Old 05-04-2005, 05:19 PM   #1 (permalink)
Gojira's Avatar
Tire temperature/measurements
Should the tire pressure be measured when the tires are cold, or when they are hot? are the pressures posted on the door cold pressures?
Thanks!
Gojira is offline   Reply With Quote
Old 05-04-2005, 05:27 PM   #2 (permalink)
#0518
Robert Puertas's Avatar
Images: 14
hot
Robert Puertas
Robert Puertas is offline   Reply With Quote
Old 05-04-2005, 06:10 PM   #3 (permalink)
Student Driver
Ground Loop's Avatar
Doesn't it say Cold Tire Pressure right on the door sticker?
They get higher when hot, so you bleed some off if you're going to keep them hot during an event and want less pressure. Then after the event I fill them back up for (cooler) road use.
Maybe I'm making this too hard..
Old 05-04-2005, 07:12 PM   #4 (permalink)
Elise Fanatic
sleepless's Avatar
Thanks!
For street driving, measure them when cold. Yes, the door sticker is for cold temps.
For track use, the hot temp is what is important. Many are using something close to 28PSI hot. Some use lower pressures for the fronts; like 26F 28R.
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
