Old 03-28-2005, 06:15 PM   #1 (permalink)
No more cone damage!
Surferjer's Avatar
Old Hoosiers cheap! and a question
Here's the link: http://www.rsracing.com/rscatalog/as...t-discount.asp
Great price. Sheesh. If I'd waited for four weeks I could have saved a bundle.
The question: If "flipping" the tires recommended? After say 1/2 the tire life, if I flip the tires on the wheels, can I wring a bunch more runs out of those outer edges before cording? Just trying to be smart about this stuff.
1993 MR2 autox car
Old 03-28-2005, 07:34 PM   #2 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
If by flipping you mean take the tire off of a wheel, rotate it 180, put it back on the same wheel on the same side of the car, that should not be done if the tires are radials. Radials take a set in the direction of rotation. Reversing the direction of rotation stresses the tire and often causes symptoms that feel like an out of balance or out of round tire.
What would accomplish your objective would be to take the tire off the left side of the car and, keeping the direction of rotation the same, mounting it on the right-side.
Old 03-29-2005, 04:53 AM   #3 (permalink)
RopaS2's Avatar
According to Hoosier, "flipping" S04s is acceptable. Since the S04 design is not a unidirectional one, there is no need to retain the original direction of rotation.
Practically speaking, the last bit of tire life you get this way is likely to be at noticeably suboptimal levels of grip.
RopaS2 is offline   Reply With Quote
Old 03-29-2005, 06:53 AM   #4 (permalink)
kverges's Avatar
While I have not tried Hoosiers, I flip tires on the wheels all the time and rotate from side to side all the time to manage tire wear.
kverges is offline   Reply With Quote
Old 03-29-2005, 07:21 AM   #5 (permalink)
#0518
Robert Puertas's Avatar
Images: 14
Yes, flip the Hoosiers.
Probably around the 20-25 lap mark to maximize life
Robert Puertas
Robert Puertas is offline   Reply With Quote
Old 03-29-2005, 10:40 AM   #6 (permalink)
Surferjer's Avatar
Since the Elise is so camber-challenged, it makes sense. I think if I flip early enough I should get pretty even wear. If you wait until the cords are nearly showing, I assume you won't see much benefit...
1993 MR2 autox car
Old 03-29-2005, 10:52 AM   #7 (permalink)
>>>Yes, flip the Hoosiers. Probably around the 20-25 lap mark to maximize life<<<
Wouldn't surface matter? Most East coast sites are on asphalt and runs tend to be about 30-50 seconds long. (Many west coast sites are concrete, which is grippier and presumably harder on rubber)
Old 03-29-2005, 11:39 AM   #8 (permalink)
#0518
Images: 14
Not much concrete in SoCal for us to run on at the moment.
Atwater in NorCal is concrete - maybe that's what you're thinking of.
Our courses are indeed longer, but also higher speeds, and probably fewer tire destroying slow turns. I'd guess it balances out. Or at least falls within the 20% range I gave.
Robert Puertas
Old 03-29-2005, 05:19 PM   #9 (permalink)
brownsa5's Avatar
As an equal opportunity buyer, Hoosier Tom has them too.......
www.midatlanticmotorsport.com
brownsa5 is offline   Reply With Quote
Old 03-30-2005, 01:20 PM   #10 (permalink)
Interloper
John Stimson's Avatar
ChrisB, as the other messages in this thread imply, reversing the direction of a radial tire is no longer a concern. Maybe at some time it caused problems, but lots of cars sold now indicate a cross-rotation pattern in the owners' manuals, and they all come standard with radial tires.
2005 S2000 #42as
John Stimson is offline   Reply With Quote
Old 04-08-2005, 09:20 AM   #11 (permalink)
I think you would only need to flip the fronts right? In the rear you can get optimum camber so they may wear really evenly there.
z06fun is offline   Reply With Quote
Old 04-08-2005, 11:00 AM   #12 (permalink)
Surferjer's Avatar
Good point. The fronts are the ones cording early. That will save some $.
1993 MR2 autox car
Old 04-17-2005, 03:23 PM   #13 (permalink)
Eyelise's Avatar
boy, the R3S04 cost a heck of a lot more.
Eyelise is offline   Reply With Quote
Old 04-17-2005, 05:11 PM   #14 (permalink)
Surferjer's Avatar
Undoubtedly because the R3S05s aren't out yet. Give it time...
1993 MR2 autox car
