View Poll Results: Is this repaired tire safe and usable on trackdays
Yes it should be fine 11 42.31%
Not safe to use at all 15 57.69%
Voters: 26. You may not vote on this poll
Old 10-11-2009, 08:09 AM   #1 (permalink)
RichardNHCooper's Avatar
Angry Tire damage
I fitted a set of Toyo R888 and drove for about 30 minutes and this happened. It was repaired immediately with a "SafeSeal" repair plug. My question is, can I use it at a track day with little or no risk or have I just blown $A440 and have to replace it?
2006 111R Elise,VF stg 1 supercharged,HIDs,Harness bar, LETSLA,Nitrons, Ferodo DS 2500,FF engine damper. Saikou Michi catch cans.Toyota MWR Transmission Lotus 6-spd 3.9:1 LSD Uprated clutch.
RichardNHCooper is offline   Reply With Quote
Old 10-11-2009, 08:44 AM   #2 (permalink)
2/3 hp to the paws.
Simba's Avatar
Personally, I'd never used a repaired tire on a track, nor on the street for any amount of time. TireRack, et al, have road hazard coverage available. Worth every penny.
Old 10-11-2009, 09:27 AM   #3 (permalink)
JLSELISE's Avatar
Plug should only be used as temp repair and never for high-speed applications. But damage may be repairable and the tire could be perfectly serviceable with properly applied internal patch. A careful internal inspection is required.
Joel
'67 S3 Elan dhc (owned since 1970)
'06 Audi A3 3.2
'04 Noble M12 (380 rwhp)
JLSELISE is offline   Reply With Quote
Old 10-11-2009, 09:53 AM   #4 (permalink)
DeanG's Avatar
It pains me when...
It pains me when I see Lotus owners/drivers try to drive at speed on the cheep. Patched tires, worn out tires, unbalanced tires, half used brake pads, warped disks, dime store brake fluid, brake fluid older than 6 months do not belong on a car taken on the track.
I believe a car should be well prepared for a track session. To me the above list is the bare minimum. We owe ourselves and the others at a track event a properly prepared car.
I don't "do" many track days but I have seen many people towed or limp home from them.
Lets be safe out there.
DeanG is offline   Reply With Quote
Old 10-11-2009, 05:56 PM   #5 (permalink)
Elise Driver
tireshoppe's Avatar
The tire takes a lot of stress on the track. Think of it like a piece of paper and you put a hole in it. If you pull at it, the paper will most likely tear at the hole. The tire ply's are very strong and woven together but you just put a weak point where it takes a lot of stress. Is the car worth less than the tire?
More important though, is a Radial tire should NEVER be repaired with an external plug. The only proper repair is to patch the inside.
Joe
TreadZone
My biggest fear is that when I die my wife will sell my stuff for what I told her I paid for it!
tireshoppe is offline   Reply With Quote
Old 10-11-2009, 06:08 PM   #6 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
Hi Richard - is the "SafeSeal" an internally applied patch and who did it? Tyres can be repaired and used safely but an internal inspection is required to ensure no belts were damaged by the nail moving inside the tyre.
So the answer isn't yes or no it is more info required
One good thing though is that since the tyre is new if you do need to replace it you only have to replace one!
As for the result from a poll on LT - well voters aren't having to reach into their own pocket for starters so replace is going to win! Also this is essentially America where terror of litigation outweighs good engineering decision making IMHO (see many threads on replacing rather than repairing bodywork).
Aedo is online now   Reply With Quote
Old 10-11-2009, 06:16 PM   #7 (permalink)
Seb
<3 QR25DE
Seb's Avatar
I went 144mph (many times) on a plugged tire. No problems.
Seb is online now   Reply With Quote
Old 10-11-2009, 06:59 PM   #8 (permalink)
Regurgitated User
fitfan's Avatar
i would not...
its all on you, to accept a level of risk.
a plug on track? no way... ANY organization worth tracking with tell you that - deffinatly not allowed.
inside patch... MMMmmmm.... i suppose its debatable, me? not on a track event (yeah i would drive it around on the street no prob.). the structure of the tire has been damaged, no matter if you "stop the air leaking out" the high temps (repeateded), high forces on the tire of a track day are way beyond what the tire will experiance on the street, and speed in a straight line is not a fair comparision at all... i mean - just look at tire after a session, the roll, temp, graining... pretty extreem.
you can not undo the structural damage to the tire. the risk increases as the tire is exposed to more and more extreem conditions - even an undamaged tire will eventaully fail if worked beyond its limits... a damage tire will have lower limits - what are thoose limits? who knows, but do you want to be the one that finds out?
is a couple hundred dollars worth the risk of a blow out on track, and the potential for property and bodily damage? to you, and maybe someone else?
...up to you you could patch it have no problems... but that might just mean you were lucky.. not that a patch is idealy safe.
Driving it around!
Old 10-11-2009, 08:22 PM   #9 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Originally Posted by fitfan View Post
i would not...
+1
Just take a look at a good photo of a car in a high-G corner... the bottom of the tire (especially the sidewall) is very deformed, while the top of the tire looks completely normal. Consider that at >100mph, the tire is rotating more than 20 times a second... (and so goes from very deformed to relaxed 20 times a second as well). How well do you think a patch is going to put up with that type of stress?
Old 10-11-2009, 08:55 PM   #10 (permalink)
Seb
<3 QR25DE
Seb's Avatar
As long as the object didn't puncture the tire near the shoulder, you're fine.
Old 10-11-2009, 10:01 PM   #11 (permalink)
Head LOONY
tvacc's Avatar
I agree. I have driven on Yokos in my Seven and after the event, I had cord showing thru. Now if money is no object, then buy new tires. But I have done track days on plugged tires. Never had a problem.
Now I am not a tire expert...only my experience. But then I Drive Fast and Take Chances....
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is online now   Reply With Quote
Old 10-12-2009, 03:54 AM   #13 (permalink)
Phill B's Avatar
Richard, I've had both a Yokohama O48 and Kumho V70A patched and plugged when near new with similar damage and did plenty of track and road time on them afterwards. Of course, my car is nowhere as quick as yours in a straight line but around corners...
Phill B is offline   Reply With Quote
Old 10-12-2009, 04:43 AM   #14 (permalink)
Elise Driver
tireshoppe's Avatar
The question that I have, is if the tire fails that you told him to repair would you accept liability?
Old 10-12-2009, 05:44 AM   #15 (permalink)
anglophile in exile
Aedo's Avatar
Images: 88
Do you ever patch tyres? If so what are the restrictions on doing so?
Old 10-13-2009, 02:18 AM   #16 (permalink)
Elise Driver
tireshoppe's Avatar
At our retail stores we patch tires for highway use all the time. The only proper repair is to dismount the tire. Inspect the inside of the tire to be sure there is no other damage. Then install a Plug Patch from the inside out.
I've dismounted tires that have been plugged from the outside and the inner liner is worn off to the sidewall ply's from driving low on air. I also saw a tire that was plugged and the nail rubbed into the sidewall ply's that it later caused a bubble on the sidewall. Both are a "catostrophic air loss" situation.
I don't take any repair supplies to the track and I don't know of any other "track support dealers" that do.
Let me ask the question another way. Would you pass someone on the outside of a turn next to a tire that was repaired?
I'm not trying to be a jerk about it, it's something that I've seen from being in the business and know it's just a matter of time until there's a repaired tire that fails. I know many racers have done it without a problem. I know tires cost a lot and you don't want to throw them away with a lot of tread. But if it fails, and it could, it could cost a lot more than a tire and I hope only to the car.
Joe
TreadZone
Old 10-13-2009, 05:41 AM   #17 (permalink)
Crunchy Smurf
toedrag's Avatar
Images: 25
buying track insurance, if available for your event, would likely be cheaper than buying a new tire. That will at least cover your financial risk.
Can't really help you on the personal risk. Good luck.
2006 Laser Blue Elise
-aka, Blue Lightning 2.0, The Little Blue Car, my automobile soul mate
toedrag is offline   Reply With Quote
Old 10-13-2009, 06:07 AM   #18 (permalink)
Thanks guys but upon inspection there was belt damage so it has been thrown out. Ah well as someone said look on the bright side, I only need to buy one !!!!!!
Old 10-13-2009, 06:56 AM   #19 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
Im sorry but the heat the tire will be exposed to, as well as pressure stresses from the constant load shifting, it would seem unsafe to track that tire. Unsafe to you, and others on the track with you.
Is your car, and more important, your LIFE worth 300 bucks? Why take the risk
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 10-13-2009, 07:34 AM   #20 (permalink)
Head LOONY
tvacc's Avatar
I got th earlier post about looking at the tire on my PDA.. I did not have a chance to reply till now and I was going to suggest that his advice was spot on especially since he does this all the time and has seen different damages once he got inside the tire.
Good call.
Tony Vaccaro
