the obedience of fools
You may recall the now quasi-famous forklifted Elise at the WCLM this year.
It was forklifted off the track because it suffered a broken rear toe link. ![]() If you missed the latest "all about the rear toe link" thread, here it is: http://www.elisetalk.com/forums/showthread.php?t=23291&highlight=toe+link This problem is potentially serious and dangerous enough for many to demand a recall: http://www.elisetalk.com/forums/showthread.php?t=23472&highlight=toe+link Stan did an analysis of the OEM part that sheared off at the track: ![]() Lotus sells a "track pack" brace kit that seems to help with this problem, although its primary purpose is to reduce bump steer during extreme track driving. The root of the problem seems to be the inadequate size (10mm) of the OEM ball joint bolt that carries the rear cornering load. Well, that's not the entire story as it turns out! Take a look at these pictures of the OEM ball joint bolt from the non-failed-side of this same car: ![]() ![]() Notice the red arrows pointing to the shiny areas. This is evidence of the stock 10mm bolt moving back and forth against the tranny mount. It was discovered that the inside diameter of both the hole in the tranny mount and the factory rear A-arm bushing are a bit too large for the stock 10mm bolt, and there is therefore a noticeable bit of slop inherent in the factory inner ball joint bolt to chassis interface. In other words, it does not so much matter if your inner toe link bolts are properly torqued, they will still wiggle inside their mounts under stress of hard track driving because of the sloppy tolerances! This will lead to the gradual weakening and failure of this bolt as outlined in Stan's analysis. Therefore, the factory track pack brace really fails to address the root of the problem, since it still uses a little 10mm bolt through the tranny mount and the factory rear A-arm bushing. So, how to properly remedy this situation?? Well, to make a long story short, the car has been up at Buttonwillow since the WCLM '06 track event getting this issue expertly resolved (it still as of today has all the masking tape on it!) ![]() It was decided obviously that we needed to go with a bigger diameter, higher-grade inner toe link bolt than what is offered by Lotus. The heart of the new system comprises of an aircraft grade 7/16" AN bolt (suitable for safety wiring) and stover nut, together with a new custom machined spherical ball joint spacer featuring a machined insert channel that fits into the factory keyed hardened insert on the tranny mount's inside toe link location: ![]() Before they re-installed the diffuser, I took a shot of the new system. It uses all new race-grade hardware including spherical ball joints throughout, and a center brace like the Lotus track pack brace, to bring the system into double-shear: ![]() While this new redesigned system may be overkill for many Elise owners, I feel very strongly that the OEM setup is not adequate for track duty, and is even more of a potential hazard given what I know now about its design. I have asked the race shop that did this system for me to make it available to other Elise owners. So far, my car is the first to have this new setup. I looks like there is a fellow running and Elise in SCCA T-2 who will be getting the second one installed shortly. This "kit" will require minor machining of the A-arm busings and the inner toe link mounts, plus it will require a rear-end re-alignment, so I dont think it's really a "bolt-in" solution for the shade-tree mechanic or do-it-yourself'er. Pricing has not been announced, nor do I think it ever will, because this will likely remain a relatively low-volume product. If you want this for your Elise, call Tom at 7's only racing at the Buttonwillow track: 661-764-5456 http://www.sevensonly.com/ Good luck and see y'all next time at the track! Marc |
Third Eye Open
Thank you for doing this and I am sorry you were forced to make this correction on your own, I hope Lotus Takes this seriously.
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's! Knowledge is knowing a tomato is a fruit, wisdom is not putting it into a fruit salad. |
marcw,
It looks like you are running ra-1s on smaller wheels, any suspension upgrades too. Will lotus stick to the position that your car is getting close to race specs and the car is only designed for occasional track use not competition driving. Could the failure be due to loads beyound normal spec? Not siding with Lotus but I think we need to be unbaised, here. I want the problem solved too as it is disappointing that the car has a flaw of this nature. |
I was thinkning about this allot, as I use my car for non competivetive HPDE day level 3-4. how much are the toe end links (stock)? couldnt this be something that track guys just change out on a basis of preventitve maintenance. if we are going to be in there checking the torque before every HPDE day(which I am going to check every time out now). can the end link be marked say with tape or something to show where the old link was set up at for rear alignment purposes, and a new one just put in when inspecting this part warrants change out? I am a DYI guy, but by now means a pro mechanic. maybe my line of thinking is WAY off, and there is something i dont understand, but wouldnt this be an OK solution as well, keep 2 of these around, just like extra brake pads or something, and watch them just as closely as brake pads, or checking oil. it might be a pain, but so would hurting the car, or my body as a result of this part letting go on the track. I am putting this out there for other minds to ponder, and would like Stan to think about this solution(for me and other HPDE guys) as an alternative to this new design, which looks really good, but my car is not going to be able to go to this shop thats doing the install, as its hard enough for me to get away with my car outside AZ as it is. Just putting this out there for my own piece of mind, and as a way of continuing dialgoue on this subject, as it has been on my mind allot since i have become aware of the issue.
thanks for the valuable input in adavnce, hopefully no flames from this idea, or at least not from people who are using the cars for track days anyway. Josh |
Links
I've never seen link failure on a street car that had not slid into a curb.
If you change your wheels, tires, spring rate, or shock rate and race prep your car, you may want to think about a Lotus rear link brace.We have them in stock for around $ 700.00 bucks.( Newport European Motorcar L.T.D. ) Street car guy's with oem parts only need to worry about keeping their ride serviced by the book. All the best, Don
'' I always tell my students to follow their bliss- where the deep sense of being is from, and where your body and soul want to go''. Joseph Campell |
#7 (permalink) | |
The Original Dro
A set of the ball joints cost around $100. I recently picked up a pair. |
#8 (permalink) | |
![]() They've helped me out more than a couple of times when I broke my miata at the track. Once My clutch slave cylinder went so I had a clutch that wouldn't disengage. they got it functional enough that I could make the drive back to LA over the grapevine and replace it at home. Another time the plastic top of my stock radiator split in half and I had to leave it with them while I ordered a new radiator. Both times they helped me out it was late in the afternoon on a Sunday. They pretty much droped everything to help me out. I was fully expecting to pay through the wazoo for race shop labor on a Sunday at the track, but they didn't take advantage of the situation at all, very fair prices both times. Anyway I've got nothing but good things to say about them.
2005 Elise, CO, LSS, Hard Top 2006 Mini Cooper S - peper white 1986 BMW E30 325E - 24 Hours of LeMons race turd The B-Team, 24 Hours of LeMons Race Team |
#9 (permalink) |
srw
Marc - did you try contacting Lotus Sport about this? Maybe it would be worth talking to Malcom? I recall seeing your car fork-lifted away and felt very sad. To read your story is worrisome. A few questions:
- others have pointed out MODS you may have done - how long have you had these modifications on the car? - how many track days have you done with your car? I am not a DIYer - I'm not sure what to tell a shop to look for on my car to see if its "going" to fail. It sounds like there is potentially slop but without taking it apart, how does one know? Even the "good" side on your car looks ok. Scott |
#10 (permalink) | ||||
![]() Quote:
#11 (permalink) |
Interloper
I agree with Stan, in that a bolt through a hole is held in place by the clamping force between the head or washer and the surface around the hole, not by the walls of the hole. If the bolt has shiny spots from wearing against the sides of the hole, then at some point in time, the bolt wasn't tight enough. That doesn't tell you whether that's due to not being installed at the designed torque spec, or the torque spec in the design being too low.
2005 S2000 #42as |
#12 (permalink) |
Just a quick question. The 7/16 AN bolt is .0435 larger in diameter than the 10mm OEM unit. Was the hole that much over sized that one can stuff a 7/16 into it?
The other thing is, is the OEM track rod end thread metric, 10mm? If so,what kind of rod end where they using, as most often the hole in the rod end is the same diameter as the threaded shank. Wondering how they mixed metic and imperial threads and dim. Do you know the thread of the track bar,or the spec of the rod end they used? |
#13 (permalink) | |
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
#14 (permalink) | ||
#15 (permalink) |
No more cone damage!
Marc-thanks for taking all the time to post this. Your fellow e-talkers thank you.
Jer-2005 Elise (retired from autox) 1993 MR2 autox car 2002 Ford Excursion DIESEL 4 X 4 1993 Miata (throwout bearing or clutch failure) 1987 Toyota Corolla FX16 Lemons car (needs new head) 1984 Chevy Citation Lemons car (needs a motor) |
#18 (permalink) | |
Interloper
1) The bolt was not tightened properly, at some point in time (it only has to happen once to make shiny spots) 2) The forces in reality were greater than Lotus designed for when they chose that fastener and torque specification. The size of the hole does not determine whether the slippage occurs in the first place, just the distance that the bolt can slip. Reducing the play in the hole will reduce the impact if the bolt does slip, but a more effective solution would be to prevent the slippage from happening. It looks like your fabricator has addressed both issues.
2005 S2000 #42as |
#19 (permalink) | |
#20 (permalink) |
Nerd on wheels
The problem is not that the hole is too big, but that the bolt moved in the first place, as it is suposed to be fixated by the clamping force of the bolt+nut.
Interesting to note that on the Toyota powered cars the torque for this connection is so much lower (50Nm) than on the Rover versions (70Nm). Of course they use different subframes, which may be the root cause of this reduction, but of course this also reduces the clamping force provided by the whole setup significantly. Not sure if the toyota powered cars use 10.9 grade nut and balljoint shank for this application. The rover ones do, therefore the M10 can handle the 70Nm torque. Bye, Arno. |
