What size Hoosier A6's for stock rear LSS wheels? - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 02-23-2013, 02:28 PM Thread Starter
Gunpilot's Avatar
What size Hoosier tires are people running on stock rear LSS wheels.
255/45/17's are rare and take a special order. Is there a more common size?
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #2 of 10 (permalink) Old 02-24-2013, 08:58 AM
Absolute power does what?
rosscarlson's Avatar
245/45/17 and 225/45/17 are both pretty common. I've run the 245s without rubbing. But for my money the Yoko slicks are far better and per cycle run about the same cost.
2006 Exige | Full List | BOE Rev400 (357whp) | JC Head | ProAlloy | ForceFed | BOE QS | ITG Airbox | BOE catch cans | gPan2 | Setrab | JUBU | Tillett B5s | Scroth 6pt | OMP Superquadro | interior/HVAC delete | Traqmate | Chasecam | Lift Point Kit | Ultradiscs | RBF 600 | RS14 | Vented Pistons | Penske DA 600/800lbs | V2 arms | BOELinks | ShiftEnforcer | Manly mounts | Braille | Yoko S01s | R888s | GTC-200 & Canards | RACEsills | BOE UnderAero | F1 Livery
Daily/Tow: '10 V8 Pathfinder LE
Former: '11 Jaguar XF-R | '08 Audi RS 4 | '09 Legacy Spec.B | '08 Volvo S60R | '07 Nissan 350Z
rosscarlson is offline
post #3 of 10 (permalink) Old 02-24-2013, 09:31 AM
Certified Lotus's Avatar
Agreed on the Yoko slicks. Medium soft. front: 190/580 R16 rear: 230/625 R17
72 Europa- Next restoration
69 Elan S4 - Restored & Sold
64 Elan S1 - Restored
12 Colin 30 - Lotus Racing Kart - Sold
07 Exige S - Wicked Road/Track Car - Sold
07 Exige S - Fast Road/Track Car - Wrecked at track
06 Elise - Track pack - Sold
Certified Lotus is offline
post #4 of 10 (permalink) Old 02-24-2013, 11:10 PM Thread Starter
Gunpilot's Avatar
Trial and error I guess to see what works for you. I'm running Toyo R888's but im plowing bad in the turns. Great to drive to work but im not digging them for autocross.
I went with 245/40 and 205/45 Hoosier A6's. Mainly because im in a time crunch and that's what Tire Rack had in stock. If I don't like the rears I can special order the 255/45's. The 205/45's though seem to be a standard size most folks use in the front.
A little worried about rake but what's the most it will be? A few CM? Doubt I will notice it with the way I drive.
2012 Evora 2+0 IPS.
2005 Elise.
1982 Brunette.
Gunpilot is offline
post #5 of 10 (permalink) Old 02-25-2013, 04:00 AM
driftwood's Avatar
less than a cm... it'll be so minimal (almost non-existent) your eyes wont be able to decipher whether or not there is a difference
'05 ST Elise: DHP exhaust, Quantum Zero's, Forge MS radiator, s111 v3 eliminator, s111 DSbrace, ce28n...
driftwood is offline
post #6 of 10 (permalink) Old 02-25-2013, 05:03 AM
addertooth's Avatar
You can significantly reduce front end ploughing by introducing more camber on the front end. With stock camber, you will only be using the outer 2 inches of any tire width (when cornering hard). Look at your tire wear after a hot run to confirm this. If you still have any shims in the front, consider removing them. If it still isn't enough, there are other solutions sold which allow a greater camber adjustment.
addertooth is offline
post #7 of 10 (permalink) Old 02-25-2013, 10:19 AM
hroundy's Avatar
I have a set to 245/40/17 for the rear. They do rub slightly on the wheel well liner. I trimmed a small piece off and put a piece of plastic behind it to keep debris from entering the engine compartment.
In autocross I found them to be phenomenal when they were new. They remained quite good for the season and were okay in the a second season.
Howard
2005 Elise AP LSS hardtop
hroundy is offline
post #8 of 10 (permalink) Old 02-25-2013, 10:47 AM
My main issue with the Hoosiers is they heat cycle out really quickly. The first 4-5 session on the track were pretty impressive (better than R888s but no where close to Yoko slicks) but after that they really fell off. By the 8th cycle they weren't nearly as good as my R888s (that I got 58 cycles out of last season). While the R888s fell off at the end they were still pretty consistent all through their life.
For me Hoosiers are about 1-2 seconds a lap faster (on a 120 second lap) where Yoko's are about 4-5 seconds quicker. Given the Hoosiers are 10X the cost of the R888s (when you factor in cost/per-lap) I'll never run Hoosiers again. Just not worth it over R888s in my opinion and hell most people aren't even maxing those out.
So if you want some real fun, hero makers get a set of Yokos. You'll be amazed. Oh, and as Adder said make sure you are running maximum camber with either. I run -2.5 for R888s and -3.5 for Yokos (V2 steering arms and I had my hubs machined to get that much). You'll probably get -1.5 with stock hardware if you remove all the shims and ABS bracket.
post #9 of 10 (permalink) Old 02-25-2013, 01:23 PM Thread Starter
Gunpilot's Avatar
Thanks Ross!
2012 Evora 2+0 IPS.
2005 Elise.
1982 Brunette.
Gunpilot is offline
post #10 of 10 (permalink) Old 02-26-2013, 04:46 PM
CosmosMpower's Avatar
245/40/17
07 Porsche 911 GT3
10 BMW M3
03 BMW 330i ZHP
06 Canyon Red Elise- Katana SC (sold)
06 LRG Elise- (sold)
CosmosMpower is offline
Human Verification
