Old 10-15-2009, 08:06 AM   #1 (permalink)
Resident Drunk
zygotesoup's Avatar
Performance Friction Pads
I was talking to my buddy who is an instructor at the Glen and he mentioned that out of all the pads he has used, he highly recommends performance friction. I did some research on these pads and had a few questions for anyone that has used them.
1. Do they make rear pads for the elise or just the front?
2. If they only make them for the front, will mixing them with Hawk pads in the rear create any issues?
3. Do these pads make any squeaking/squealing noise?
4. Would you recommend these for a novice track driver (me)?
5. On this site, it says that the pads require removal of about 1mm of pad material by filing or grinding... is this accurate? If so, how do you go about it?
Lotus Elise Products: street and track pads, tires
I appreciate any info, thanks!
2005 BADA55 Lotus Elise
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
zygotesoup is offline   Reply With Quote
Old 10-15-2009, 11:34 AM   #2 (permalink)
Resident Drunk
zygotesoup's Avatar
anyone?... bueller...
1993 Black BMW 325i
Old 10-15-2009, 11:42 AM   #3 (permalink)
I've used them on a heavy BMW, & they are awesome. However, I think they would have too much bite for the Lotus, they are very difficult to bed in, probably couldn't get enough heat in them. I would not mix pads front/rear, the lotus has a lot of front bias, this will make it worse. The 01 compound is track only, they are dangerous on the street.
Red Mist is offline   Reply With Quote
Old 10-15-2009, 12:09 PM   #4 (permalink)
Vulcan Grey's Avatar
I use the Ferodo DS2500 on my Acura and really liked them on the track. A little noisy on the street.
My friend says he has tried all the pads on his Lotus Esprit X180-R track car, and will only use the Ferodo. He uses the DS3000 though.
Travis
Vulcan Grey Esprit SE
http://vulcangrey.lotuscolorado.com/gallery
Vulcan Grey is offline   Reply With Quote
Old 10-15-2009, 12:25 PM   #5 (permalink)
Resident Drunk
zygotesoup's Avatar
thanks for the input guys, but im curious about how these will work on the elise specifically
1993 Black BMW 325i
Old 10-15-2009, 02:55 PM   #6 (permalink)
R T
Registered Loser
R T's Avatar
I've used PF97's on my '05 Elise and they work fine (hard to get them though) ...... that being said, they need a lot of heat in them to keep them to stay above their abrasive range so it would not be the correct pad on a track that's not really hard on brakes or for a novice (no matter what track).
You'll be really happy with Hawk HT-10's on the Elise!!!!
R T is online now   Reply With Quote
Old 10-15-2009, 03:45 PM   #7 (permalink)
SirBedevere
I use the Performance Friction 01 up front, and stock pads at the rear. Absolutely amazing braking performance! Heartily recommend this for track use. The only negative is the PFs make a lot of dust that is hard to clean off the wheels.
I've gone through two sets: the first set I had to machine down a tad to make them fit. The second set went right in. I don't know why there was a difference, but I did get them from two different vendors.
SirBedevere is offline   Reply With Quote
Old 10-15-2009, 03:48 PM   #8 (permalink)
Resident Drunk
zygotesoup's Avatar
hmmm... where did you order them from when they fit?
1993 Black BMW 325i
Old 10-15-2009, 03:50 PM   #9 (permalink)
R T
Registered Loser
R T's Avatar
....... at low heat levels they're going to eat your rotors alive (just so you know)
Old 10-15-2009, 04:05 PM   #10 (permalink)
SirBedevere
Rotorsandpads.com... $147
In my case, the rotor wear is not high. I have slotted and dimpled rotors up front, and these don't show too much wear from the pads. It would be easy to see the dimples going away if they wore too fast.
Old 10-15-2009, 04:33 PM   #11 (permalink)
Resident Drunk
zygotesoup's Avatar
i would only use these for the track and take them off for street use, so i dont think the rotor wear would be terrible.
if i do have to shave them down a bit to make them fit, how would you recommend i go about it?
1993 Black BMW 325i
Old 10-15-2009, 06:36 PM   #12 (permalink)
SirBedevere
That's the way I do it... only use PFs on the track. Too much brake dust on the wheels otherwise!
The best way is to have a machine shop take off, oh, not quite an eighth of an inch. That way they're all even. A caveman method would be to scrub em around on the sidwalk till they fit. I've heard of that too.
