Old 10-05-2009, 01:32 PM   #1 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Will a track pack suspention work on a 05 Elise
Will a Bilsteins and Eibach springs from the track pack from a 2008 Exige work on a 05 Elise?
If so is it a easy bolt on / find a spot for the front reservoir?
Has anyone done this modification?
2005 Starlight Black Biscuit Interior // Hard Top // Von Hep Exhaust // Von Hep Rear Delete // Full Heat Shield Removed // Fujita CAI // Rota Torque Wheels W/ Toyo R1R's // ForceFed Carbon Fiber Splitter // Carbon Fiber Engine lid cover // LidBone // JL Audio VR525-CXi Front and Rear // Micro Mirror // Painted interior bits // Bling Buttons // Darth Holder
V-RAPTOR is offline   Reply With Quote
Old 10-05-2009, 01:42 PM   #2 (permalink)
Cthulhu's Avatar
Installation of the tack pack may result in a slow loss of air pressure
2009 135i - Montego blue/Coral red.
2007 Lotus Exige S (deceased) - Storm Titanium.
RIP SCCVC11127HL80723
May the roar of your supercharger forever shatter the serenity of the heavens <3
Cthulhu is offline   Reply With Quote
Old 10-05-2009, 01:59 PM   #3 (permalink)
G-200 Driver
kestrel74's Avatar
YUP... If the Mods don't fix that title, you'll never hear the end of it !!!!
Old 10-05-2009, 01:59 PM   #4 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Well played!
Here's the official parts list from Lotus for upgrading to "LSS"...
Super Sport Suspension Retrofit
To retro-fit Super Sport suspension to a Toyota powertrain Elise/Exige, the following parts and procedure
may be used:
Parts Required Part Number Qty
Front Damper A120C0018H 2
Rear Damper A120D0046H 2
Front Spring A120C0019H 2 31.5/47.5 N/mm
Rear Spring A120D0047H 2 46.6/65 N/mm
Front Spring/Damper Unit A120C0017F 2
Rear Spring/Damper Unit A120D0045F 2
'C' Spanner, spring seat adjust A120C6001F 1
Cradle, tie wrap, reservoir mounting A082W6293F 2
Tie Wrap, reservoir mounting A075W6038Z 4
Screw, M5 x 20, cradle fixing A075W5084F 2
Rawlnut, M5, cradle fixing A075W6074F 2
Anti-Roll Bar, stiffened, adjustable A111C0134S 1 Black
Mounting Clamp, Nylon A111C0052F 2 >
Spacer Sleeve, mounting clamp A111C0060F 2 >
Bolt, M5 x 45, cap head, clamp fixing A082W2106F 2 >
Washer, flat, M5, clamp fixing A075W4011Z 2 > Use with bar A111C0134S
Nyloc Nut, M5, clamp fixing A100W3113F 2 >
Pivot Bolt, M10 x 45, lower wishbone front A075W2065F 2 >
Washer, flat, M10, clamp to chassis A075W4024Z 2 >
Anti-Roll Bar, std. rate, adjustable A120C0020F 1 Yellow
Clamping Block, a.r.b. bush A120C0021F 2 )
Pivot Bush, a.r.b. A120C6002F 2 )
Bolt, skt cap, M8x65, clamp to chassis A125W7218F 4 ) Use with bar A120C0020F
Washer, flat, 25mm, clamp bolt B075W4021Z 6 )
Washer, flat, 16mm, clamp bolt A111W4175F 2 )
Nut, Nyloc, M8, clamp bolt A075W3010Z 4 )
I don't see why it wouldn't be doable...
Old 10-05-2009, 02:01 PM   #5 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Wow I guess I should have read what I wrote.
You all got me!
Old 10-05-2009, 02:04 PM   #6 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Ok I sent racytracy a PM to see if she would be kind enough to change it for me.
Old 10-05-2009, 03:20 PM   #7 (permalink)
Chris Mackey's Avatar
What about the Smack Pack?
It's what you get when you make a mistake around here.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 10-05-2009, 03:45 PM   #8 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
I didn't know the track pack worked on an Exige??? Not sure why it would work on an Elise either
Old 10-05-2009, 03:51 PM   #9 (permalink)
V Not my picture V
RacyTracy's Avatar
Tracy
1996 Porsche 993TT Big news coming Tuesday.....(hopefully).
2008 Toyota FJ Cruiser
LOG 29 photos
RacyTracy is offline   Reply With Quote
Old 10-05-2009, 04:46 PM   #10 (permalink)
My car is really small
After all the razzing sombody should at least try to give him a straight answer. I am fairly confident it will bolt right up, but not 100%. Sombody more knowledgable should chime in...
05 Safron Yellow "bumbleBee"
A terrible car, but a great toy
02 mazda protge 5 "shagginwagin"
84 930 turbo "no nickname yet"
aschen is offline   Reply With Quote
Old 10-05-2009, 05:00 PM   #11 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Thank you aschen
I did deserve it and it was funny but back on tack
Old 10-05-2009, 05:36 PM   #12 (permalink)
apk919's Avatar
Images: 20
Originally Posted by V-RAPTOR View Post
Thank you aschen
Well, the LSS suspension is essentially what comes with the Track Pack, and the manual has a parts list and a procedure to upgrade, so...
I'd vote yes.
