All good
2007+ mirror removal?
I just recevied my Micro Mirror and the instructions are the same ones they provide for the 2005-06 cars. To me it doesn't look like they would apply, and I'm not at all interested in learning the hard way and cracking the windshield.
So, can anyone comment on the removal procedure for the newer style mirror? Thanks, Paul |
Excess ain't rebellion
When I removed the mirror from my '07, the mirror stalk just slid up and off of the base that's glued to the windshield. It's just held on with friction. If I remember (it's been years at this point), I just got a good firm grip on the mirror stalk as low as I could with one hand, applied a little upward pressure, and popped that hand with the other. It was a nervous moment, but it did require some force (the quick blow with my second hand) versus just pressure. The key to avoiding a broken windshield is to avoid heavy tools and make sure the pressure and force is applied parallel to the rake of the windshield.
-Brad
'07 Exige S Graphite Gray, LSD w/ TC, Track Pack, Star Shield |
Serial Thrilla
Don't worry about cracking the windshield. You'd have to hang off the mirror or do something equally stupid to break it. I use a paint can opener for leverage, but I have an '05.
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch 05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!) |
#5 (permalink) | |
All good
The new style mirror starting with the '07 year cars is much simpler to remove than the earlier version that is notoriously difficult to remove. There are no spring clips and the mirror just slides up and off the mounting plinth. Just push the base upward along the slope of the windshield and it will release from the plinth. As long as you are not prying the mirror base away from the glass you will not break the windshield.
Edit: Too late, looks like you figured it out. ![]() |
#9 (permalink) | |
-Brad
