#21 (permalink) |
You guys need to go to a drivng school where they teach weight transfer, which, by the way, in steady state is independent of body roll.
I personally think the concept is sound and the idea of more downforce on the inboard side in a corner would not be to affect body roll, but weight transfer. The inside tire has much less load and ability to bear more load without getting to the point where the ability to bear lateral grip diminishes due to vertical load is a factor. Tires do not have infinitely increasing lateral grip as a function of vertical load, they get nonlinear with higher vertical loads. In addition, it would take weight off the outside front tire, so the extra donwforce in rear would be less likely to just cause a huge push due to lack of comparable aero grip in front. That said, I might prefer twice the downforce over both rear wheels. But if I understand the controller properly, you can set up any change in angle of attack as a function of speed and g's, so you could have the wings work in tandem or not and see what difference it really makes. I thnk it is a great idea! If the price is sensible I am going to try it on my project car. |
#23 (permalink) | |
My other car's a mtn bike
I think you're discounting the fact that any one car can only use so much downforce at each axle, so if you can direct 100% of that to the inside wheel, you are getting more benefit than if you apply 50% to each wheel. In theory at least, the split wing accomplishes that, and from a visual perspective it appears to be a very agressive shape so I would think that it could in fact develop as much downforce on 1/2 the wing as most wings can over the entire length.
Sometimes you have to go in circles to move forward. 05 Elise |
#24 (permalink) |
Lotus/TRD Geek
Yea sure so who's going to be the monkey to try it first. I would like to see what people really think about it in real world experience. The concept does seem valid but I still have my issues with it.
Kids in the Back seat causes Accidents Accidents in the Back Seat causes Kids Moral Stick with a Two Seater |
#25 (permalink) |
'07 Black Exige S
I'm confused. Does the wing activate by computer based on brake, gas, and steering inputs or is the driver constantly pushing buttons while he's driving to manipulate the wing? Unless you're a former F1 driver, that seems like a lot of stuff to be trying to do (along with driving the car) on a track.
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness |
#26 (permalink) | |
McLareghini Bugatterrari
But I think that's irrelevant here. I hardly think that particular wing is going to cause either of those problems, at autox speeds, if you let it develop as much down force as it can on the outside tire as well as on the inside tire. xtn
#27 (permalink) |
Enthusiast
The yellow '01 BMW M3 in the video is Vic Sias'. He took third this year in Street Mod at Nationals. I would assume that he would be able to turn fairly consistent lap times..
One of the designers of the system posted up on NASIOC about it. Apparently, it's triggered off of accelerometers (lateral / longitudinal), so no need to twiddle with it in the cockpit - though you can tweak how much it triggers for a given g-loading back in the paddock. Active aero?! - NASIOC (designer's post is #30)
2004 Subaru Impreza WRX STi 2005 Lotus Elise 2006 Pontiac GTO |
#28 (permalink) | |
In the case of the Exige, for instance, the downforce is cut back to very little to avoid causing the drag our little motors can't deal with. It took the S to render any real advantage in that body style. So I'll ask you this, if you had a lead weight under the car that you could shift from side to side, wouldn't you want to shift it to the inside wheel on turns and the center of the car on straights? I know I would. If you do too then wouldn't you want a wing to do the same if it could? That would render all the advantages of that lead weight without the obvious weight disadvantage. The questions of stall speed and reaction time may indeed negate the value of this design, but like so many technological advances that have been shunned as some sort of heresy against commonly accepted principles, this design may deserve more merit than some of you are willing to even entertain. At the very least I would credit it as an interesting prototype that further R&D can improve. I'd like to see more data on this and even test a car with and without (or perhaps at zero lift, conventional fixed position and fully active). On the practical side, I would expect the split wing to perform to some benefit over a single wing, but I imagine it will never see any sanctioned racing due to restrictions.
Sometimes you have to go in circles to move forward. 05 Elise Last edited by R'elise Me : 10-12-2008 at 09:03 PM. |
#29 (permalink) | |||
xtn
#30 (permalink) | |
Enthusiast
#31 (permalink) |
Well no. Of course it remains parallel to the vertical axis of the car. Sorry to be inaccurate on that point, however my logic still stands; it's is much, much closer to vertical than the vector of force created by a mass of ballast weight.
xtn
2006 McLareghini Bugatterrari, Storm Titanium... <mods> installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates. </mods> Last edited by xtn : 10-13-2008 at 03:07 PM. |
#32 (permalink) |
No Acceptable Substitutes
Neglecting the "split" part of the design... active aero is standard on a number of Porsches as well. IIRC, Jaguar had a LeMans racer in the 50's which used active aero for braking, and not downforce... the entire engine cowl turned into a air brake.
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam |
#33 (permalink) | ||
The overall force vector of the car's mass does change from the pure vertical when a car is cornering, but the magnitude of the vertical component is constant... it's only the lateral component that changes. The weight distribution on the tires does change though... but the sum of the vertical components still equals the car's mass, regardless of whether it's cornering or not. Now, if the corner was banked or cambered, and not flat, that's another story.
#34 (permalink) |
Turbo Elise Slayer
I don't think the split design makes a whole lot of sense. Depending upon where you are on a track, you tend to either want as much downforce as you can get or you want the least amount of drag. The only situation where you'd want an intermediate condition would be in a full throttle corner where you'd want to reduce drag and downforce to the point where you're close to the limit of grip. If you're in any corner where you can't use full throttle, the only thing that will help you go faster is more downforce. On a straight, of course, you simply want the least drag. Because of that, you would tend to either want both panels angled for max negative lift or both angled for minimum drag.
Another thing about a split design: getting the same amount of downforce with two panels at different angles of attack as a single panel of the same span will necessarily generate more drag. This is because of the induced drag that will be generated between the panels when set to different angles of attack and therefore different lift coefficients.
1981 Ferrari 308GTSi, red. 2005 Hypersport Elise with roll cage, etc., SY. Katana SC, DA Nitrons, Pagid RS-14s, stainless steel brake lines, RTD brace. 2005 Noble M400, 515 bhp.
