Supporting Vendor
![]() Join Date: Nov 2008
Proper Storage for R Compound Tires
For those of you who have extreme winter months, you may find these tire storage tips useful. This information comes directly from Nitto.
Details:Proper Tire Storage for Colder Climates For other useful information on winter driving, check out our winter tire FAQs page. Details:Winter Tire FAQs Matt- |
POWR2W8
Was thinking about this myself as this will be the first winter that I will be storing r-comps. Guess I'll get them out of the garage and down in the basement. Storing at 1/2 pressure was a good tip, too.
Thanks for the input. - Allen.
S/N:34090 Mag. Blue/Biscuit, Touring, HT, 5000K HIDs, PPE/Larini SE. |
Live on the edge
I thought I've seen a separate thread, regarding putting our cars away for the winter, where it was highly DISCOURAGED, to remove the wheels/tires (what I used to do with other cars in winter months "putting it up on blocks") with our Elises/Exiges - for fear of some sort of damage or distortion to our suspension. ...???
So, if you are in a climate where extended below freezing temps are to be expected this winter, and you also do not have a climate controlled environment (heated garage) to keep your baby in, what are you supposed to do? ![]()
'08 Exige-S Club Racer Desnorkelled, Stage-2, HID's, DRL Defeat, Sector111 Tow-hook & Fire Extinguisher, Deeply Fettled Roof S/C Air Intake, Schroth Prof II ASM 4pt Harnesses, RLS Lightweight gunmetal coated intercooler tubes, Saikou-Michi catch-cans, dual-SPAL hi-perf intercooler puller-fans, custom painted engine cover
#5 (permalink) | |
![]() My regular tires/wheels are in my basement and the car is sitting on a set of compact spares (98 VW Jetta) purchased from the local junkyard for $100 for the whole set. This keeps the suspension bushings from being distorted and damaged by the suspension being left in full droop and if these tires get flat spotted or damaged from the cold, who cares. The other nice thing is that when not in use, the compact spares are light and easy to move around and take up almost no room when stacked in the corner of my garage. Problem solved! |
Live on the edge
Beautiful solution!
#7 (permalink) | |
Great idea. Is the bolt pattern the same, or did you modify the wheels?
'07 Exige S, Racing Green Metallic, Track & Touring Packs, Traction Control |
#8 (permalink) |
The bolt pattern is the same, but the wheels will foul the brake calipers so no rolling the car around or driving it. If you need to roll the car around the garage, just slip some car dollies under the wheels. I have a set made by Roll Master (don't know if the company still exists, but there are plenty of cheap dollies available now days) that will allow me to push the car in any direction or spin the car 360 degrees within its own wheelbase.
#9 (permalink) |
Unattractive Nuisance
what is the benefit of storing the tires @ 1/2 pressure??
I've not heard that before.
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. 6. "A bore is a man who deprives you of solitude without providing you with company." - Gian Vincenzo Gravina |
#12 (permalink) | |
Supporting Vendor
The primary benefit of reducing the pressure in this case would be to reduce the stress on the rubber compound of the tire. |
#13 (permalink) |
...so, 1/2 pressure only if the tires are stored in cold temps?
Stripped 02 » A/C, heat, interior, window, top delete » 15x9 6UL » NT01 » AFCO's and a Moto-Lita (a must have IMO) |
#15 (permalink) |
AKA XHILR8N!
Brilliant!
Simplicity is the ultimate sophistication. Leonardo Da Vinci 2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, other stuff. 2007 Toyota Tundra (about 10 cup holders) 2004 BMW X3 (4 small cup holders) 1980 Rover SD1 |
#16 (permalink) |
boy....the ride quality must be terrible!
#17 (permalink) |
Supporting Vendor
Personally, If I was storing any tire over a long period of time I would store them at 1/2 pressure no matter the temperature it does sound to me like it is more important to do this if they will be stored in cooler temperatures.
-Travis |
#20 (permalink) |
Stands
Thanks for the compliments
![]() BTW - Since I sold my car a few months ago, I will not be needing these stands (for a while anyway). If anyone wants them for 200 bucks (I think that's how much the steel cost me), they're yours! I hope everyone had a great Thanksgiving! |
| Display Modes | |
