Old 03-27-2006, 12:22 AM   #1 (permalink)
Mountain Road Nut
ChrisH's Avatar
Uneven brake wear - need advice
I just changed my front brake pads over the weekend because the right front pads reached their wear limit. My concern is that the right front seems to wear a lot faster than the left front. If I recall correctly, the front pads start at 9mm thickness when new. The left front outer pad was at 2-2.5 mm when I replaced it. The right front inner pad had 3 to 4 mm left. (The lesser part towards the outer edge of the rotor). The left front pads were 5-6 mm thickness. Hence, in the time the left front worn down from 9 to about 5.5 mm (3.5 mm worn off) the outer right front pad wore down from 9 to 2 mm (7 mm loss).
When I brake on clean dry pavement with the brakes slightly warmed, I don't notice the car pulling at all. However, every once in a while (rare), it seems that the right front ABS intervenes at moderate braking when I don't think it should. That seems odd.
On cold brakes, sometimes the car will pull left or right briefly. I haven't noticed one direction more than the other.
Does anyone have any insight? I can make some guesses:
a) Maybe the right front rotor needs to be turned (rough surface). However, if it was wearing the pad off that much quicker, I would expect the car to be pulling to the right when braking. Or, since the pads still slight touch the rotors even when released, maybe some roughness on the rotor is wearing the pads when not braking.
b) Maybe since there tends to be more sand and dirt on the right hand side of a two lane road (which I drive a lot), then maybe the right side is simply picking up more grit, causing uneven wear.
By-the-way, this was the easiest brake pad replacement I have ever done. Save some money and replace front brake pads yourself. Thanks Lotus for using such an easy system. The rotors also look very easy to take off and put on as well. (Unlike my 92 Honda Accord, which is a huge pain.)
ChrisH is online now   Reply With Quote
Old 03-27-2006, 07:40 AM   #2 (permalink)
Elise Fanatic
sleepless's Avatar
I'll vote for (b)...
Pete
05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 03-27-2006, 08:36 AM   #3 (permalink)
co sp/tp/ht
nocash's Avatar
How many miles are on the car?
nocash is offline   Reply With Quote
Old 03-27-2006, 09:34 AM   #4 (permalink)
Super 7 Owner In Training
EburgE's Avatar
I say yes. I removed all four wheels this weekend (after 5K miles) to clean the rims and retorque the lugs. The curbside wheels were noticably dirtier and required more scrubbing than the driver's side.
'05 Lotus Elise
'07 Caterham Seven www.hals7.com
EburgE is offline   Reply With Quote
Old 03-27-2006, 10:15 AM   #5 (permalink)
Fists of the Red Lotus
YAUDI's Avatar
Not sure if you track at all, but this is some info on my experiences. I also noted fairly uneven wear with the OEM rotors with OEM pads and Porterfield R4S pad (which I don't recommend). Check out my thread:
http://www.elisetalk.com/forums/show...ight=dba+rotor
Not to say the DBA rotor solved anything, but the pad wear is basically even with the Porterfield R4 pads. I all cases, I never noticed any weird brake feel or characteristics, brakes fine, just some interesting wear patterns...
-Fists of the Red Lotus-
2002 S4 MaD wAgOn, 2003 Golf TDI "Fuel Tank on Wheels", 2005 Ardent Red Lotus Cartoon Car, Sport Pack , Hard Top, Quicksilver RIP, 2bular 6" Ultra Thru , DBA rotors , BADAR888S, ekological HIDs, Fidanza+South Bend
http://www.thedriversedge.net/, http://www.apexdrivingacademy.com/
YAUDI is offline   Reply With Quote
Old 03-27-2006, 11:36 AM   #6 (permalink)
esprit89
esprit89's Avatar
What percentage of the time are you running clockwise vs counter-clockwise at the track? I could see the outside higher loaded tire doing more braking work and hence more wear. Do the rear pads show a simliar wear pattern?
esprit89 is offline   Reply With Quote
Old 03-27-2006, 12:06 PM   #7 (permalink)
YAUDI's Avatar
Talking
What are you, some kind of an Aerospace Structural Analysts or something... If you're talking to me, probably 80% is CCW on the various tracks I drive... That would make sense with the RHS wear a bit faster, but I always brake in a straight line , yeah always...
Old 03-27-2006, 01:34 PM   #8 (permalink)
esprit89
esprit89's Avatar
Originally Posted by YAUDI
What are you, some kind of an Aerospace Structural Analyst or something...
Hey! I resemble that remark.
If you're talking to me...
Opps... my super quick initial glance of the thread somehow made me think we were talking about your car.
ChrisH, you wouldn't by chance frequent CCW tracks also would you?
Old 03-27-2006, 07:35 PM   #9 (permalink)
Mountain Road Nut
ChrisH's Avatar
Further info:
Track time: None (just some practice AutoX events)
Miles on car: 14,000, but that doesn't matter much. What matters is how much and how hard I brake. I drive twisty roads to and from work, so there is a good amount of braking (much more than freeway driving).
New pads: I did switch to Porterfield R4-S pads. I bedded them in Saturday, but thought they were slippery at then end of the bedding session (even after a few miles of driving to cool them down). I couldn't even get the ABS to engage at the end. But, by the next day at the May 26 Club111 San Diego AutoX event, they felt good and the ABS clearly intervened on some sections of hard braking. So, I think the pads are okay, at least from a 2 day of use point of view.
Comparison to Rear pad wear: The rear pads seem to be wearing fairly evenly (right side about same as left). It was just the fronts that had the very uneven wear rate. That might weaken or even invalidate hypothesis (b) in post #1.
Old 07-02-2007, 11:07 PM   #10 (permalink)
My other car's a mtn bike
R'elise Me's Avatar
Just saw this thread. I'm replacing pads on a tracked car that had the same unevenness, but in reverse (driver side wore much faster). Most track days I've done are CW which supports the theory that the outside wheel (and in this case the heaviest loaded front wheel) wears fastest.
Sometimes you have to go in circles to move forward.
05 Elise NA 1750 lbs w/ full cage, fuel cell, aero, 173 whp - Colin would be proud.
2008 LR3 HSE
2005 Mini S Convertible
If I'd thought that one day ALL my cars would be British, I'd have laughed at myself!
R'elise Me is online now   Reply With Quote
Old 07-02-2007, 11:22 PM   #11 (permalink)
2sporty's Avatar
9mm thickness front pads when new seem a little thin.
here's what I measured from Porterfield pads:
new front R4 pad
13.8mm
new rear R4 pad
12.5mm
2sporty is online now   Reply With Quote
Old 09-23-2007, 08:46 PM   #12 (permalink)
Buz
left front
As I was leaving a track day this weekend my brakes made a horrific squealing grinding sound. My left front pads are metal to metal. The other 3 corners look to have about 50 percent pad left. Bleeding the brakes last week they all seemed to have at least half left. The car has about 9k on it but only 4 track days, 3 of which were ccw. It never pulled to either side but the last session I had to brake a little earlier toward the end as the last of the left front pads were used up.
Buz is offline   Reply With Quote
Old 09-24-2007, 07:05 AM   #13 (permalink)
KMG365
new front R4 pad
13.8mm
new rear R4 pad
12.5mm
9mm is just the friction material not the entire pad thickness which would include the backing plate. I think that is what you measured.
Never Lift....
jordantii is offline   Reply With Quote
