Old 08-29-2008, 07:06 AM   #1 (permalink)
R888 tire pressures?
What are you guys running cold F/R?
www.needmusic.com
2006 Elise, GG SOLD
2007 Volkswagen GTI DSG
Previous: 2007 C6 Z51 ylw/blk, 2002 Z06 blk/blk, 1994 Supra TT auto slv/blk, 1993 NSX blk/blk, 1994 Supra TT 6M slv/blk, 1993 Supra TT auto blk/tan
mkiv808 is offline   Reply With Quote
Old 08-29-2008, 08:24 AM   #2 (permalink)
Chili Red's Avatar
I normally dont measure the tires cold. Hot is what matters and I run 27F 29R...
2007 Exige S - Chili Red
2009 Mini Cooper S - Chili Red
Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera.
Chili Red is online now   Reply With Quote
Old 08-29-2008, 08:44 AM   #3 (permalink)
No, it's only an N/A
RichS's Avatar
Need more detail on that question:
What size wheels? What size tires?
I started at 23/26 (cold) and then lower from there (using a probe type pyrometer) when using R888s on the stock wheels with the stock tire sizes. Over the course of the day I think I let about 1.5 pounds out of the fronts and one pound out of the rears.
RichS is offline   Reply With Quote
Old 08-29-2008, 09:46 AM   #4 (permalink)
BLAND
fishguy's Avatar
Images: 1
using a probe type pyrometer is the only way you will get them set up correctly, along with your quality air gauge.
use his 23/26 as a starting point, and then go from there.
1986 Swift DB-1
1987 Porsche Spec 944
Old 08-29-2008, 09:55 AM   #5 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
Ok...how do you properly use a pyrometer? I know you want to know the outside, middle inside temps and you want them even. But what does that really mean.
Yes, I will probably start by just using this info on GTR 2 but its all a learning game.
BTW, I run my R888s 26 PSI front and 28 PSI rear hot. Alwats seem to start with them over inflated and then have to seriously back off pressure after my first run. First run Im not pushing anything and just learning the track.
Add me on MySpace
2005 Lotus Elise LSS
2003 Corvette 50th Anniversary Convertible
Visit LA Club Chat for the latest on clubbing and nightlife in Los Angeles
Dmbrown34 is offline   Reply With Quote
Old 08-29-2008, 10:33 AM   #6 (permalink)
...disappearing posts...
FLuXeXigeS's Avatar
as of now, im on TD 1.2 wheels, 16x7 front, 17x8 rear factory size R888 and im running the PSI reading on the door jamb of the car, its like 26/29 f/r if i remember correctly
any PSI recommendations?
-Coi-'07 AR Exige S+Gotham, Von Hep, corner balanced&tuned SACHS, 6k HID, JVC KD-NX5000, Alpine 4ch. amp, JL stealth box, s111 rear towhook and harness bar, Starshield, TG4 1/4 turn fasteners, SS brake lines, bling bling eng bay, painted calipers, TD 1.2 wheels w/ Toyo R888, Safecraft harnesses, DRL delete, s111 CRD mount.
add me: www.myspace.com/kandyredcoi & lotuscar.ning.com/profile/KandyRedCoi
FLuXeXigeS is offline   Reply With Quote
Old 08-29-2008, 10:55 AM   #7 (permalink)
RichS's Avatar
If a tire has temps like this (one tire, left/middle/right):
140 160 140
then you have too much pressure and you should let some air out.
If a tire has temps like this:
140 120 140
then you don't have enough pressure and you should put some air back in.
140 140 140
then you should play the lottery.
That's the basics. Of course things like camber can effect temps and you will often see uneven temps across a tire, but basically you want temps that make sense.
If your rear drivers side tire has temps like this:
140 145 148
and you are running -3 degrees of camber in the back then it sort of makes sense. The inside of the tire should be a bit hotter than the outside because of the camber, and everything is sort of linear.
I do think that 26/29 cold would be too much pressure for a R888 on stock wheels, however a lot of this also depends on how hard you run the car. I know that with the AO48s there were folks who were running their rears a few pounds LOWER than their fronts because they were running their cars HARD. While the first few laps were squishy, once the rears got up to temp their cars were some of the fastest on the track. Of course they were running at 10/10th (or often more like 10.5/10th). If you are running the car 5/10th or 6/10ths then 26/29 might be fine.
Old 08-29-2008, 10:57 AM   #8 (permalink)
RichS's Avatar
Track or street? For track, I would go down. Minimum of 3 lbs per tire.
For street... sounds about rightish, but who the heck knows? You would have to use a pyrometer, or just look for uneven tire wear.
Old 08-29-2008, 10:59 AM   #9 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
^ Heard the advice from one of the dealers to run rears lower than fronts. Dont think Im at the level where thats right for me. However, I think Lap This has some nice footage of my rear stepping out on me in some twisties. Since I cought it...it should make for some cool footage.
Add me on MySpace
Old 08-29-2008, 11:27 AM   #10 (permalink)
Chili Red's Avatar
Since I very rarely have the rear of my car step out Im not sure lowering the rear pressures would do much good. In fact It makes the car harder to rotate mid corner.
Old 08-29-2008, 11:48 AM   #11 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
You have a little more force pressing down on your rear! Might make a little bit of difference.
Edit: Assuming your racing with a wing.
Add me on MySpace
Old 08-29-2008, 11:56 AM   #12 (permalink)
knucklehead's Avatar
At the last autocross I think I ended up at 24F and 26R.
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is offline   Reply With Quote
Old 08-30-2008, 12:19 AM   #13 (permalink)
FLuXeXigeS's Avatar
was that the qualcom one a few months back?
your car felt really really good
i dont remember...are you running 15/16 ?
and if so...will the same PSI work for my 16/17?
thanx Jacob
Old 08-30-2008, 02:22 AM   #14 (permalink)
Yes I'm running 15/16, but I would assume the tire PSI should be similar. It would at least be a good starting point. Those temps are for hot BTW.
Jacob
Old 08-30-2008, 02:41 AM   #15 (permalink)
FLuXeXigeS's Avatar
OK got it...ill try that for the sept autox
thanx
Old 08-30-2008, 11:20 AM   #16 (permalink)
I just did 23 front 25 rear cold for stock sizes.
These tires feel FANTASTIC and just grip and grip. Imagine they'd be even better after a little break-in.
www.needmusic.com
2006 Elise, GG SOLD
Old 08-30-2008, 12:18 PM   #17 (permalink)
No Acceptable Substitutes
apk919's Avatar
Yes, they do, and they will!
I've got 24f/26r cold (80 degF)... stock sizes. I've checked the temps with an infrared thermometer after a canyon run and they look nice and linear across the tire face.
Coi, which auto-x are you going to in Sept?
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD
Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam
apk919 is online now   Reply With Quote
Old 08-30-2008, 01:59 PM   #18 (permalink)
What's considered full break-in for these?
www.needmusic.com
2006 Elise, GG SOLD
Old 08-30-2008, 03:54 PM   #19 (permalink)
FLuXeXigeS's Avatar
Speed Ventures in Fontana Sept 20th
Old 08-30-2008, 06:15 PM   #20 (permalink)
apk919's Avatar
Thx!
HTML code is On
