What size Hoosier A6's for stock rear LSS wheels? - LotusTalk - The Lotus Cars Community
Old 02-23-2013, 02:28 PM   #1 (permalink)
Gunpilot's Avatar
What size Hoosier tires are people running on stock rear LSS wheels.
255/45/17's are rare and take a special order. Is there a more common size?
"CHARLIE DON'T SURF"
When it comes down to making out, whenever possible, put on side one of Led Zeppelin IV.
Gunpilot is online now   Reply With Quote
Old 02-24-2013, 08:58 AM   #2 (permalink)
Total Addict
rosscarlson's Avatar
245/45/17 and 225/45/17 are both pretty common. I've run the 245s without rubbing. But for my money the Yoko slicks are far better and per cycle run about the same cost.
2006 Exige | Tillet B5s | Scroth 6pt | OMP Superquadro | hubQR2 | Stereo delete | interior delete | Traqmate | Chasecam | BWR wheel studs | BOE tow bar | MWR Lift Point Kit | BOELinks | Ultradiscs | RBF 600 | Pagid RS14 | V2 arms | Larini 8" CS | Fujita | Ported | ShiftEnforcer | gPan2 | Manly mounts | BOE catch cans | Braille | Yoko S01s | Toyo R888s | APR GTC-200 | APR canards | RACEsills | BOE Diffuser | Lotus F1 Livery
2008 Audi RS 4 | 2008 Pathfinder LE
rosscarlson is offline   Reply With Quote
Old 02-24-2013, 09:31 AM   #3 (permalink)
Certified Lotus's Avatar
Agreed on the Yoko slicks. Medium soft. front: 190/580 R16 rear: 230/625 R17
'07 Exige S,2bular Header,De-Cat & GT3 Exhaust,Koldfire ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler,Pipes & CF heat shield,Sector 111 Gpan, Accusump,Nitron GT3 shocks,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Sector 111 Trackmount, Lotus High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Personal F1 & Rapidfix II quick release,Traqmate.
Certified Lotus is offline   Reply With Quote
Old 02-24-2013, 11:10 PM   #4 (permalink)
Gunpilot's Avatar
Trial and error I guess to see what works for you. I'm running Toyo R888's but im plowing bad in the turns. Great to drive to work but im not digging them for autocross.
I went with 245/40 and 205/45 Hoosier A6's. Mainly because im in a time crunch and that's what Tire Rack had in stock. If I don't like the rears I can special order the 255/45's. The 205/45's though seem to be a standard size most folks use in the front.
A little worried about rake but what's the most it will be? A few CM? Doubt I will notice it with the way I drive.
Old 02-25-2013, 04:00 AM   #5 (permalink)
1800lbs club
driftwood's Avatar
less than a cm... it'll be so minimal (almost non-existent) your eyes wont be able to decipher whether or not there is a difference
05 ST Elise: DHP custom exhuast, VF NA tune, Sachs SAS, Forge MS radiator, Powerflex inserts, s111 v3 eliminator, s111 DSbrace, Enkei RPF1's, BWR studs...
driftwood is offline   Reply With Quote
Old 02-25-2013, 05:03 AM   #6 (permalink)
Painful Novice
addertooth's Avatar
You can significantly reduce front end ploughing by introducing more camber on the front end. With stock camber, you will only be using the outer 2 inches of any tire width (when cornering hard). Look at your tire wear after a hot run to confirm this. If you still have any shims in the front, consider removing them. If it still isn't enough, there are other solutions sold which allow a greater camber adjustment.
addertooth is offline   Reply With Quote
Old 02-25-2013, 10:19 AM   #7 (permalink)
hroundy's Avatar
I have a set to 245/40/17 for the rear. They do rub slightly on the wheel well liner. I trimmed a small piece off and put a piece of plastic behind it to keep debris from entering the engine compartment.
In autocross I found them to be phenomenal when they were new. They remained quite good for the season and were okay in the a second season.
Howard
2005 Elise AP LSS hardtop
hroundy is offline   Reply With Quote
Old 02-25-2013, 10:47 AM   #8 (permalink)
Total Addict
My main issue with the Hoosiers is they heat cycle out really quickly. The first 4-5 session on the track were pretty impressive (better than R888s but no where close to Yoko slicks) but after that they really fell off. By the 8th cycle they weren't nearly as good as my R888s (that I got 58 cycles out of last season). While the R888s fell off at the end they were still pretty consistent all through their life.
For me Hoosiers are about 1-2 seconds a lap faster (on a 120 second lap) where Yoko's are about 4-5 seconds quicker. Given the Hoosiers are 10X the cost of the R888s (when you factor in cost/per-lap) I'll never run Hoosiers again. Just not worth it over R888s in my opinion and hell most people aren't even maxing those out.
So if you want some real fun, hero makers get a set of Yokos. You'll be amazed. Oh, and as Adder said make sure you are running maximum camber with either. I run -2.5 for R888s and -3.5 for Yokos (V2 steering arms and I had my hubs machined to get that much). You'll probably get -1.5 with stock hardware if you remove all the shims and ABS bracket.
Old 02-25-2013, 01:23 PM   #9 (permalink)
Gunpilot's Avatar
Thanks Ross!
Old 02-26-2013, 04:46 PM   #10 (permalink)
Cone Magnet
CosmosMpower's Avatar
245/40/17
10 Nissan GT-R Premium
06 Porsche Cayman S
06 Canyon Red Elise- Katana SC (sold)
CosmosMpower is offline   Reply With Quote
