Old 10-31-2009, 05:50 PM   #1 (permalink)
ToYoTa dRiVeR
Imolas54's Avatar
Rota Slipstream fits on the S240?
i am getting tired of cleaning the OEM wheels, do you guys know if the rota slipstreams sold by balckwatch racing will fit on the s240? I thought i read somewhere the offset need to clear the bigger brakes?
Thanks
It's Never Enough...
Imolas54 is offline   Reply With Quote
Old 10-31-2009, 06:02 PM   #2 (permalink)
AKA XHILR8N!
BRTHTAKR's Avatar
Images: 6
No way. There is only 2mm or less clearance to the standard front caliper. The Rotas are a cinch to clean. Cup wheels even easier to clean, with room for big brakes.
Simplicity is the ultimate sophistication. Leonardo Da Vinci
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, other stuff.
2007 Toyota Tundra (about 10 cup holders)
2004 BMW X3 (4 small cup holders)
1980 Rover SD1
BRTHTAKR is offline   Reply With Quote
Old 11-10-2009, 05:47 PM   #3 (permalink)
brthtakr, cup wheels have no room for big brakes? meaning the 240 already has bigger brakes or it has stock elise brakes but the cup wheels are tighter fit than stock?...
The real question is what brakes does the s240 have? If already having bigger brakes which fill the 16/17's that are stock, then yeah, no way the rota's 15/16 would fit. The rota 16/17 "could" fit however unless you're already sure of design differences which will keep a similar spec'd rim from fitting (which is very possible). The OP also didn't mention if he's looking for 15/16 or 16/17... unless blackwatch only sold the smaller sizes. I've got the 15/16's which fit fine on elises.
2006 Aspen White Elise. Hard top (never left it's shipping box), LSS, LSD, Traction control, Red leather.
ewalberg is offline   Reply With Quote
Old 11-10-2009, 05:54 PM   #4 (permalink)
AKA XHILR8N!
BRTHTAKR's Avatar
Images: 6
I mean the front caliper on standard Elise/Exige. The S240 has larger front calipers than standard. Rotas barely leave any room to the caliper on lesser models. This is measuring horizontally from the side of the caliper to the inside of a "spoke" of the wheel.
1980 Rover SD1
