Tesla driver
Understeer reduction.
My Tesla is very similar to the Elise. Because of the extra battery weight the front has too much understeer. My front sway bar is set in the middle of 3 holes. Which way do I move the linkage, towards the pivot or away? Would a stronger sway bar help? Any thoughts on the rear sway bar?
Thanks, Roger |
#334
To dial out understeer, you want less roll stiffness at the front (to unweight the front outside tire), which would mean a weaker anti-sway bar.
You should start with a proper alignment--lots of camber, etc. There are lots of threads on this--try "Search". Good luck! Joe |
#3 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
Addtional negative camber in the front is key. Removing shims in the front to get more.
elf
The experts would know better than I, but wider front tires should also help reduce understeer. More front downforce should help too. Not sure if there are any options for you though. You could also try increasing the pressure on the front tires.
#5 (permalink) | |
(Formerly PESTODUDE)
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
#7 (permalink) |
Elise Royalty
I would think that would reduce front grip.
![]() The Tesla weighs about 1,000 pounds more than an Elise and what works on the Elise may or may not work on the Tesla.
#8 (permalink) |
elf
Again, I'm no expert. What I had *read* was that many companies (Lotus included) use a lower recommended front tire pressure as one of the ways to increase understeer as understeer is safer for less experienced drivers to deal with. As a means to counter that you can increase your pressure and reduce the effect. I agree with you though; it seems counter-intuitive. It might have something to do with the recommended pressure being too low for maximum grip. At the very least it is worth looking into and cheaper than new tires. =)
