Old 09-06-2009, 08:25 AM   #1 (permalink)
rackhenry's Avatar
RTV Brace - Jacking Points
I am installing the Sector111 RTV brace and have a question on lifting the car. I researched the topic last night, read the manual but thought it wise to post here to be 110 percent sure. Are the rear most lifting points ok (D) to use when only using two jack stands, ie. the front of the car is on the ground? Also are the D points just the rearmost cross member right where the rear control arm is located? I am thinking if I use those , then the jack may actually get in the way of the install? However it does appear to be a bit less work not to remove the other panel...
rackhenry is offline   Reply With Quote
Old 09-06-2009, 08:43 AM   #2 (permalink)
Frank Amoroso's Avatar
Pull the diffuser and place the jackstands under the subframe where the two large diffuser bolts attach to. Place your stands / hockey pucks accordingly. This is how I did it for my brace install and it worked out sufficiently well.
Frank Amoroso
Whatever Press Vehicle(s) I'm driving this week
www.twitter.com/famoroso
Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it?
Frank Amoroso is offline   Reply With Quote
Old 09-06-2009, 10:14 AM   #3 (permalink)
I like to take the diffuser off while it's still on the ground. Then place the floor jack right in the middle of the subframe (the part where you connect the RTV brace to), jack it up, then jackstands on both sides. Really secure and will not go anywhere. Hope this helps...you're probably half way done now anyways...
05 GG Elise. Sector111 is only 5 minutes away from home (NOT GOOD) always resisting!!!
Dang!!! is offline   Reply With Quote
Old 09-06-2009, 12:26 PM   #4 (permalink)
rackhenry's Avatar
Nope, still setting up, had to buy some new jacks. . Thanks for the feedback!
Old 09-06-2009, 12:32 PM   #5 (permalink)
rackhenry's Avatar
Is it ok to do while the car is only jacked up in the back. Worried about the angle the rear subframe contacts the jack stand at an angle??
Old 09-06-2009, 12:42 PM   #6 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
If you do decide to lift it from the rear only, chock the front wheels... but I always prefer the car to be sitting level on either jackstands or wheel ramps when I'm working on it.
And as mentioned earlier, place the jackstands near where the threaded inserts are for the diffuser bolts... it will give you more room to get to the toe link parts and rotate your torque wrench...
Old 09-06-2009, 01:11 PM   #7 (permalink)
rackhenry's Avatar
Thanks Finally got the car up on stands and.... now just need some tin snips... Ah, the joys of learning a the mechanical intricacies//nuances of a new car!
Old 09-06-2009, 01:23 PM   #8 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Tin snips? Are you removing the heat shielding? I'd keep the heat shielding that covers the inner toe link joints... ask me why...
Old 09-06-2009, 03:55 PM   #9 (permalink)
rackhenry's Avatar
Glad I just bent it out of the way then! I was only going to trim enough to get out of the way of the bar. Guessing that it offers some form of protection to the joint?
Old 09-06-2009, 05:50 PM   #10 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Yes... especially on the driver's side where the U-bend for the cat is located. Probably saved my heim joints from excess heat when my catalytic converter cracked...
Old 09-08-2009, 01:50 PM   #11 (permalink)
rackhenry's Avatar
Once you got me thinking in that direction, I looked at the setup and came to the same conclusion. Just some fancy bending done on the shielding...
Now just need to get a scissor type u joint separator so I can install my V2 arms..
Thanks everyone for all the great feedback!!!
