Old 06-28-2008, 10:45 AM   #1 (permalink)
Recommended tire pressure?
I have AO48's and LSS wheels on my base suspension car.
Because of this, inside the door is 26F 28R cold recommended for front and rear. I'm sure this is too much pressure for the AO48's.
What is recommended by Lotus for AO48's cold?
I have only seen recommended hot track pressures by searching. I am looking for cold pressure suggestions for street use.
Thanks!
www.needmusic.com
2006 Elise, GG SOLD
2007 Volkswagen GTI DSG
Previous: 2007 C6 Z51 ylw/blk, 2002 Z06 blk/blk, 1994 Supra TT auto slv/blk, 1993 NSX blk/blk, 1994 Supra TT 6M slv/blk, 1993 Supra TT auto blk/tan
mkiv808 is online now   Reply With Quote
Old 06-28-2008, 12:48 PM   #2 (permalink)
British by extrapolation
Mr. Know's Avatar
Images: 5
26F and 29R IS the recommended cold pressures...hence why its printed on the car.
Edit: Ah, you added the LSS wheels and A048 tires to a base car... pressures are 26F and 29R.
07 Magnetic Blue Exige S
Mr. Know is online now   Reply With Quote
Old 06-28-2008, 01:14 PM   #3 (permalink)
mjf
elf
mjf's Avatar
For a recent trip I took, I upped the pressure to 28F 31R and got considerably better millage, without losing any noticeable street performance. Tires max psi is about 50. If you stick to the recommended 26F 29R you should be fine.
07 Elise Type 72D #6 of 50
mjf is offline   Reply With Quote
Old 06-28-2008, 11:27 PM   #4 (permalink)
GGM ENFORCER
shay2nak's Avatar
i'm running 25 front and 27 back. Just trying these after reading some older posts after my rears wore out. The wear pattern on both rear tires was much more in the center than the outsides of the tires, so the 29 stock pressure was too high. my guess.
'07 GG EXIGE S ** MY CAR ** VIDEO CLIPS!
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 06-29-2008, 08:37 AM   #5 (permalink)
Super charged!
Vishus_1's Avatar
Images: 19
Question Can you help me understand
I think the requirement for tire pressure decals on all new cars is a little absurd. Most mechanics swear by those tire pressure decals now and they are touted like they are the gospel or something.
Here is my problem with the tire pressure decals...
I have seen some new cars that have different types of tires mounted - these are brand new cars mind you - and the tire pressure printed on those differing tires varies. For example, I saw a cobalt with Firestones, Goodyear and Dunlap (i think) and some said 35 max all the way to 45 max? That is just on new cars. My understanding is that some auto manufactures have contracts with different tire companies and some cars just get what is available at the time. So right there, I see a potential conflict.
Now lets say you replace the tires with something different...maybe you get a different compound, different manufacturer...who knows, but you change the tires. Maybe you go to a different size rim all together. It is very likely in this example that you will have altered the tire pressure requirement as designated by the tire manufacturer.
I have a hard time believing that whatever reccommended tire pressure is put on the decal always applies if you get different tires. Different manufacturing techniques and different tire types (like run flats vs all season vs mud and snow vs dry pavement) may likely require different pressures.
I feel bad for those who swear to go by that sticker instead of what the manufacturer put on their own tires. I guess the manufacturer of the tires doesn't know what they are talking about?
Help me understand this...where am I wrong or mistaken. I get that the tire pressure on the decal is supposed to correlate with the weight of the vehicle but again tire manufacturers have different techniques, compounds and constructions. I would think people should be advised to go by what is printed on the tire.
Vishus_1 is offline   Reply With Quote
Old 06-29-2008, 10:17 AM   #6 (permalink)
Mr. Know's Avatar
Images: 5
I agree...but disagree.
The pressure on the sticker is supposedly the "optimal" pressure with stock tires. In the case where the car manufacturer throws on any tire they get hold of...then the sticker is bollocks.
Speaking specifically about the Elise...it is known in the community what the proper pressure is for the make and model of tire.
The tire manufacture does not list the optimal pressure on the tire (only max load capacity pressure) because they can not. Optimal pressure can only be known when the application is known. Max load pressure will make the tires feel like you are driving on steel if you don't have enough weight on them.
To take it further...I have to go weigh my motorcoach in loaded condition, calculate corner weights, consult the tire manufacturer's chart regarding the highest corner weight for that axle and apply that pressure for all tires on that axle. I also have to take into account dual or single axle and dual or single tire per axle!
Old 06-29-2008, 11:27 AM   #7 (permalink)
... _ . ..._ .
nvrblu's Avatar
I'm running 26F/27.5R cold on A048s.
I was running 29R but the first set of tires showed a lot more wear in the center than towards the edges.
Steve -- '05 Laser Blue, Biscuit, Sport/Touring, Starshield
nvrblu is offline   Reply With Quote
Old 06-29-2008, 01:26 PM   #8 (permalink)
Chili Red's Avatar
29 is to high for the rear as others have said, you will wear out the center of the tire before the edges. Ive been running 26F 28R and get much better wear.
2007 Exige S - Chili Red
2009 Mini Cooper S - Chili Red
Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera.
Chili Red is offline   Reply With Quote
Old 07-05-2008, 03:25 PM   #9 (permalink)
brgelise's Avatar
26/27.5-28 is good for me with either the AD07's or A048's on street, but I take it one step further. In CT a daily temp range this type of year is 70-90 degrees. If I set the car for 70 degrees (on way to work in morning) car is a brick from lunch on (when I usually play a little more) So I set all my vehicles based on a daily median temp. That way my pressures are always 1lb +/- from my but-o - meters ideal. Has worked really well and I'm getting perfect tire wear even with all my camber modifications for track use. Try it, you'll like it!!!
05 Lotus Elise Sport Hardtop LRG red leather.
04 Skip Barber Race School, Competition certificate;
04 Jaguar XJ VandanPlas Radiance Red Ivory leather
04 Subaru WRXSTi WorldRallyBlue,360HP/390tq,FORSALE
06 Subaru Tribeca LTD
08 Isuzu Ascender Lux 1/3rd off invoice!
brgelise is offline   Reply With Quote
Old 07-05-2008, 06:14 PM   #10 (permalink)
Lotus Sales
tireshoppe's Avatar
The pressure printed on the tire is the maximum pressure, or not to exceed when cold. Some tires are rated for extra load, or a reinforced side wall and will have a higher max pressure. If you want to carry extra weight in a SUV or truck, like a concrete statue you wife had to have on vacation and the normal pressure is 32 the tire might have a max pressure of 45, you could pump the tires to 45 and take them back down after the trip.
The vehicle manufacturer calculates how much weight is put on each tire under loaded conditions not sitting still. They determine how many square inches of tire is on the ground and get PSI or pounds per square inch. They will adjust that if the car tends to oversteer or understeer, but lean towards understeer. That tire pressure is the same for summer, all season, snow or mud tires. For street driving this will change very little with a larger size, competition driving is completly different.
Joe
TheTireShoppe
tireshoppe is offline   Reply With Quote
Old 07-06-2008, 09:27 PM   #11 (permalink)
Super charged!
Vishus_1's Avatar
Images: 19
Originally Posted by tireshoppe View Post
The pressure printed on the tire is the maximum pressure, or not to exceed when cold. Some tires are rated for extra load, or a reinforced side wall and will have a higher max pressure. ...
Joe
TheTireShoppe
Thank you Joe for the explanation - I understand that but what I am questioning is the premise this is based on. If the vehicle manufacturer is basing the printed reccommended pressure on the PSI of the stock tires - wouldn't this be meaningless if I changed to a different tire by a different manufacturer. Some have stronger sidewalls, different compounds and compositions from others. I don't understand how the car manufacturer can make a blanket statement that really only applies to the specific stock tires the car has. And again, there are some instances when some cars have different tires by different companies on the same rims depending on what is in stock (like Chevy Cobalts for example - you will find some at dealerships that have the same rims but different tires). I would think the tire manufacturer should be the athority on what is reccommended based on the max and type of tire.
Old 07-08-2008, 01:20 AM   #12 (permalink)
Lotus Sales
tireshoppe's Avatar
The vehicle is supported by air pressure not by the tire. A runflat tire will support the vehicle when the air is removed but when inflated it rides on air. When you change tire brands the size of the air chamber stays the same. A tire with a reinforced sidewall is stronger to take more cornering forces and can hold more air presure to carry more weight. The presure printed on the tire is the maximum not the recommended.
The vehicle manufacturer plac has the information for the OE size and often optional sizes. The information is for normal highway driving. I've seen charts for size, presure, weight and they're pages long. They wouldn't fit in a door jam and most people would never read them.
Joe
HTML code is On
