Old 06-21-2009, 05:25 AM   #1 (permalink)
Capo's Avatar
Screw in my Tire
Picked up a screw in my rear A048. Not losing air. Looks like a straightforward plug scenario. In that I use these for track days, what are y'all's thoughts on plug vs replace?
"No, Donny, these men are nihilists. There's nothing to be afraid of."
2006 Elise- Chili Red
2006 Infiniti M35 Sport/ 1999 Miata
A couple of Hinckley Bonnevilles/ '89 Honda GB 500
Capo is offline   Reply With Quote
Old 06-21-2009, 05:34 AM   #2 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
There was a military training area in Germany where the tree huggers used to throw nails with washers welded to the end of them in the mud and dirt roads. Unfortunately this was also the area where we played paintball. We would always walk the road first and usually pick up a few hundred of them before driving in. Even doing this we used to get them in our tires quite often. I had a plug kit in my trunk to do on site repairs and then run on the autobahn at 120 mph all the time. I actually had one tire with 16 plugs in it at one time. Never had an issue or leak.
Dragon is online now   Reply With Quote
Old 06-21-2009, 05:34 AM   #3 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Never plug unless it's an emergency to get you home. Plugging may be illegal in most states due to safety failure reasons. The correct method is to patch the tire on the inside if it's in the tread.
Tire Tech Information - Puncture Repairs
Cheers,
Old 06-21-2009, 08:06 AM   #4 (permalink)
a lot of people are against plugging but i had my lambo rear tires plugged once and i've ran it to 200 miles many times over without any problems. i've also plugged the a048 and ran them on the track past their wearbars with no problems at all.
although it's better safe than sorry so if you can patch it up from the inside, so much the better.
azmurciev12 is offline   Reply With Quote
Old 06-21-2009, 08:34 AM   #5 (permalink)
ads_green's Avatar
The internal patch with combined plugs are by far the best. Done properly these are stronger than the original rubber.
ads_green is offline   Reply With Quote
Old 06-21-2009, 01:51 PM   #6 (permalink)
Capo's Avatar
Thanks for the replies guys. I should have said 'repair' generically rather than 'plug' to include patching. Will save me quite a bit vs new set, so appreciate your input...will report back.
Old 06-22-2009, 08:56 PM   #7 (permalink)
#334
Chococar's Avatar
Odds of a problem on the track with a repaired tire are low, but the consequences of a failure could be high. What's your life worth?
I bought a new pair of tires when it happened to me.
Good luck!
Old 06-22-2009, 10:19 PM   #8 (permalink)
Chili Red's Avatar
Ive plugged 2 different tires on my lotus and tracked them both extensively without issue.
2007 Exige S - Chili Red
2009 Mini Cooper S - Chili Red
Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera.
Chili Red is offline   Reply With Quote
Old 06-23-2009, 08:37 AM   #9 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Same here Chilli.
But it COULD lead to disaster. Probably won't, but if the right nail/screw went through just right and split one of the steel belts, it could mean big trouble at speed. Low probability, but high risk situation if it does happen.
xtn
