Old 09-05-2008, 10:26 PM   #1 (permalink)
Tire Valve Stem Torque Settings?
My new RAC Monolites came with screw-in type valve stems. The stems have rubber on each side of the rim hole and are secured via a threaded nut. Does anyone know the proper torque setting for the nut that secures the valve stem? My guess was 10 to 12 pounds of torque, but I would rather not guess.
2007 Carrera S
2007 Exige S
2007 CBR600RR
My wife told me to choose between her and the bikes and cars. I am really going to miss that bit$h.
deddie is offline   Reply With Quote
Old 09-06-2008, 08:21 AM   #2 (permalink)
... _ . ..._ .
nvrblu's Avatar
That sounds like too much torque... I would guess no more than 5 ft-lb. If you're worried about them vibrating loose, add a drop of Loctite 242 on the threads.
Steve -- '05 Laser Blue, Biscuit, Sport/Touring, Starshield
nvrblu is offline   Reply With Quote
Old 09-06-2008, 08:30 AM   #3 (permalink)
tesprit's Avatar
+1
I wouldn't go with a torque setting anyways. While installing the stems, watch the rubber seals and stop tightening the nut when the seals just start distorting. If you are afraid of the nut loosening up, it would be best to double nut them to lock the nuts in place. This will make it easier to remove the nuts from the stems if you need to remove the stems in the future.
HTML code is On
