cant remove hard top GGRRRR!!!
Ok so today im like damn its about time I remove that ****in hardtop, so I remove everything with a problem...but when I arrive to the back passenger one(the one near the rear), it just wont do, so ive tried ****in hard, tried other hex keys, etc etc.....all in all, this one wont get out, but the worse part is, now its worst than stripped, I completely ****ed it up from trying to remove it.....so please someone tell me what to do
-Seb
-Seb 2005 Lotus Elise LSS - Chrome Orange - Fully Loaded(LSS, Touring, Hard Top) - Not Stock ![]() 1994 Toyota Supra TT - Rennaissance Red - Mod list is too long - 1300+hp 2007 Mini Cooper S - Chili Red - Beater/Family Mobile |
#2 (permalink) | |
The Only Sane One Here
My other car is an MR2 Spyder. My other other car is a Segway. |
#3 (permalink) | |
-Seb
TWRD & Blip advertising
![]() Join Date: Jul 2004
Is the bolt itself not loosening?
All your trying to do is loosen the bolt low enough to unhook it. The big square piece above the screw has a hook just to the bottom right. When the screw is low enough. The square piece drops down to clear the hook. |
#5 (permalink) | |
-Seb
A smile a mile.
You need either an "Easy Out" screw extractor or a Craftsman "Bolt Out" set. I don't know what the hardtop bolts look like. I'd guess that an Easy Out would work best.
Paul Parkanzky Magnetic Blue with Biscuit Touring, LSS, Starshield |
#7 (permalink) | |
![]() -Seb
#8 (permalink) |
WOW. I dont know what lotus did to that screw but...I drilled the hole for the bolt out screw, screw the bolt out scew...the bolt out screw broke
What sucked at first is now pissing me off!!Help!!! -Seb
#10 (permalink) |
I would go to the dealer, if you are lucky, they will fix it under warranty. It is a captured bolt. I am not sure it can be replaced. A new roof may be necessary. Stop before you do more damage.
Greg
Aubergine/Black, Touring, Sport, and Hardtop |
#13 (permalink) |
oh crap, well the closest dealer is like 2-3 hours away....ill see what I can do this week...this totally sucks ass, if anybody got an idea let me know....and im sure they wont put it under warranty once they see the bolt....LOL
-Seb
#14 (permalink) | |
Hard top
was it a factory installed hardtop ? Who put it on last ? Do you have a Dremel tool? How about getting some help from a ''friendly'' local body shop ? You may want to have a pro operate with a mini cut off wheel after you protect the area with 200 mph tape. Don.
'' I always tell my students to follow their bliss- where the deep sense of being is from, and where your body and soul want to go''. Joseph Campell |
#15 (permalink) | |
![]() -Seb
#16 (permalink) |
the devil's advocate...
thats not going to work anymore... you are going to need to destroy the bolt now by drilling it out (which im sure at this point you could care less about the bolt. use a drill bit that is the same size as the bolt body (not the head) and drill until the head seperates from the body. HSS bits might work but a carbide tipped hardened steel bit (such as made by bamanufacturing) will give much better results, particularly if you cannot remove the easy out bit.
make sure that you keep the bit cool as you drill; this means putting down a bunch of towels and then spraying lubricant on the bolt as you drill (WD-40 will work OK for this but machine shops have better drilling oils. once the bolt head seperates you will be able to remove the top and replace the assembly. my guess is that you will either find that the bolt was cross threaded or siezed into place from corrosion. good luck... |
#17 (permalink) |
thanks rob, yeah I definetely dont give a **** about the bolt, it can be replaced....hopefully I can find someone to get it out for cheap
-Seb
#18 (permalink) |
AS # 0232
This screw is a type of captive screw. It has a threaded section then a reduced shaft size and then another threaded section. You might want to remove the other side all the way out so you can see what you have. The bracket should drop off into your hand as you finally remove the screw. I'm not at home right now or would go out and see what will work best for you. It is possible that getting the head removed will not let the bracket be removed. Hopefully someone here will get more info for you. Good luck, Bob.
Cuando Omni Flunkus Moritati |
#19 (permalink) |
well I went to the guy who works on my supra and he managed to unscrew it with brute force, so I brought the hardtop back hom in the passenger seat LOL now im open air YAY
-Seb
