Weird tire wear. Only the middle worn out.
Two of my friends and I have been getting weird tire wear in the rear. Only the middle of the tire is bald with quite a bit left on both corners.
I run around -2.5 deg camber, toe settings I don't have a number, but it's slightly toe in. Tire pressure around 25psi. Street driven in a mild manner. Any idea? Sent from my iPhone using AutoGuide.com Free App |
| Sponsored Links | |||
Advertisement | |||
Cerebellum Whisperer
Time to hit the twisties and get those corners worn down...
'06 Elise, Aspen White, red interior, LSS, Touring, S111 Katana SC, Reverie CF scoops ![]() 2006 Lamborghini Gallardo, Rosso Leto / Ivory - another rare color combo sheesh, I'm drooling over my own car. ![]() 2007 Yamaha V-Max - the POWER BEAST for cruising with my wife ... probably selling soon! 2006 red Mustang GT convertible, stock - wife's fun car 2009 Toyota Rav4 - winter car, also for carrying anything larger than a toaster |
When I experienced that problem on my 06 Exige, it was a combination of over inflation and horrible alignment. It was mostly the latter, the alignment acted like a cheese grater to the middle portion of the tire. So I'd certainly check on both.
Mike ____________________________________________ |
#6 (permalink) | ||
Thanks for the help.
25 psi is way too much? A friend of mine runs 21-22 psi and has the same problem Quote:
Correct me if Im wrong, but I thought Toe in will wear the outsides of the tires and toe out will do the opposite. Cheers. |
#9 (permalink) |
#10 (permalink) | |
#17 (permalink) |
You can get center wear from under inflation too. The center of the contact patch can squirm and resonate due to the low center loading and wear in a pattern resembling over inflation. I would go up a few pounds, especially your buddy running in the low 20psi range.
Sent from my MB860 using AutoGuide.Com Free App |
#18 (permalink) | |
Failing at Self-Control
![]() A search will reveal that this topic has been covered dozens of times with the general consensus being that the indicated pressures on the door will typically cause a pair of AO48s to wear in the middle. I’ve gone through probably 10 sets of rear tires (AO48s) and always run my pressures lower for more even wear.
07 Lotus Elise – Krypton Green – Sport Pack, Touring Pack, Cilajet, Stage 2 Exhaust, Pagid Black RS14 brake pads and Motul Brake Fluid, Exige-style side scoops, Other Sector 111 / BWR Accessories 02 Mazda Miata MX-5 SE – Blazing Yellow Mica – Hard Top, Boss Frog Clearview Roll bar 05 Mazda3 – Laser Blue, 2.3L 84 Mazda B2000 SE Pickup – White – 296,000 miles |
#19 (permalink) | |
#20 (permalink) |
www.gglotus.org
Tire pressure is the common answer to center wear. However, in this case on the rear of an Elise, Exige (or even Europa and Esprit) it is caused by too much toe-in. As a previous post suggested by the alignment checked. It's highly likely you'll find there's nearly 1/4" of toe at the rear. Great for keeping the rear end stable, but terrible on tire wear.
Cheers, Kiyoshi
Lotus events in Northern California - www.gglotus.org |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
