your compressor. This has been discussed in other threads (last year?).
d) Combine a+c or b+c.
I could see a problem with liquid water in the tire if you filled it with air on a hot, humid day, and then it got cold. You would then have liquid water in your tire. If you filled with more air while cold, then you could get some overpressure when the tire got hot again as the water evaporated. Of course, even without the water, the tire pressure would go up as the temperature increased.
Old 06-05-2006, 04:05 PM   #15 (permalink)
fastliz's Avatar
If you bring a compressed gas cylinder, it has to be in a container that prevents it from tipping over. I guess they're afraid of one falling, the valve getting knocked off, and turning into a missile.
Mike
2004 Subaru WRX STi
Old 06-05-2006, 04:33 PM   #16 (permalink)
TimMullen's Avatar
Images: 19
The point of it all is that the air pressure in the tire will not go up any more than the nitrogen pressure. It's the moisture in the tire that rapidly expands with heat. Moist air in the tire will cause the pressure to increase as it warms up. Dry air or dry nitrogen will increase at about the same rate (not much).
I simply use a filter on my regulator and have fairly dry air coming out of my air hoses. Dry enough that it doesn't make much difference.
Old 06-05-2006, 06:14 PM   #17 (permalink)
Eyelise's Avatar
O.K. how about CO2 to top off the tires at the track?
Old 06-05-2006, 06:18 PM   #18 (permalink)
fastliz's Avatar
If you want super-dry air, use a scuba cylinder filled at a dive shop. It's what I've been doing for years. Not so much because it's dry. Rather, because I had a scuba tank not being used and it will fill tires for a long time.
Mike
2004 Subaru WRX STi
Old 06-05-2006, 07:52 PM   #19 (permalink)
Mountain Road Nut
ChrisH's Avatar
By moist, that means there has to be liquid water in the tire (even tiny droplets), not just humid. Water vapor expands at the same rate as nitrogen and oxygen. They are all just gases and pretty much obey the ideal gas law: PV=nRT.
But, it is easy to end up with liquid water in the tire if you fill up on a day that has a high water vapor content, and then it cools.
Old 06-05-2006, 08:31 PM   #20 (permalink)
Eyelise's Avatar
I think it has more to do with the fact that water vapor provides a greater heat capacity. The greater heat capacity, the hotter the tires gets and higher the pressure. If you lower the heat capacity of the gas in the tire, you decrease the tendency for the tire pressure to raise.
