#21 (permalink) | |
ΒÄŅNED
#22 (permalink) |
I lowered the car as mentioned then *attempted* to corner balance it. My end result with a little more than 1/2 tank and my weight was (now these may not be 100% accurate as the scales I was using did not have adjustable legs)...
LF 123 mm 429 lbs RF 126 mm 411 lbs LR 124 mm 694 lbs RR 126 mm 664 lbs. I have not had any trouble with the height so far other than getting onto the alignment rack. I now have a chunk missing off my front splinter. It's covered with tape at the moment till I get it fixed. Someone who was not a newb probably would have balanced the car better but hopefully it'll handle fine. I'm sure my driving limits the car, not the other way around. The only thing that bothers me is the front splitter is noticeably lower on the driver side than the passenger side. Driver side is 106mm off the ground and passenger side is 120mm off the ground. No idea why so different.I'm happy with the height so far. The high front end was starting to bug me, now it looks right. ![]()
Toys- 07 Lotus Exige S Chrome Orange 05 Ducati S4R 02 Suzuki SV650 09 Kawasaki KLX250 |
#23 (permalink) | |
ΒÄŅNED
#24 (permalink) | |
I just remeasured the front splitter with nothing in the car and driver side is 112mm and passenger side is 120mm. I have a warped splitter I guess.
Toys- 07 Lotus Exige S Chrome Orange 05 Ducati S4R 02 Suzuki SV650 09 Kawasaki KLX250 Last edited by agirls : 10-29-2009 at 03:37 PM. |
#25 (permalink) |
ΒÄŅNED
What do you get when you measure from the bottom of the clam (in front of the wheel, but behind the splitter) on each side?
#26 (permalink) |
(Unloaded) The difference between the sides measuring the front silver under panel is 1mm, measuring the clam directly in front of the wheels difference of 4mm, and the splitter difference is 8mm.
#27 (permalink) | |
ΒÄŅNED
#29 (permalink) |
ΒÄŅNED
#30 (permalink) | |
Drive it fine on the street and car parks are ok. Some bumps you do need to approach slowly and/or at a diagonal angle and only once I had to ask passenger to get out for clearance ![]() |
