Old 09-25-2008, 08:15 PM   #1 (permalink)
Form and Function
plastique999's Avatar
Ohlins DA adjustment prob. - no "CLICK"
My suspension is almost complete...have camber shims removed, Ohlins DA, and BWR sway bar...
Problem is I was at the track adjusting the rebound adjustments, and 3 out of the 4 adjustors click and set very loudly. The fourth I can't feel a click or set....is there a way to fix this?
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 10-05-2008, 08:10 AM   #2 (permalink)
SobeLotus
SobeLotus's Avatar
My Nitrons stopped clicking as well. I am sure they still work but no clicking to know where I am at. Any suggestions?
www.myspace.com/SobeLotus
SobeLotus is offline   Reply With Quote
Old 10-13-2008, 12:07 AM   #3 (permalink)
Form and Function
bump...anyone else have this problem...and know how to fix it?
www.FaceNBody.com
Old 10-13-2008, 09:01 AM   #4 (permalink)
luxige
luxige's Avatar
I suspect you'll have to have it rebuilt.
luxige is offline   Reply With Quote
Old 10-13-2008, 12:03 PM   #5 (permalink)
The Ohlins owners manual says "if no click is felt, the damper must be inspected by an authorized service workshop. It could be due to incorrect or lack of gas pressure".
Red Mist is online now   Reply With Quote
Old 10-13-2008, 12:11 PM   #6 (permalink)
without a Lotus
FLuXeXigeS's Avatar
yep sounds like its time for a rebuild...
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 10-13-2008, 01:04 PM   #7 (permalink)
Zzzzzzz
Green Hornet's Avatar
I have this problem on the left front only. I don't have enough time on (10 track days est.) them to warrant a rebuild - do I?
Life, Liberty and the Happiness of Pursuit
Green Hornet is offline   Reply With Quote
Old 10-13-2008, 02:17 PM   #8 (permalink)
without a Lotus
FLuXeXigeS's Avatar
^depends how low they are set and if they were bought new or used
also sometimes they just go bad...maybe you go to tracks that put the most strain in the front driver side more than the other 3 sides
but if you guys are going to rebuild might as well do all 4!
eBay Store
Old 06-29-2009, 09:08 AM   #9 (permalink)
RS member
Bender Unit's Avatar
Sorry for bumping this old thread
I want to see if anyone have solution of this.
I found out my Ohlins experience the same problem. No "click" when I turn the dial and there's a good amount of oil on the damper...
Please help
Bender Unit is online now   Reply With Quote
